Projects Here we go again....My second '32 Coupe
Discussion in 'Traditional Hot Rods' started by TCATTC, Dec 14, 2020.
  1. 32partsguy
    32partsguy
    from DFW,Texas!
    Love a deuce ch***is build!
  2. clem
    clem
  3. saa
    saa
    from Sweden
    that is quick progress...
  4. 1-SHOT
    1-SHOT
    from Denton
    Did you bend up the center a member or is it a kit. Following your build, and like what I see
  5. TCATTC
    TCATTC
    I usually bend my own but I got lazy this time and bought one from Pete & Jakes. It saved me some time but I could have made it cheaper.
  6. TCATTC
    TCATTC
    A little plumbing today
  7. Chief 64
    Chief 64
    I am adding you to my list of people to pm when I need help on my 32:D
    You have some great skills and speed too!!
    Great job!!
  8. TCATTC
    TCATTC
    A little more brake line plumbing and a fuel line today. Got my panhard bar set up. 0214211453.jpg 0214211453_HDR.jpg 0214211453a_HDR.jpg 0214211454.jpg
  9. warhorseracing
    warhorseracing
    from cameron wv
    Man, if I were you I would cover the sending unit hole in the fuel tank. My luck is something would end up in there that I didn't know about and cause future problems.
    Don't take a chance on something ruining your hard work.
  10. TCATTC
    TCATTC
    Good observation. Note to self....install sending unit tomorrow.
    shortypu, Stogy, norms30a and 2 others like this.
  11. warhorseracing
    warhorseracing
    from cameron wv
    At least tape it up like your rear end housing.:D
    Stogy, TCATTC, clem and 1 other person like this.
  12. oneratfink57
    oneratfink57
    from Wisconsin
    Now that’s what I call progress! Great work
    TCATTC and loudbang like this.
  13. a12
    a12
    Excellent work! Exactly what I’d like to do! I’ll be following along too.....
    cheers
  14. TCATTC
    TCATTC
    My progress slows down in the winter. No heat. South Ga ain't Canada but this makes my bones hurt. 0217211144.jpg
    This is inside at lunch, high 30's outside
  15. warhorseracing
    warhorseracing
    from cameron wv
    Yall need some heat down there. Crazy cold about everywhere and I am on my 9th Ton of coal here in mid February. I usually go through 12 Tons a winter so when this load is done we should be at Winters end.
  16. Jacksmith
    Jacksmith
    from Aridzona
    loudbang and TCATTC like this.
  17. TCATTC
    TCATTC
    Got my third member built last weekend
  18. TCATTC
    TCATTC
  19. Jacksmith
    Jacksmith
    from Aridzona
    Some brakes is right! I've got the same ones on my '39 and they work exceptionally well!
    loudbang, TCATTC and Stogy like this.
  20. pprather
    pprather
    Once the body is installed, will you be able to disconnect the fuel line, if you need to slide the tank out the rear to service sender, etc.?
  21. TCATTC
    TCATTC
    Good observation. I guess I will have to add a union ahead of the crossmember. Thanks
    loudbang and pprather like this.
  22. Tim_with_a_T
    Tim_with_a_T
    Dumb, 7:00 AM question but are those backing plates on the correct side? On mine the emergency brake hole (on the back side) point towards the front of the car.
  23. warhorseracing
    warhorseracing
    from cameron wv
    The more eyes the better. I am glad to see you finally covered the fuel level and pick up holes in the tank we discussed a while back. LOOKING GOOD!
  24. Jacksmith
    Jacksmith
    from Aridzona
    Pretty sure the primary shoe (smaller of the two) goes toward the front.
  25. TCATTC
    TCATTC
    Yes they are, I just stuck them on for mock up making sure everything fits. I will take it all back apart for painting. Thanks for every bodys comments.
  26. Tim_with_a_T
    Tim_with_a_T
    Makes sense. Great job on the ch***is by the way. I am watching intently and taking notes!
  27. TCATTC
    TCATTC
    And the progress get put on hold a few days
  28. grumpy65
    grumpy65
    Dare we ask how many s***ches...................:eek:
  29. TCATTC
    TCATTC
  30. Chief 64
    Chief 64
    Oh boy! When I see someone with your experience get hurt it really opens up my eyes as to how fast it can happen:(. I hope you heal fast and can get back at it!!!
    TCATTC likes this.
