Technical 1940s Ford Steel Rims
Discussion in 'Traditional Hot Rods' started by RobG, Feb 6, 2021.
Tags:
  1. RobG
    RobG
    from WA
    More research paths - thanks!
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    @RobG please conduct your buying and selling via PM. thank you
    RobG likes this.
  3. Tetanus
    Tetanus
    I'm checking about 3.43 ish with telescope gage so about 3-7/16 bore on a 1941 16x5 ford wheel 1612917186592.jpeg 1612917288925.jpeg
    Sent from my SM-G930R4 using The H.A.M.B. mobile app
    RobG likes this.
  4. Tetanus
    Tetanus
    RobG likes this.
  5. RobG
    RobG
    from WA
    Thanks for taking those measurements! So I would need to bore it out to the point that the lip is gone to get to 4”. I think that’s doable but I really hate to ruin an original part. Thanks again!
  6. Tetanus
    Tetanus
    Looks like at 4" you would be in the middle of that stamped bead. I think a pretty good place to end up. 1612918854432.jpeg 1612918990552.jpeg
    RobG likes this.
  7. Tetanus
    Tetanus
    There's a lot more 16x4 ford wheels than fords to put on I think. 4" ers are pretty common. Cut em up. Big lathe or a cnc mill could spin that right out. Or manual mill with big rotary table.
    RobG likes this.
  8. Tetanus
    Tetanus
    This is where you will end up the caliper is set to .28 which is what you would cut per side to get to 4" looks good 1612919410527.jpeg
    RobG likes this.
  9. stillrunners
    stillrunners
    from dallas
    Yep - that's what I got on a Jeep - about 4" - Moriarity had the answer I believe - here's some pick of one of my early Ford's that was cut for a Jeep and my Jeep lock hub which is a smidgeon over 4" . 20210207_173626.jpg 20210207_173618.jpg 20210207_173454.jpg
    RobG likes this.
  10. rusty valley
    rusty valley
    i've seen those wheels with the bump between the lug holes on lots of old commercial stuff like air compressors, and trailers, etc. but unless you know of some old yards to look, i would just make what you need
    RobG likes this.
  11. RobG
    RobG
    from WA
    OK, sounds good
    I’ll find a set of Ford rims and tweak them a bit to fit.
    Thanks for the time spent taking measurements and researching.
    mansfieldlad likes this.
  12. RobG
    RobG
    from WA
    You’re right - I think they are out there. So use what’s available now and watch for the exact match.
  13. RobG
    RobG
    from WA
    I’ve found a pair of rims for my project! Thanks everyone for your ideas and suggestions. Rob
