Hot Rods Anyone using ladder bars on their hot rods?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Feb 3, 2021.
  1. Used to grab all the swap meet ladder bars I could get my hands on. Just changed the front mounts to heims to handle articulation.
  2. AHotRod
    AHotRod
    Yes ! I build my own ladder bars from scratch to fit my car design.
    Hnstray, mad mikey, loudbang and 2 others like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I have used P and J type ladder bars on numerous vehicles. the longer the bar the less chance of bind on tight turn, uneven terrain...going up steep driveways. triangulated 4 bar seems to have taken on a real following.. no need for a panhard/tracking bar and pretty easy to install..Put these P and J bars on my latest build 33 chassis
    mad mikey, loudbang and HOTRODPRIMER like this.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    My '33 Willys
    - ladder bars with Heim ends in double shear
    - coil overs
    - Watts linkage
    - 4-pinion posi 9"
    Launches like JackTheBear. The best setup on the street for stoplite-to-stoplite.
    -Brent-, mad mikey, loudbang and 2 others like this.
  6. 73RR
    73RR
    Looks nice!
  7. willys36
    willys36
    I run them on my Willys. I made a front mount using Mustang II strut rod donuts to allow for leaf spring movement.
  8. mgtstumpy
    mgtstumpy
    My 64 Fairlane T'Bolt clone has them however no sliders on the leaf springs.
  9. flamedabone
    flamedabone
    A bit of overkill, but this heap has a bunch of motor and slicks.
    And, the ghetto ladder bar/ torque arm on the '40.
    The shackle lets it get longer and shorter as the rear goes through it's arc.
    -Abone.
    dumprat, -Brent-, AHotRod and 5 others like this.
  10. 1971BB427
    1971BB427
    from Oregon
    Comp engineering on my Austin:
    Hand built on my '39 Chev coupe:
    Hand built on my Falcon too:
    -Brent-, AHotRod, chevy57dude and 4 others like this.
  11. A lot of what we see we call ladder bars because of the shape of them but they are really little more than hairpins. Nothing wrong with that either that is also a '60s styling cue.
    I think that in my mind a ladder bar suspension is a little more refined than your common '60s style suspension. What you normally saw on a '60s car was the bars reaching way up under the doors and pretty much static, the more modern rendition has some adjustability to find instant center and offset track conditions.
    mad mikey, 73RR and HOTRODPRIMER like this.
  12. 1971BB427
    1971BB427
    from Oregon
    I prefer adjustment at 3 points, and on two of mine I have inline adjusters on the bottom one of the two rear points. Makes them more versatile to square up the wheels, but also set pinion angle too.
    Hnstray, HOTRODPRIMER and mad mikey like this.
  13. HOTRODPRIMER
    HOTRODPRIMER
    This Chevy II use to prowl the streets in Anderson back in the 60's, you can barely see the ladder bars.
    The Magic Ratchet and mad mikey like this.
  14. mad mikey
    mad mikey
  15. HOTRODPRIMER and mad mikey like this.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Maurice was the John Miller back in the day around here, He just drove a different kind of Deuce. :)HRP
    mad mikey likes this.
  17. 3W JOHN
    3W JOHN
    Today's ladder bars are more tucked in and look more streamlined than than the ones seen in the hay day of the jacked up hot rods we use to see.
    HOTRODPRIMER likes this.
  18. HOTRODPRIMER
    HOTRODPRIMER
    These look good. HRP
  19. Almostdone
    Almostdone
    P and J bars on an A frame. Went with them rather than the more common 4 bar systems because I didn’t want to see the lower bar from the sides. These are unseen from the outside.
  20. upspirate
    upspirate
  21. HOTRODPRIMER
    HOTRODPRIMER
    I used the P&J ladder bars under my '32 Ford pickup. HRP
  22. mad mikey
    mad mikey
  23. HOTRODPRIMER
    HOTRODPRIMER
  24. Corn Fed
    Corn Fed
    When I freshened up the chassis on my ‘32 I left the old ladder bars/spring assembly that were there. It’s not how I would have set things up if I was starting from scratch, but it’s true late 60’s technology.
  25. Mike Colemire
    Mike Colemire
    My 33 plymouth will get ladder bars, wish I'd done it to start with instead of the 4 link. I want to build a set out of DOM tubing with 3/4 heim joints, CM and do them like Rjays have theirs set up. Next winter's project.
  26. 3W JOHN
    3W JOHN
    Basically the same thing I have under my 32 and it works.
