Projects Blown 4 Banger (210 inch grenade)
Discussion in 'Traditional Hot Rods' started by nutrocker, Feb 7, 2021.
  1. nutrocker
    nutrocker
    It’s black and got a Ford in it, so guessing Ol’ Henry would approve.
    Pendine is 1/2 mile then speed timed between two points of 100 foot (I think).
    I’m aiming for over 100mph. Although that doesn’t sound too tough, it is. Getting the power down onto the sand and not making any quick movements isn’t easy.
    winduptoy, Stogy, Jet96 and 4 others like this.
  2. wulf powis
    wulf powis
    Very Impressive, great photos, way above my paygrade! Thank you for the details
    Stogy and loudbang like this.
  3. 48fordnut
    48fordnut
    In a word, Awesome.
  4. The Wrong-Un
    The Wrong-Un
    The timed area is 330' after the 1/2 mile run up.
  5. getow
    getow
    More than words can say. Simply impressive would be an understatement. I guess brakes will be da next act?. Your capabilities are outstanding. Hats off to ya.
    Stogy and nutrocker like this.
  6. set me on fire
    set me on fire
    wow awsome f######g awsome
    Stogy, nutrocker and loudbang like this.
  7. Are you nuts, hoses , bearings , hose clamps, and alloy parts and pieces, hopped up and blown, yes the car and our minds. Oh Yes, I bet the 97's still leak and blow gas in your face on occasion.
  8. 282doorUK
    282doorUK
    Just read all of this, what superb stuff!
    Dunno about you nutrocker, but I'm proper exhausted now!
  9. GlassThamesDoug
    GlassThamesDoug
    Thats a work of art.
  10. You have built one incredible banger! Awesome work!
  11. nutrocker
    nutrocker
    Thank you for all the kind comments
  12. roseville carl
    roseville carl
    Abso****ingbeautiful, is all I can say, you sir are in a cl*** all by yourself
  13. Jungle Jalopy
    Jungle Jalopy
    Dang! Rad T.
  14. 57JoeFoMoPar
    57JoeFoMoPar
    This could be one of the most ridiculously gratuitous displays of the "because I ****ing can" mentality I have ever seen...
    AND I LOVE IT.
    Hellbentrodder, Jrs50, chiro and 9 others like this.
  15. Smjacob
    Smjacob
    Just went through this whole build and I am in awe. Amazing work!
    I look forward to seeing more updates on this amazing Banger build.
    My son, my father, and I are planning our first banger build now. Your work is inspiring and intimidating all at the same time. [emoji4]
  16. exterminator
    exterminator
    Wow! Now that has to be my favorite 4 banker! Wow!
  17. Sporty45
    Sporty45
    Nice car, that :cool:
  18. Graham Thompson
    Graham Thompson
    I was impressed by your modified Pete but I am totally in awe of what you have done to this. Amazing doesn't do it justice.
    loudbang, Stogy and nutrocker like this.
  19. nutrocker
    nutrocker
    Thanks Graham.
    loudbang and Stogy like this.
  20. Stogy
    Stogy
    Across the Pond Excellence and then some...what a fantastic journey in skill, patience, mechanical design, pushing power envelopes and so much more that so many have touched on... @nutrocker thanks for sharing this masterpiece in Hotrod with the Hamb...;)
    Can't wait to see you give it a serious pedal pounding...pulverizing the Pendine Sands...I can't imagine that block would ever have dreamed being punched out like this one has...
    loudbang, Tony Martino and nutrocker like this.
  21. Rickybop
    Rickybop
    Nice job helping it to breathe.
    Really wanna see 'er run, nut.
    nutrocker, Stogy and loudbang like this.
  22. nuppi
    nuppi
    No words, just awesome, huh.
  23. chiro
    chiro
    There had better be forthcoming video of you screaming it down the beach. Just sayin' because I know we all want to see that. Lol
    Andy
  24. 56sedandelivery
    56sedandelivery
    Absolutely W-O-W!!!!!!! That's all I've got to say. I am Butch/56sedandelivery.
    nutrocker likes this.
  25. continentaljohn
    continentaljohn
    Awesome build and great skills and thanks for sharing
    loudbang and nutrocker like this.
  26. 41woodie
    41woodie
    Jeez, I get excited when I change the oil and the filter doesn't leak. Amazing skills and execution.
    Tat2Neil, Jet96, loudbang and 3 others like this.
  27. Ebbsspeed
    Ebbsspeed
    @nutrocker Stunning craftsmanship! Are you concerned at all about the oil pump hanging down so low, or maybe it just appears to be due to photo angles. Just in case a rock gets tossed into the pump drive and throws the belt, I'd consider a low/no oil pressure engine kill switch.
  28. Shawn Wildman
    Shawn Wildman
    Dang! Something you don't see everyday, which are the most interesting projects.
  29. nutrocker
    nutrocker
    It’s always a concern that something could knock the belt from the pump. The photos don’t show, but there is a pair of rings that fit either side of the pump pulley. These stop the belt from being able to come off the pulley.
    There’s always a risk with a setup like this, hopefully the worst won’t happen.
    The low pressure kill switch is an interesting idea. I do have an oil warning light mounted on the carbs directly in my eye line.
    Jet96 and loudbang like this.
  30. Ebbsspeed
    Ebbsspeed
    A friend of mine has an old gasoline powered welder that came from the factory with a low oil pressure kill switch. It uses basically the same pressure switch as the warning light you have, and is connected to the points side of the ignition coil. There is an override switch that breaks the circuit for starting. Flip the override switch, start it, when there is oil pressure flip the override switch back. If the welder loses oil pressure, the pressure sensor switch grounds the ignition coil and the engine shuts down. Pretty simple setup for the protection it can provide.
    Jet96, loudbang, nutrocker and 2 others like this.
