Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. alchemy
    alchemy
    Both of the chokes in my 97’s on my V8 are locked open. Never use them.
  2. tb33anda3rd
    tb33anda3rd
    I drilled the ball on this one, oblong, so the cable could be slipped through and a cable stop attached to pull it on and off. IMG_9825.JPG
  3. Tribalmonkey
    Tribalmonkey
    Should I consider a new cam while I am this far in? What all would be involved? I should be getting my FSI2 distributor and Snyder 5.5 head within the next few days. I discovered don’t have adjustable lifters. Here is a pic of my mock up so far. IMG_5317.JPG
    John Heckman, Tim, drdave and 6 others like this.
  4. Tribalmonkey
    Tribalmonkey
  5. Dick Stevens
    Dick Stevens
    D
    Drill mounted wire brush
    StraightAxle64Nova likes this.
  6. Tribalmonkey
    Tribalmonkey
    Thanks ****. I did use a wire brush on my drill along with an array of sprays and scouring pads. IMG_5340.JPG IMG_5339.JPG
    Tim, Aaron D., drdave and 5 others like this.
  7. Tribalmonkey
    Tribalmonkey
    Wire brush on a drill along with an array of spray cleaners and scouring pads. Easy? IMG_5339.JPG IMG_5340.JPG
  8. Tribalmonkey
    Tribalmonkey
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Your build is really coming together! I'm loving all the speed equipment. As far as the choke cable mount goes, I was thinking maybe this one from Stromberg would work? I was considering running it on mine with a cable. Or I may just fab one up myself instead.
    That being said, it doesn't get very cold in my part of the world and I'm not sure how necessary a choke will be. 9552K-B.jpg
    You can find it in the "Other Parts" category here
    tb33anda3rd and lothiandon1940 like this.
  10. Tribalmonkey
    Tribalmonkey
    Thanks Joey. I already ordered this one. I get a four seasons here in MD. IMG_5343.JPG
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    That's really neat with the Edmunds name on there. I might have to follow suit!
    Tony Martino and lothiandon1940 like this.
  12. Tribalmonkey
    Tribalmonkey
    Comparison between stock head and Snyder’s 5.5:1.
    Premium head gasket B-60551-M
    Tim, Stogy, greasemonkey54 and 2 others like this.
  13. tb33anda3rd
    tb33anda3rd
    be careful torquing the front two bolts. the water necks tend to crack.
    Stogy, loudbang and Tribalmonkey like this.
  14. tb33anda3rd
    tb33anda3rd
  15. How dare you build a hot rod while enjoying it.
    That’s impossible
    Tribalmonkey, Tman and Stogy like this.
  16. Tribalmonkey
    Tribalmonkey
    We’ll see. I’m trying to get my manifold studs out without breaking them. So pause the fun for a bit. Haha!
  17. Tribalmonkey
    Tribalmonkey
  18. Tribalmonkey
    Tribalmonkey
    Tim, Rolleiflex, Stogy and 5 others like this.
  19. Tribalmonkey
    Tribalmonkey
    Tim, Stogy, greasemonkey54 and 6 others like this.
  20. Tribalmonkey
    Tribalmonkey
    More progress made this evening. Hard to tell from the pic but I installed the FSI 2 distributor and coil. I also did the first mock up of the fuel line from the firewall to the carb. Began work on the ‘behind the scenes’ fuel line and pump placement. I’m enjoying the fuel line work. It’s a bit of creative fabrication. IMG_5375.JPG
    Tim, Stogy, drdave and 5 others like this.
  21. Tribalmonkey
    Tribalmonkey
    Quick question - While I had my valve cover off I cleaned everything including removing and cleaning the oil pump gear. After I ****oned everything up and adding the new FSI distributor I am questioning whether I screwed up the ‘clocking’ of the distributor shaft. Is it possible that I put the oil pump gear back in 180 out? I am still working on the fuel lines and fuel pump placement... so I haven’t attempted to start it yet. How can I be sure my distributor clocking is set correct?
    Stogy likes this.
  22. Tribalmonkey
    Tribalmonkey
    A few pics of the distro at TDC.
    anthony myrick likes this.
  23. Tribalmonkey
    Tribalmonkey
    I called FSI and got my questions answered. First we identified that I had my firing order incorrect. I had 1,2,3,4. Should be 1,2,4,3. Other than that I could run the distributor how it’s positioned but I can also pull the rotor and reposition the ‘T’ 180 degrees to get my wires closer to their ***ociated plugs. I plan to do this. I’m still finalizing the fuel lines and fuel pump installation so I’m not ready to try to start and set the timing and carb yet. However, I am getting close!
    drdave, Stogy and greasemonkey54 like this.
  24. Tribalmonkey
    Tribalmonkey
    Tonight I flipped the FSI distributor cam 180 degrees, corrected my plug firing order, installed the Holley electric fuel pump and Holley fuel pressure regulator. I used more rubber hose than I initially planned. I still plan to replace some IMG_5420.JPG IMG_5416.JPG of the rubber with steel line at some point in the future. I also ended up placing the regulator on the outside of the firewall. That seemed to be the best set up even though my original plan was to keep the pump and regulator completely hidden. I also installed a kinetic/inertia switch for the fuel pump. I soldered and put heat shrink on all the connections. I installed a new manual choke cable and Edmunds choke bracket. I still need to install the original gl*** fuel filter bowl. I need to get one of my boys to help me since I need to tighten that fitting from inside the firewall while holding a wrench on the outside firewall side. I now need to find a muffler. I looked at tractor supply again but the ones they had in the diameter I needed were too big for my liking. I’m gonna keep looking. Maybe a gl*** pack.
  25. Tribalmonkey
    Tribalmonkey
    Last night I finished up the last few tasks, doubled checked everything, added a few gals of gas, and Pappy fired right up. Very satisfying considering all the removed/replaced and new parts. I thought for sure I would have some issues. Idle was steady and low. I messed a bit with the timing and air/fuel mix screws on the carb to try to get things dialed in a bit. I’m sure I will need to do more of that. I didn’t take him out for a drive yet. I’m trying to follow the break in procedure for the Snyder’s head. I only had a length of exhaust pipe bolted to the header. I actually like the way it sounded. I think I may just go a straight pipe to the back. The only issue I ran across was with the fuel regulator. It’s a Holley (12-804) 1.5-4 psi. My gauge was showing 1.5 psi. I could not get it to go up or down with the adjustment. That is pretty frustrating considering that 80% of the fuel line work was trying to find a good fit and placement for that regulator. I’m open to any recommendations to get the regulator working as expected. My target fuel pressure is 2.5 psi per Stromberg technician.
  26. Tribalmonkey
    Tribalmonkey
    I just spoke with a Holley technician. He believes I have a fuel pump pressure issue and recommended I check the pressure coming out of the pump by deadheading the pump with a gauge to see what I get there. I guess that is the plan for this evening. :)
  27. Tribalmonkey
    Tribalmonkey
    This evening I double checked the timing per Shawn at FSI’s advance setting recommendations for my head. I messed with the fuel pressure regulator but could only get 2 psi on the gauge. I went through the Stromberg 81 adjustments, re torqued all my head and manifold nuts and then went out for a cruise with my 13 year old boy.
    He said, “Dad now it looks and sounds like a hot rod.” It ran great and stopped great. I could certainly tell a difference in the power. Much more lively. I tack welded my exhaust pipe extension in place. IMG_5429.JPG IMG_5430.JPG IMG_5431.JPG
    Phase III complete.
    (Phase I was getting it running and stopping, Phase II was pulling the fenders and ‘trying’ to lower it, new wheels and tires, Phase III was Hop Up)
    My wife asked how many phases will there be. I said, good question. [emoji2]
    Tim, drdave, greasemonkey54 and 4 others like this.
  28. Tribalmonkey
    Tribalmonkey
  29. Tribalmonkey
    Tribalmonkey
    Tim, winduptoy, drdave and 6 others like this.
  30. Tribalmonkey
    Tribalmonkey
    Now I’m thinking about what I should do next. Interior? I already have a drop axle in the works with Okie Joe.
