Technical Vehicle ID Help Please
Discussion in 'The Hokey Ass Message Board' started by 59BuickWagon, Feb 6, 2021.
  1. A friend of mine got this sedan and it came with a ***le saying it was a 1931 Ford. Well it's pretty obvious that it's not (unless it's some foreign built odd ball like from Argentina or somewhere.)
    Did some Googling and I think it may be a 1931 Chrysler but I'd like to drawn on the wisdom of the HAMB and see if anyone has better idea.
    Thanks in advance.
    Speed Gems likes this.
  2. X38
    X38
    Yes, a 70 seems real close. Chrysler 70 that is.
  3. squirrel
    Sure looks like it
  4. May be ***led as a 31 Ford because of the numbers on the frame.
    GordonC likes this.
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Whoever chopped it left the door gaps a bit generous at the roofline!
  6. If there were 1932 Ford numbers stamped on the frame I'm guessing the factory didn't do the stamping:)
  7. X38
    X38
    Or build the frame!
  8. No guessing there - that's for sure!!
  9. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    It's a Chrysler products body. ID by the detail on the top of the cowl. Unique to the maker. Could possible be a Dodge but memory fails.
  10. King ford
    King ford
    from 08302
    Maybe with a bunch of work that could be built into a hotrod....
