Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Lloyd's paint & glass
    You're one bad mofo Lane!! Or crazy!! Not sure which one o_O
  2. mnjeff
    mnjeff
    Always wanted to try this, and my satin black, flawed, old daily farm truck seems like a good candidate....Fixed up Ma’s old Singer, got a stack of old denim to cut up, and we will see what happens.....
  3. I like that!
    Ben
  4. Harley32
    Harley32
  5. 57 Fargo
    57 Fargo
    My mom says I’m special...
    I put a clutch In my daughters Jeep at -20 a few weeks ago. Luckily my cheapness overcomes what little brains I have.[emoji2]
  6. X-cpe
    X-cpe
    I quit that when Uncle Sam cut me loose.
    jakespeed63 and 31hotrodguy like this.
  7. fastcar1953
    fastcar1953
    Kenny's done with chop. Before and after. 3 inches lower. 12 working days . 143492406_2897366697187593_1579669421358175794_n.jpg 147874006_2908386872752242_5519326545061505884_n.jpg
  8. topher5150
    topher5150
    mad mikey, LAROKE, reagen and 6 others like this.
  9. GlassThamesDoug
    GlassThamesDoug
    Started 30 Chevy in 20deg temps, to back it up so Morton Bldgs could install the 14 x 12 doors. She fired right up, 307 amazes me. Morton got stuck 3mi down road on a hill. 2weeks before this snow is gone.
    mad mikey, Lil32 and impala4speed like this.
  10. blowby
    blowby
    from Nicasio Ca
    Did a quick and dirty toe-in check..
    Recently did some front end work and set the toe with the usual gauge. Went for a ride, didn't seem right. Didn't have time to crawl under it last night but was curious so I came up with this, consisting of two old bed frame rails and 4 jack stands. Measuring just in front of the tires and again two feet forward should give the same result as measuring at the tires. Looks like it's toed in almost an inch, more than I usually screw up. I'll be checking it again the usual way but for a quick and dirty check I think this should work.
    mad mikey, Lil32, Stock Racer and 4 others like this.
  11. saltflats
    saltflats
    from Missouri
    Floor finished in the 62. :)
    mad mikey, hammer-time, rod1 and 7 others like this.
  12. classicdreamer
    classicdreamer
    from nyc
    Created a new trunk upholstery panel in my 38 outside in the wonderful 27 degree weather. Rewired and reset the location of the air ride in the car
  13. HarryT
    HarryT
    Converted '40 banjo rearend to open drive. Used Hot Rod Works kit. Beautiful kit, also HAMB discount. 20210212_132617.jpeg 20210212_132550.jpeg
    Sent from my LG-H700 using The H.A.M.B. mobile app
    40two, mad mikey, blowby and 10 others like this.
  14. High test 63
    High test 63
    IMG_20210209_212836251.jpg installed an lt-1 grind solid lifter cam and double roller chain on new roadster mill. New oil pump, pick up and shaft. Pan won't clear windage tray studs, dang,
    Back to the drawing board...
    mad mikey, blowby, LAROKE and 6 others like this.
  15. redzula
    redzula
  16. Lloyd's paint & glass
  17. Lloyd's paint & glass
    Can ya bolt the windage tray on and cut off the excess studs?
    High test 63 likes this.
  18. 57 Fargo
    57 Fargo
    I would
    Maybe not...does the windage tray bolt to the end of the studs?
  19. Stock Racer
    Stock Racer
    I got so frustrated with the studs I now only use pans with the tray bolted to the pan
    High test 63 and GlassThamesDoug like this.
  20. Elcohaulic
    Elcohaulic
    You guys checking front end alignment need to get four pieces of 12" x 12" 20 gauge sheet metal. Put wheel bearing grease on two of them and then sandwich the two pieces left over.. You should have two sandwiched together pieces of Sheetmetal. On a level floor put one under each front tire and bounce the car up and down a few times to get the suspension to relax. Now check your caster, camber and toe.... Don't be surprised if the new measurements are way off what the first couple of measurements were..
    I always put a little more positive caster on the p***enger side
    rod1 and jakespeed63 like this.
  21. High test 63
    High test 63
    kinda thinking that may be the way i go in the end, but am reconsidering my pan options now. I've got my eye on a 5qt vette pan that a buddy of mine has that I'd like to relieve him of, before I do any cutting or dimpleing. he just doesn't know it yet, heh heh heh...
  22. Moparmaniac79
    Moparmaniac79
    [​IMG][​IMG][​IMG]
    I got the head off to see what was living inside after 50 odd years of sitting and was pleasantly surprised. Managed to free up my rear axle and not break any lug nuts getting the extra rusty wheels off.
  23. Mike Miller
    Mike Miller
  24. Rocky
    Rocky
    Classified Editor
    12 below zero.....removed offending snow from my driveway and looked at my 50 Pontiac coupe waiting for some love from me. Sigh....too cold! housesnow2021.jpg
  25. roseville carl
    roseville carl
    installed a Halon system on the digger
    DSC02788.JPG DSC02789.JPG DSC02790.JPG DSC02791.JPG DSC02792.JPG DSC02793.JPG
  26. Stock Racer
    Stock Racer
    Compe***ion valve grind the old school way
  27. 33Doll
    33Doll
  28. SEAAIRE354
    SEAAIRE354
    Well after 4 plus years I finally got my roadster in the shop and started to mock things up. Don’t know how much time I’m going to be able to spend on it but at least it’s a start. IMG_2579.JPG
  29. jimmy six
    jimmy six
    Finished and installed a coolant recovery system made from a water bottle from the AAA. Posted on other threads. 3365FAB0-307F-4C41-AE3F-167A568B22F4.jpeg
  30. Lloyd's paint & glass
