Projects Not Another 41 Pickup Project!! (Update: 12/06)
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Aug 7, 2020.
  1. Grandadeo
    Grandadeo
    Well I really hosed that up. Summit paint for the engine and maybe the wheels with dark maroon body paint.
    Lee
  2. hotrodA
    hotrodA
    Wow! That would pop!
    Price is right, too.
    I’ll check out Summit.
  3. Grandadeo
    Grandadeo
    Bill this was a while ago so they may not still have it. Seemed like they were clearing out that product line. As far as pop, I hope so. I was using a creamy tan for engine and wheels. Boring! Denise is wintering with her parents and came down to the Ranch for the day. Saw her last at the Lone Star in 09.
    Lee
  4. hotrodA
    hotrodA
  5. Bandit Billy
    Bandit Billy
    Looking great! I really like the valley pan and valve covers you chose.
    I sprayed my flathead with maroon paint that I had mixed and canned at the paint store with hardener in the can, to match the exterior. Still looks nice and cleans up easy.
    On my Hemi I used Eastwoods gloss black ceramic 2K engine paint. I did the trans, oil pan, intake and block. $25 bucks a can, I think it was a $100 paint job. :eek:
  6. arkiehotrods
    arkiehotrods
    I wasn't even thinking about trying to find a '40-'41 Pickup to go with my coupe but after reading this thread, now I am! I'm enjoying following your progress!
  7. hotrodA
    hotrodA
    Thanks for the compliments!
    Pleasantly surprised today! WOOHOO!
    Pulled the pan today......after I found out that I couldn't rotate the heavy SOB on my non-gear driven engine stand! Took some weight off the front with my hoist and a trailer strap. Worked great!
    Having those heavy ass heads on really makes it tough when it gets to 45 degrees rotation. Haven’t yet figured out how I’ll get it rotated upright.:eek:
    Pan will need some love to reach @Bandit Billy standards, though.
    Bottom end looks like it was put together yesterday!
    And the bonus is that it looks like it was balanced!! Fresh machine and drill marks on the rod caps, piston pin bosses and crank counterweights! The weight records are still legible on the rod caps.
    Plus there is enough room to brush some break-in lube on the cam lobes. I'm super stoked!!
    Comp Cams said the cam grind would be engraved or stamped on the rear journal, behind this freeze plug. Think I will leave well enough alone! Or maybe check it with a degree wheel and indicator. Have to see if I feel THAT energetic. There are more pressing issues.
  8. hotrodA
    hotrodA
    Tedious, back killing, PITA, but it's ready to go in the oven. :D
    Old black was either chipped or multi coats thick. Foil is your friend on the irregular shapes.
    Now if the weather will cooperate just one day, so I can open a bay door, pull the 32 out, and get some primer on it.
    brEad and loudbang like this.
  9. hotrodA
    hotrodA
    Woohoo!!
    When you're a simple person, small things can make your day. I had been moping around after loss of sleep for the wrong reasons, and a little package came today from Germany.
    The wee VW turn signal that I posted before had a defective part, namely the little strap that attaches it to the column. The seller graciously sent me another.
    Amazing how well it fits an Early Ford column.
    Simple minds, simple pleasures!
    Thanks, I know there is trash behind the gauge glass. It still has to come apart for new gauge faces.
    Now.... it's back to that aggravating Desoto.
  10. Bandit Billy
    Bandit Billy
    It's nothing a little sanding, primer and a heavy 2k flow coat can't fix. And always remember the famous adage "if it's worth doing, it's worth doing it shiny":cool:
  11. hotrodA
    hotrodA
    That Eastwood 2K looks like good stuff! Too bad they don’t have it in a maroon.
    loudbang and Bandit Billy like this.
  12. Bandit Billy
    Bandit Billy
    That's a fact! I went to the local paint store and had them make 6 cans of royal maroon and put them into rattle cans.
    They were base coat to be clear coated with the Eastwood 2k high gloss clear. I used a high heat primer on the flathead before painting. It has been driven and the paint still looks nice after being hot. No adhesion issues either.
  13. hotrodA
    hotrodA
    Great tip! What type of paint did they put in rattle cans? Acrylic enamel?
    I’m headed to our paint supplier tomorrow.
    Actually found a left over can (actually only a couple ozs) of GM Brandywine 2K from my long ago 56 pickup. Still had a legible code, so I see where that goes.
    loudbang and Hamtown Al like this.
  14. Bandit Billy
    Bandit Billy
    Yes, I used acrylic enamel base. Here is a shot of the oil pan after clear coating.
  15. hotrodA
    hotrodA
    Thanks, looks great!
    What brand is it?
    My NAPA/Martin-Senour paint guy said his acrylic enamel would burn off on the heads. Other paint jobbers here are 30 miles away.
  16. Bandit Billy
    Bandit Billy
    I am not sure what the brand of paint was and I am at work now, I can look later and see what they wrote on the cans. I can't speak to the heads as my flathead has aluminum heads but it has stuck everywhere else. But that also why I used a high heat primer.
    That 2k Eastwood Ceramic engine paint the hemi is painted with sure didn't burn off during the burn in. :cool:
  17. hotrodA
    hotrodA
    Thanks for your efforts. When you have time.
    If the maroon held up around the flathead’s in the block exhaust ports, hopefully it will hold up on the hemi’s.
    Bill
    loudbang and Grandadeo like this.
  18. hotrodA
    hotrodA
    Not much to write home about from here on the frontier. Got some 2K from Eastwood, but too rainy and cold to paint the lump of a Desoto.
    I think I got the multi-layered black carved down and ready for primer.
    This heavy SOB has tried to whip me but you don't get old by not learning things. With it upside down with the heads on, it was impossible to rotate back upright. Engine hoist and sling first around one head, then the other, got the job done. Whew!
    Made up a brake parts shopping list for front and rear. Guess that's next on the agenda. Stay tooned.
    The 39 guy, Hamtown Al, brEad and 5 others like this.
  19. hotrodA
    hotrodA
    Still slow here on the frontier.
    Front and rear brake parts ($$ = everything) started coming in from four different Rock Auto warehouses.
    Don't think I like that.
    Chemical stripped several heavy coats of paint off the Desoto oil pan, getting it ready for primer. Couple of dents to take care of. My mentor@Bandit Billy, said "Smoooooth and Shiney, even if you can't see it!"
    Three lone days of spring-like weather with no rain gave me the choice of engine painting ......or getting this slab (45x55 tapered down to 25 wide driveway) poured up to the existing shop slab. Finally can move a car in and out and not have to fight the gravel.
    2 truck loads, 20 yards, with fiber and wire/rebar took care of a bunch of Benjamins !
    Tim, 40LUV, Bandit Billy and 7 others like this.
  20. joel
    joel
    Smooth concrete is always a benefit and it pays dividends every day. Congratulations.
    hotrodA and loudbang like this.
  21. Bandit Billy
    Bandit Billy
    Smooth and shiny can apply to concrete as well. :cool:
  22. Grandadeo
    Grandadeo
    Easier to shovel for sure.
    hotrodA, Hamtown Al and loudbang like this.
  23. hotrodA
    hotrodA
    HA! Now I know why you moved to FL.
    Two years ago I had to bust and shovel 4” of packed ice and snow on 500 feet of driveway just to get in and out. No fun.
  24. hotrodA
    hotrodA
    Finally got some self-etch primer on this aggravating thing. A lot of labor for something that no one will see.
    Just couldn't leave it alone.:rolleyes:
    brEad, Grandadeo and loudbang like this.
  25. hotrodA
    hotrodA
    Concrete and fill has about wore me out, but today was so nice, I rolled the 32 outside on to the new concrete, and moved the 330 lump over to the door.
    Two coats of Eastwood 2K high temp primer on the engine and oil pan.
    Small step but a big one in the scheme of things.
    Not as slick as @Bandit Billy's but good enough for the oil change guy, or wayward possum.
  26. hotrodA
    hotrodA
    @Bandit Billy
    How long did you wait after the color coat before you applied the Eastwood 2K clear?
    Thanks!
    Bill
  27. Bandit Billy
    Bandit Billy
    Just until it dried to the touch, maybe an hour or so. it was all done the same day. The clear makes it so easy to clean up my flathead's "droppings" although that was nearly eliminated byt he addition of the PCV I added.
  28. hotrodA
    hotrodA
  29. Bandit Billy
    Bandit Billy
    I am no expert (though I play one on TV) but i would not try that hardened clear over rustoleum without trying a small sample piece first. I am not a rustoleum fan at all but something tell me thats no bueno.
    Go somewhere else.
    And who the hell is broncobilly? :cool:
    Guy Patterson and loudbang like this.
  30. hotrodA
    hotrodA
    Thanks! Corrected!:oops: Must have confused you with another famous guy.
    Didn’t think that I could do a sample spray out, since once the EW 2K is activated in the can it has a limited pot life, and I would lose it.
    Thinking to just buy a quart of another brand and be done with it.
