Technical ***February 2021 Banger Meet Thread - 6 More Weeks Shop Time!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 2, 2021.
  1. winduptoy
    winduptoy
    Are you running 12V or 6V?
  2. Tribalmonkey
    Tribalmonkey
    12v - currently original carb distributor intake exhaust...
  3. patina steve
    patina steve
    Nice Rattler on that Blue Engine
    winduptoy, G Baese and poshdbs like this.
  4. railcarmover
    railcarmover
    Somebody say big bore B? 4.060 big enough?
    Old Dawg, guitarguy and brjnelson like this.
  5. Tribalmonkey
    Tribalmonkey
  6. railcarmover
    railcarmover
    Filter pump on front of firewall, carter rotary electronic pump for a Vw,2.5 psi no regulator needed. Switched out alot along the way..FSI,Holley 94 8BA,cast iron original winfield 7.5 to 1 head.. still have 97,B distributor and Rosemead aluminum winfield in the stash. Flathead is enough for me, got ******s and blow to buy :) thumbnail - 2020-03-20T211738.489.jpg thumbnail (64).jpg
  7. Tribalmonkey
    Tribalmonkey
    Great set up! Thanks for sharing. Informative and funny [emoji1]
  8. railcarmover
    railcarmover
    One thing I'll add,and probably get grief for,is if you plan on driving the wheels off dont run a header..***y? Without a doubt,but with a single carb intake you don't transfer heat to prevent icing..my next build (or if I get anxious) is to use a stock exhaust manifold with a restriction free exhaust..heat transfer to the intake guaranteed.
    winduptoy, guitarguy and brjnelson like this.
  9. brjnelson
    brjnelson
    I agree on the manifold heat. It helps my gutted out equalizer manifold. If I go back to a header I may just weld a tank on the back of that intake and run hot water through it.
    winduptoy likes this.
  10. railcarmover
    railcarmover
    I have one of those vintage precision thermostats..was considering wrapping the intake horn with copper tubing and running hot water like a still to heat it but then I sobered up..
    Old Dawg likes this.
  11. V4F
    V4F
    from middle ca.
    bummer on sobering up
  12. I thought he was spending too much time near the still with the copper coils..........
  13. brjnelson
    brjnelson
    oops attachments not working will try again
  14. brjnelson
    brjnelson
    Thank you wheeltramp Brian for the gasket suggestion.
    The ridges for the gland rings have been removed from my ports.
    Jet96, Old Dawg and burl like this.
  15. brjnelson
    brjnelson
    Jet96 and burl like this.
  16. 5280A2
    5280A2
    Now you can go "Wide-Track" on those Colorado mountain roads too!
  17. railcarmover
    railcarmover
    Purely medicinal,its good for my lumbago
    Retson the Racer likes this.
  18. burl
    burl
    from Minnesota
    Think i might need to do this.After i switched to the big 97 i noticed it like to ice up.
  19. Mikko_
    Mikko_
    from Sweden
    Well, how things can change.
    Had an order placed for a Brierley head but due to some other, unexpected expenses I had to cancel my order and go for something cheaper for the time being.
    Ended up with a simple and kinda boring to be honest, Snyder 5.5:1 head instead.
    To quote Johnny Cash, "Guess things happen that way".
    Carter, winduptoy, Jet96 and 3 others like this.
  20. If it counts, I purchased a Simmons Super Power head, and had to end up selling it.
    That intake looks killer! What is it?
    winduptoy and Mikko_ like this.
  21. Mikko_
    Mikko_
    from Sweden
  22. Fabber McGee
    Fabber McGee
    winduptoy, Jet96, Mikko_ and 2 others like this.
  23. Well, backup engine is in the shelf. I gotta figure out the “poor boys” method of polishing that valve cover
    Jet96, rwrj and Mikko_ like this.
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    That is the intake available thru Snyder’s, and I’m sure other vendors as well. I ordered one recently to cut up for a non A project... turns out the runners are noticeably bigger than a standard A, so I chose not to use for my application. My guess is the manifold runners would probably flow more than a single 97 could supply... maybe a 9super7 tho...?
  25. Fabber McGee
    Fabber McGee
    I was familiar with his aluminum body thread, but hadn't seen the blown banger.
    winduptoy and Retson the Racer like this.
  26. railcarmover
    railcarmover
    I bought some heat pads to play with,small 1"x 2" pads 12v small versions of the ones that keep oil pans warm..search 'engine heat pads' but I figure the stock exhaust manifold flows well,Im not so comfy with running electrical stuff so close to fuel,The stock manifold does the trick and provides heat all the time.
  27. railcarmover
    railcarmover
    The snyder 5.5 is a direct copy of the only performance head developed by ford engineering, the 1931 "police" head. Its heart shaped chamber has way better turbulence than stock and a compression pressure increase to the 90 psi range with everything else fresh. I ran a 97 with a shaved 5.5, hard to tell the difference between it and the 7.5 Winfield I currently run...tune it and go, you'll be happy
  28. Mikko_
    Mikko_
    from Sweden
    Yes, performance wise I am sure it will be just fine for me, and I'll be running a 97 too.
    When I said boring I was just refering to the look of it, it doesn't exactly look like a performance head.
  29. Phil Damon
    Phil Damon
    from San Diego
