Just getting started on this project. First issue is the frame is separating. Can't find a donor frame in my area. Only 2 options I can think of is swapping the frame for something more readily available such as an S10 or other frame or building a new frame from scratch. I don't believe it's repairable but if you guys know otherwise please share your suggestions.
S10 frame won’t work, most other frame swaps put the wheels in stupid spots and limit steering and look ...... well..... stupid. when you say separate go what do you mean? Is it a top hat frame like Chevy ? your pics didn’t load . it’s a frame ! You can cut and paste as much as you want to correct it. it’s steel not flesh, if you screw or up start over, or find a doner But first get your pics working so we can see what you see.
Then it’s a top hat frame like a Chevy, Canadian poncho was just a reskined Chevy Opens options for parts cars n finding a frame. Post pics !
A top hat style frame on face value wouldn't be that hard to repair depending on what you cl*** as 'Separating'. It's a very basic frame unlike a full frame with open 'C' channel as in Oldsmobiles, Buicks and Cadillacs. Or as suggested, a simple frame swap may be in order?
I don't know why my pics aren't loading because they're in my album. And I've searched high and low around here with no luck on a frame - Chevy or otherwise
According to my book, "Canadian Cars, 1946-1984" by Perry Zavitz, the Fleetleader is the Canadian, Chevy based car. A frame from either the Chev or Pontiac should work. Post pictures of the problem areas of your frame. Maybe it isn't as bad as you think.
Looks repairable however time is money. Do it once do it right. Either way the body needs to come off frame for repair or replacement. There's time involved wither way, rolling a better frame under your body would be quicker and more time efficient.
That frame is toast. Once you sandblast the outside you will have more holes than steel left, and you still haven't removed the corrosion from the inside. The key to fixing old cars is having lots of friends. Get the word out for what you are looking for. You need to let everybody you can do some networking for you. Unless you are an experienced fabricator, a swap from a different model car is not a good answer. You will spend more time modifying everything to fit than you would making calls to find a direct fit frame. You might make some calls to the US looking for shops that are doing frame replacements with pro-touring style full IFS frames. They'd probably be giving the old stock frame away for the hauling.
It looks like repair work has already been attempted on that frame. I would agree that it needs replacement. There should be frames available somewhere as Chevy is the same. All body styles used the same frame as well, except conv. I believe. I know the local pic a part has some Chevy's in it, but I never looked at any frames on them.
