**SOLD** 1934 Ford 5 Window
Discussion in 'Cars For Sale' started by BrandonB, Jan 31, 2021.
  1. BrandonB
    BrandonB
    from nor cal
    City: Citrus Heights
    State: California
    Price: $42,500
    Thought I would never sell it, but here it is for sale. Henry Ford steel registered and ***led as such. Pictures have been added of under carriage.
    If you're looking for a 34 belly****on 350/350, blah, blah, blah then just move on because there's nothing to see here, but if you're looking for a unique late 50's style hot rod then continue reading.
    1934 Ford all original steel, full fendered, unchopped, unshaved, unfilled and absolutely no rust. I also have the hood sides for it. You'd have to put blisters on them to accommodate the hemi heads. This started out as a father/son project back in the 60's. The person I bought it from was the son. When he was 13, in the 60's, his father brought home a 33 and a 34 and they took the best parts from both cars to make this one, hence the 33 body with 34 front clip sitting on a 34 frame. It was painted around 1970. 1981 it was taken apart and that's where it sat until I bought it in 2007. The last two pictures are of the car when I picked it up.
    Original re-chromed grill that's perfect and when I picked it up it still had the 1981 newspapers wrapped around the newly re-chromed bumpers. Windshield cranks out and the back window rolls down. It has almost new upholstery including the trunk.
    It's picked up a couple of awards at shows, Poorboys club pick at one and Mala Famalia club pick at the Sacramento Autorama, which says a lot about the car. You can tell by the bugs on the radiator that it does get driven, I just haven't driven it much in the past year.
    **SOLD**
    The following work was done. Most of it here in Sacramento at Blue Collar Customs.
    331 Industrial Hemi non-extended bell housing, w/Weiand Intake & 2x4's with C4 trans. Motor and trans came from a T-Bucket that was wrecked.
    34 Ford dropped axle from a 34 that was being "upgraded" to MII
    Early 50's Olds rear end with the trailing arms out of an old 40 coupe hot rod
    Lincoln brakes from Wilson Welding and Buick 45 drums.
    New wiring harness
    16" Lyons hubcaps that are nearly perfect
    Nearly new Excelsior-Stahl tires, 7.50x16 on the rear and 5.50x16 on the front. It has a 5 on 5 bolt pattern all around. I also have another set of wheels that are powder coated black. The wheels, both sets, are 1941 Studebaker which take the smaller inner circle beauty rings of which I have.
    Brockman Mellotone's for exhaust.
    If it sells to someone in California the rare 4 digit plates that are registered to the car can stay with it. If it's sold out of state then they stay.
    The videos were from last year or so.
    My 34.png 1934 Ford.jpg IMG_E8526.JPG IMG_E8533.JPG IMG_E8536.JPG 37BB02C1-3855-4479-BAAE-4CBC52FCD897.jpeg 116572C1-C08C-4F4D-A17C-B8E3AABAFA8A.jpeg 448B9B76-556D-4F08-865F-AFA019CE7951.jpeg A4017254-1BF1-437E-A5A8-5CB8721B062B.jpeg 614C4BAD-843A-419A-81B1-634B21321E54.jpeg EBE7D74C-5A0D-4A65-A10B-97E9858DD585.jpeg E3A3C8CB-EA70-4E88-9009-EE2AE7537336.jpeg 4B85BD5E-0305-42C2-AFDD-26D99341D83F.jpeg 59B3DBCA-AB45-45BD-9296-2809A2A5AFE0.jpeg 1934 @ Pickup.png 1934 @ Pickup #1.png
  2. BrandonB
    BrandonB
    from nor cal
    When I had whitewalls on it and pictures of the under carriage.
    34 W:Whitewalls.png
    34 W:Whitewalls2.png
    34#1.JPG 34#2.JPG 34#3.JPG 34#4.JPG 34#5.JPG 34#6.jpg 34#7.jpg 34#8.JPG 34#9.JPG 34#10.jpg 34#11.jpg 34#12.jpg 34#13.jpg 34#14.jpg 34#15.JPG 34#16.JPG 34#17.jpg 34#18.jpg 34#19.jpg 34#20.jpg 34#21.jpg 34#22.jpg
  3. BrandonB
    BrandonB
    from nor cal
    **SOLD**
