Customs 1956 Ford Victoria (New to me)
Discussion in 'The Hokey Ass Message Board' started by Eric16, Feb 7, 2021.
  1. Eric16
    Eric16
    Hello there H.A.M.B. members!
    Here is my recently purchased 1956 Victoria. I'm a younger guy, and this is my first purchase into the 50's era for cars.
    It's 100% stock with:
    292 Y-block
    3 speed with overdrive
    Power steering
    Manual drum brakes
    This thing loves to cruise, but it could use a couple of upgrades.
    At the top of the list would be power brakes, radial tires, replace the exhaust manifolds, and a new exhaust system.
    Just curious for you Ford guys out there:
    Any recommendations for a power brake conversion?
    Do bias-ply look radials still drive well?
    Any suggestions for replacement manifolds, headers, or mufflers that sound good on a Y-block?
    Anyone run A/C in these?
    I appreciate any direction you could point me in. Until then, here are a couple of shots of the car!
    20210123_154706.jpg 20210207_164526.jpg 20210207_164533.jpg 20210207_164616.jpg 20210124_173615.jpg
  2. BJR
    BJR
    40 years ago I saw a 56 Ford 4dr with factory air.
    Stogy and loudbang like this.
  3. Zax
    Zax
    Beautiful car! Diamondback Tires makes an Auburn Radial that looks like a traditional bias ply that rides really well.
    Join the 1952-1959 Ford social group.If anyone knows what power brakes and exhaust would work it's that crew. They even have a sticky that contains a lot of info on upgrades.
  4. Oldb
    Oldb
    That one is a beauty.
    B
  5. ahshoe
    ahshoe
    Had this pea**** blue and snowshoe white 1956 Victoria and in all my years it is the only car I regret selling. You have a very nice ride there, congrats
  6. Beautiful! And I am not a Ford guy. For the AC, may I suggest an under the dash unit such as the Mark IV. Much quicker and way less invasive and completely removable. Mine is an original unit from the 50s and keeps my black Buick 4 door cool here in the Texas summer. Newer ones will be more efficient and quieter.
    Ben
  7. i.rant
    i.rant
    Seldom seen paint combo, nice ride.
  8. miker98038
    miker98038
    Nice car, great start. I'll second the Zax comment about the social group and it's information.
    You might add your location to your signature, sometimes there's someone close.
    I have the Coker bias look radials on my 32. I had no out of round or balance problems and they drive great.
    Most of what you need to know about y blocks, casting numbers, etc.
    http://www.ford-y-block.com/
    There's a write up about a/c that recent here. Read to the end about the radio problem if you go with a modern unit. It's a beautiful install.
    http://forums.y-blocksforever.com/Topic153710-1.aspx
    Hopefully jimmysix will see this, he's got a lot of information on his 56 Vic.
  9. Bbdakota
    Bbdakota
    Beautiful car! I second the diamondback Auburn's. Under dash ac (I used vintage air) is not to difficult to add to about any car. Good luck with it!
    firstinsteele and loudbang like this.
  10. 03GMCSonoma
    03GMCSonoma
    Mine was painted '59 Ford off white. With a Y-block gl*** packs are absolutely a must. I used Walker tapered gl*** packs. The really sound good when you let off the gas and let it slow down on its own. Look at this link and see what you think. 1957 Ranchero with Gl*** Packs - YouTube Maybe this won't work.
  11. MeanGene427
    MeanGene427
    from Napa
    I have a set of dual exhaust manifolds that eliminate the front crossover pipe, scrounged them up for a project that got traded off. Seems like they are from a 57, would they fit?
    Atwater Mike and loudbang like this.
  12. chargin03
    chargin03
    Very nice!
  13. hudsonmand
    hudsonmand
    I saw one in the seventies had clear duct work in back window
  14. scotts52
    scotts52
    Beautiful! Great colors
  15. Hdonlybob
    Hdonlybob
    That is a real Gem....love it..
    Good for you..
  16. Norris McCarty
    Norris McCarty
    Awesome! I’d drive it!
  17. blowby
    blowby
    from Nicasio Ca
    Great model, great year. Really sweet.
  18. guthriesmith
    guthriesmith
    Very nice car! I have no information on aftermarket power brakes since mine are factory. But, I am running some of the bias look radials which are American Cl***ics and I have been happy with them. My car had Coker radial wide whites before and these ride just as good as the Coker radials. If your bias tires aren’t old, I would just run them. They look good on it.
    Also curious why you want to replace the exhaust manifolds? I need to do the same, but it is because they are both broken right behind the first bolt. I’m just replacing mine with another set of the same.
    loudbang and arkiehotrods like this.
  19. Jalopy Joker
    Jalopy Joker
    You did good getting this beautiful ride - the upgrades will be worth the time and cost
    Sent from my SM-G930V using The H.A.M.B. mobile app
  20. southcross2631
    southcross2631
    I did some work for a guy with the Coker bias looking radials and he had to run a higher tire pressure to keep the car from wallowing all over the road. After that he said they were fine.
    I had a 57 Fairlane with 27 inch gl*** packs and 2 1/4 inch pipes that sounded amazing.
    I installed vintage air with an under dash unit to keep the nostalgic look. It was real good after I added an electric fan to keep the airflow up when stopped at red lights. Added a GM alternator at the same time.
  21. guthriesmith
    guthriesmith
    Pretty sure those sound like the ones that are factory on my 56 that also has no crossover. Looks like the OP has the same as well from what I can see in the pic of the engine.
  22. GordonC
    GordonC
    Holy ****! An A roadster AND a 56 Vicky! Does it get any better?
  23. arkiehotrods
    arkiehotrods
    Beautiful car! Congratulations!
  24. warhorseracing
    warhorseracing
    from cameron wv
    Obviously being that you are a "younger guy" you obviously have no idea as to how to drive a standard shift vehicle especially a three on the tree.:( So you may as well just give me the car now and quit being chauffeured around by your Dad.;) Really, nice car and great that you scored it.:D Have fun and enjoy the looks that you will get.:cool:
    03GMCSonoma and loudbang like this.
  25. jaracer
    jaracer
    I've been driving a 57 T-Bird for the last 24 years. The biggest improvement probably came with radial tires. I put on gas shocks and they may have helped, but not as much as the radials. The next biggest improvement with handling came from a new front sway bar and the addition of a rear sway bar. I think the front bar is about 1 in diameter. The sway bars really made it corner much flatter.
    I still have the factory brakes, but they are power. I've got the stock exhaust without the resonator and it sounds very good. However, a set of Porters would sound real good on a Y block.
    I had a 54 Mercury with a 3 speed OD, loved it. Also, Ford did offer dealer installed AC in 56.
    stillrunners likes this.
  26. loudbang
  27. Fortunateson
    Fortunateson
    Power brakes we're an option in '56 but they were not disc. I'm pretty sure AC had the clear ductwork for the rear of the cabin like the Mercs. The white in '56 was Wimbledon White I believe.
  28. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Great looking car, enjoy it!!
  29. stillrunners
    stillrunners
    from dallas
    Nice car and like what JimmieSix did with his brakes
  30. Lost in the Fifties
    Lost in the Fifties
    I had a 56 that had an ARA dealer installed under dash AC that would freeze you out in Texas summers. Keep your exhaust manifolds and just install whatever sound mufflers you like. I envy you having that beautiful car!
