Technical 8.8 Ford rear end in a 1940 Ford coupe
Discussion in 'The Hokey Ass Message Board' started by geoford41, Nov 11, 2020.
  1. tracker_63
    tracker_63
    from california
    I have a 8.8 and want to change that yoke flange to a u joint style rather than the flange style? It's a 31 spline axle type off a explorer. Any tips on part numbers to swap the flange out to a u joint style? Thanks.
    Sent from my SM-G975U using The H.A.M.B. mobile app
  2. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    03/04 Cobra would be my guess
  3. 1971BB427
    1971BB427
    from Oregon
    Denny's sells yokes for various std. U joints. But considering the cost I prefer to use an adapter U joint myself. Only about $25, vs. $150 for the yoke.
    https://www.dennysdriveshaft.com/p3...ion_yoke_1350_series_fits_ford_8.8_inch_.html
  4. 1971BB427
    1971BB427
    from Oregon
    When I built my '39 Chev coupe I set the engine, and bolted up the trans. Then made my trans mounts, and set the 8.8" rear axle to center in the rear fenders. Got underneath and measured up the driveshaft length, and the length seemed like maybe a common size? So I began searching the internet and found a 3rd Gen Camaro V8 had a driveline very close to what I needed. I looked on local CL and found a guy parting one out, and bought the driveline for $40. Took it, and the Ford flange to my local driveline shop, along with a new 7" input yoke I determined I'd need for enough total length. Had new u joints installed, and one the adapter joint to go from the Chev driveline to the Ford flange, plus balancing. Whole deal, including the driveline purchase came in under $200. And if I ever needed another driveline i just use a 3rd Gen Camaro stock V8 unit.
  5. thecj3man
    thecj3man
    from TN
    tracker_63 likes this.
  6. tracker_63
    tracker_63
    from california
  7. indyjps
    indyjps
    Hate to link another site for info. BUT, Check this out. Very well put together data source for 8.8's.
    https://www.therangerstation.com/tech_library/Ford-8_8-axle.shtml
    Im looking for a few 8.8's now, even though I have a few factory narrow 9"s on the shelf. Some builds just dont a 9" and the cost ***ociated. A ready to go 3.55 to 3.73 "posi" that needs brackets is perfect for a driver, cruiser that'll never see slicks.
  8. thecj3man
    thecj3man
    from TN
    Your welcome. Its a Yukon piece, so it should be available just about anywhere. East Coast Gear Supply just happens to be the closet to my house.
  9. tracker_63
    tracker_63
    from california
    By any chance, did u have clearance issues in the driveshaft tunnel with the old 5 inch coupler vs the u joint style?
  10. tracker_63
    tracker_63
    from california
  11. jakespeed63
    jakespeed63
    My club brother and I pulled 2 Ford Explorer rear ends out at the u-pull-n-pay yesterday. They were having a black Friday special of $30 off the regular price of $180. Not actually ready to dive into swapping into my '39 Coupe, just yet, but we were both there and seemed like a no brainer. Scott grabbed a 3:73 posi unit from a 2000 4WD, mine is an open diff. I'm OK with that. Need to do the front disc brake swap first. Speedway actually has a $50 coupon for black Friday until today. Can't really afford the $380 right now but might just have to put on credit card. Another deal too good to p*** up. BTW...I'm over the poor stopping power of the drum brakes, on my Coupe. Yes, I've tried all kinds of stuff to improve it, including a dual master. And the 2:35 rear ratio ****s too. (Granada rear axle)
  12. jakespeed63
    jakespeed63
    My club brother and I pulled 2 Ford Explorer rear ends out at the u-pull-n-pay yesterday. They were having a black Friday special of $30 off the regular price of $180. Not actually ready to dive into swapping into my '39 Coupe, just yet, but we were both there and seemed like a no brainer. Scott grabbed a 3:73 posi unit from a 2000 4WD, mine is an open diff. from same year, I'm OK with that. Need to do the front disc brake swap first. Speedway actually has a $50 coupon for black Friday until today. Can't really afford the $380 right now, but might just have to put on credit card. Another deal too good to p*** up.
    Sharpone likes this.
  13. Crusty Chevy
    Crusty Chevy
    Be mindful that the speedway kit pushes out the front tires quite a bit on each side, around 1". If you have a narrowed front axle you are OK but stock and lowered it will cause fender and tire issues without deeply inset rims.
  14. 1971BB427
    1971BB427
    from Oregon
    Our local Pick N Pull had a 40% off sale this last weekend and the regular price on an 8.8" with disc brakes is $230, so that makes them around $138 on the sale.
    I almost went shopping for a spare as I usually like to keep a good 3.73 or 4.10 posi around. But not sure I've got any projects in the near future, and it's cold as Hell outside right now, so stayed home and ate leftovers instead!
