Technical Lowering the rear of 1932 ford
Discussion in 'Traditional Hot Rods' started by Ilari, Feb 14, 2021.
  1. Ilari
    Ilari
    I wonder how much I can lower the rear of 1932 ford with just changing the spring. I tried to turn the main leaf in press and left two leaves of the spring. It’s not tightened yet but did not seem to make much change to rear height. I know it’ll lower a bit when everything is tightened as they should be. IMG_5379.JPG
  2. da34guy
    da34guy
    Use a front spring out of a 40 ford with 2 leafs taken out.
    kidcampbell71 likes this.
  3. Primered Forever
    Primered Forever
    from Joplin,MO
    Remove a couple of leafs. Longer shackles.
  4. Model A Gomez
    Model A Gomez
    Doesn't look like you have enough weight to compress the spring. ***uming you are going to have a fuel tank in the rear, upholstery, maybe a battery get a 200 pound friend to sit in the trunk and see how much it comes down. When I built my avatar years ago I set the springs up with a bare shell on the frame and had to add leaves back with all the weight fenders and everything listed above was added.
    Ilari and Fordors like this.
  5. Fordors
    Fordors
    If he was to use a ‘40 spring that requires new spring hangers on the rear end, his ‘32 spring is curved and the spring eyes are not parallel.
    sidevalve8ba likes this.
  6. alchemy
    alchemy
    When I first built my tudor it started out with a couple leaves removed and a slightly flattened spring. After a few years I put the removed leaves back and flattened the pack a little more. Right now the ride is great, not much bottoming out, and it sits about two or three inches from the rubber bumpers. I use 48 Ford rubber bumpers because they are softer and cushion the impact more than the stock 32.
  7. Ilari
    Ilari
    I have a dropped axle in front, maybe 2,5-3” and I would prefer the rear to be down like 2-3” to compensate the dropped axle. I Don’t know if it’s possible only by modifying the rear spring. IMG_5381.JPG
  8. Happydaze
    Happydaze
    Possibly the main advantage of achieving that kind of drop by modifying the crossmember is that the spring characteristics can remain unchanged, meaning that the guesswork of spring rates etc is avoided. Worked for me. Is there a reason you're holding back from going that route?
    Chris
    Sent from my SM-T515 using The H.A.M.B. mobile app
  9. alchemy
    alchemy
    Try removing the third leaf up, and maybe the second from the top. And, it will settle more after you've driven it a hundred miles or so.
    Maybe the spring was from a closed car and has more leaves than a roadster would require. Just don't lose any of the removed leaves in case you need to put them back someday.
    All my adjustments were done with just a press, no cutting needed. Granted, my car is full fendered, but it sits a lot lower than your car does. And I don't even have a reversed main leaf.
    Ilari and adam401 like this.
  10. adam401
    adam401
    On my 34, which is the same curved spring mounted behind the axle scenerio ive got a couple things going on. First is I was using a 40 rear axle that has different spring perches. When I modified the 40 perches, I welded them on 1" lower than a stock 34 axle would have. I removed 2 leaves and lengthened my shackles an 1-1/4" all that got it so low I actually shimmed between the spring and crossmember 3/4"
    If I were too do it over again I would just flatten the rear crossmember the desired amount. I did just that on a 40 Ford I welded together and it functions well and uses all stock unmodified parts exept the crossmember obviously.
    Without having a spring made, or at least a main leaf made and the rest of the pack modified I dont think your gonna get the desired result with spring work alone. Just my experience bro good luck.
    My ride height for reference
  11. Ilari
    Ilari
    I’m quite sure it is from closed car. Does it have different shape than the roadster spring? Or just more leaves? How many leaves there is in roadster spring?
  12. Ilari
    Ilari
    That was the first idea, but the frame is really good and I just try to avoid cutting it. If I don’t get it sitting right with spring changes, I’ll probably change the rear crossmember and the rear axle too. I have a good 1935-36 axle and 1937 crossmember which I could flatten to get the right stance.
  13. alchemy
    alchemy
    I don't know the leaf count in closed vs open cars, but I'd guess the roadster has at least two less leaves.
    Drive your car a bit and if you aren't happy, you can remove the spring on a weekend and flatten it a bit more. Trace the arch of the leaves on a flat space and run each one through the press to remove an inch of arch. The same thing you did when you reversed the main leaf, except not as drastic.
    Ilari and continentaljohn like this.
  14. Happydaze
    Happydaze
    I thought you'd say something like that! I thought that about mine too, but the relative ease of getting the stance I wanted soon won the day!
    Chris
    Ilari likes this.
  15. HOTRODPRIMER
    HOTRODPRIMER
    I used a reversed eye 1940 Ford mono front spring under the rear of my Deuce pickup. HRP
    Ilari likes this.
  16. solidaxle
    solidaxle
    from Upstate,NY
    Are you going to run full fenders? The extra weight will bring it down some.
    Like alchemy said, start taking out leafs. A word of caution. I reversed the eyes on my 32 and had no trouble with the main spring. When I tried to flatten the second one from the bottom it snapped and went flying. Luckily it didn't hit me or something else.
    Ilari likes this.
  17. Ilari
    Ilari
    Did you change the rear cross member too?
  18. Ilari
    Ilari
    No fenders, I have heard that they might break when pressing, but my spring was not original anyway.
    tdog likes this.
  19. dirt car
    dirt car
    from nebraska
    I happened across a home made ch***is with a 32 spring that was heated & steeply bent on either end about 6" inboard of the shackle eyes, it appears to be well done & square with the side edge of the leaf however have not attempted a trial fit in anything as of date. Back in the day so to speak it was common practice to heat coils to desired ride height & in this case ***uming proper heat/cooling procedures were followed I'm still uncertain how metal quality might have been compromised.
    Ilari likes this.
  20. Deuce Lover
    Deuce Lover
    De-arching is another way.If you use longer shackle bars put in a panhard bar.
    Ilari likes this.
  21. clem
    clem
    how much is ‘some’
    would the weight of fenders really be noticeable ? I would be keen to know by how much ?
  22. solidaxle
    solidaxle
    from Upstate,NY
    I didn't measure mine when I removed the fenders so I could not say. It would stand to reason any change in weight would effect the ride.
  23. Ilari
    Ilari
    Do you have any tips where to de-arch the spring?
  24. alchemy
    alchemy
    De-arching is done evenly across the whole leaf. Originally the leaf should be close to a true arc (semicircle), and afterward it should just be a flatter arc. Trace each original leaf, and then re-arch it across the whole length to be one inch less. Or whatever you are shooting for.
    When I was doing mine I drew lines across the leaf every two inches. I started at one end and gave the press two pumps after initial contact. Then moved to the next line. Then the same on all the leaves. If you need more drop, then do the same in between the lines.
    Ilari likes this.
  25. Ilari
    Ilari
    Thanks
