Hot Rods Did you use your car's original frame or use a reproduction of the original one?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Feb 3, 2021.
  1. willys36
    willys36
    I know it is implicit that this thread is about Phords but I'll comment about my '36 Willys Coupe. Used the stock frame. Cut out the X-member and used it to weld into the outer rails as boxing. Added a rear X-member from a '56 Oldsmobile and a 2" square tubbing X-member as a rear ****** mount for my Hydro. Has worked fine for 50 years.
    HOTRODPRIMER and bchctybob like this.
  2. hotrodA
    hotrodA
    My old survivor 32 still has the original frame with a 34 x-member and 34 rear crossmember, which lowered the rear.
    HOTRODPRIMER, bchctybob and 2deuces64 like this.
  3. Binger
    Binger
    from wyoming
    I built mine from 2x4 3/16 box. I used an aftermarket 32 front cross member and a stock A rear cross member. I also built the bolt in cross member to support the T-5.
    HOTRODPRIMER, bchctybob and ss34coupe like this.
  4. Blake 27
    Blake 27
    I found better pics of my Ray Zarick built frame. DSC06094-1.JPG DSC06108-1.JPG DSC061171.JPG
  5. Roothawg
    Roothawg
    I either build my own or use Henry’s.
    HOTRODPRIMER likes this.
  6. ss34coupe
    ss34coupe
    I like using original Henry frames but here is one I am putting together that uses repro rails with stock x member and crossmembers. The original rails needed too much work to save, but for some reason the rest of the frame survived without any problems. IMG_0692 copy.jpg
  7. DosCoupe
    DosCoupe
    I used original cross members and Just a Hobby deuce rails. The rails that came with my car were too pitted and rusted. Since I had to get a bonded state ***le. The rivets on a stock deuce frame would seem to result in rust and stress cracks.
    Some of the requirements in Canada make it difficult to use modified frames because of safety certification requirements.
    Sent from my SM-J727U using The H.A.M.B. mobile app
  8. bchctybob
    bchctybob
    I built all of my cars with original Ford frames with various levels of modification except my ‘31 2 dr sedan. I was swamped at my shop just after I started to build it so I had SAC in Orange County build me a roller using my front end. It was six months late and about 30% over the quote but it was all TIG welded and very nice. They wanted to see the original frame then they transferred the numbers onto the new frame. I still have the original frame.
    The Model A coupe I just bought has a nicely done stock frame with all P&J add-ons, again all TIG welded. That was a big factor in my decision to buy it.
