Projects Henry Steel or not
Discussion in 'Traditional Hot Rods' started by Ford72, Feb 7, 2021.
  1. Ford72
    Ford72
    Hi all
    I have a 32 ford 3 window all Henry steel, but the rear quarters and the p***enger rear roof are not fixable so I will use Brookville parts.
    So my question is, is it still a Henry steel or just a steel car?
  2. hemihotrod66
    hemihotrod66
    If it's got a good ***le no one cares...LOL...
  3. trevorsworth
    trevorsworth
    These cars are coming up on a century old. Nobody expects every molecule of Henry's Patented Original Bessemer Steel™ to be intact. Patches, body filler and replacement parts are normal. It's OK to say it's Henry steel if the car was built in 1932 and you had to fix some damage.
  4. stanlow69
    stanlow69
    Everything is fixable. You just need to find the right guy. Read the build thread of @33anda3rd(spelled that wrong) pickup re do.
    VANDENPLAS and loudbang like this.
  5. rustydusty
    rustydusty
    Repair panels are used on just about every old hot rod build. This is still going to be a "Henry steel" car...
  6. alchemy
    alchemy
    A couple repro panels won't make it worth any less. And if the repair job is done nicely it should give you pride in the work done to keep it going.
    MR CLEAN, OzMerc39, Driver50x and 3 others like this.
  7. big duece
    big duece
    from kansas
    If you get a new heart from a pig, a new knee or hip joint, do you change your name or social sec #? Yes even with a few needed repairs that would still be cl***ified as a Ford survivor...
  8. pirate
    pirate
    from Alabama
    So if you buy a brand new Brookville body and cut out a chuck of the body and replace it with a section of original Henry steel does that make it real Henry original. I have seen guys start with a cowl and everything else is patch panels and weld and claim it’s original Henry steel. This has been discussed I don’t know how many times and you might as well throw in fibergl*** also. If you build a car and you like it that’s all that counts. Drive it, enjoy it and don’t worry about what others think or say or feel the need to ask for permission. My opinion your mileage my vary.
  9. DDDenny
    It's a 3 window, that should be enough!
    Sure, there is a wide gap between a stocker and a hot rod, there is also a lot of leeway even a**** the purist( traditional) hot rod culture.
    Too much pidgeonholing hinders creativity, besides, aftermarket fenders are not a crime.
  10. adam401
    adam401
    Id be interested in your unfixable panels.
  11. Ford72
    Ford72
    Thanks all
    It doesn’t matter for me if it is Henry or not just a question:) just as long it’s a steel car and not gl*** car.
    And yes I can’t wait to drive it
  12. Ford72
    Ford72
    Traditional style
  13. Ford72
    Ford72
    Adam there is nothing left of the panels totally gone
  14. Budget36
    Budget36
    I used the ends of Camaro fenders for the cab corners on my Dodge PU, it’s still a Dodge;)
  15. HOTRODPRIMER
    HOTRODPRIMER
    To some, It doesn't matter is it's steel or not. I have known some guys that are so **** about gl*** cars that they never own a hot rod because they can't afford steel.
    I have owned a coupe of gl*** cars in the past and they may not have been real steel but they were real fun,:) HRP
  16. big duece
    big duece
    from kansas
    If the 32 body still retains at least 75% or more of original steel car, I would feel like that's a solid statement. An aftermarket steel body, with say an original deck lid or say an original door is stretching it a bit. If it really bothers you, I can take it off your hands so you won't loose sleep at night...:D:D
  17. jim snow
    jim snow
    X2. Answer the question with,yes it’s steel. End of story.jmho. Snowman
    hotrodjack33 and pprather like this.
  18. Ford72
    Ford72
    I have nothing against gl*** cars I just like steel
    I have a little question more, I have a 25 louvred 32 hood.
    Why is the price so different from 20 to 25 louvred hoods?
  19. adam401
    adam401
    Ok thanks. Good luck with your build.
  20. Ford72
    Ford72
    Thanks Adam
  21. Ford72
    Ford72
  22. Ford72
    Ford72
  23. chopo
    chopo
    IronFord and Speed Gems like this.
  24. bill gruendeman
    bill gruendeman
    I think the car would be worthless, so if you want be get rid of it I will give you my address so you drop it off at my house. Just kidding it’s still a Henry, don’t worry about it
  25. big duece
    big duece
    from kansas
    The 25 louver hood was introduced late in the production run, to aid in heating/cooling issues so there were way more 20 louver hoods made... show us some pics and quite teasing us!
    kidcampbell71 and 19Eddy30 like this.
  26. HOTRODPRIMER
    HOTRODPRIMER
    Is your hood a original 25 louver or rootlib?
    HRP
  27. J. A. Miller
    J. A. Miller
    from Central NY
    Supply and demand.
    clem and Chief 64 like this.
  28. Ford72
    Ford72
    It’s a original one with no rust at all :)
    It is just unbelievable how much the price difference is.
    kidcampbell71 likes this.
  29. warbird1
    warbird1
    And in the big picture; it really matters because?
  30. Ford72
    Ford72
