Projects My 1935 Ford Five Window build.
Discussion in 'Traditional Customs' started by emil, Jan 11, 2021.
  1. zz29
    zz29
    Fantastic build sir and you are moving fast! Fun to watch.
    Stogy and emil like this.
  2. emil
    emil
    from sweden
    Today I started off by making a dimple tool to countersink my body bolts into the floor.
    IMG_1304.JPG F6633936-8766-4A88-95B3-C9C461BF623D.jpg 7DAF8FDC-CFE9-4FFC-BAE8-6A318F4339B6.jpg
    Then I made the panel of the other side
    D2BBD9A9-FE87-45B0-8666-5C4A3F19374D.jpg 5EE5C6A7-7932-4F4F-8DE8-035D65D5A398.jpg
    Then I found that I had no more sheetmetal in my shop so I had to run some errands and buy some more.
    Turns out having a girlfriend who likes legos is a huge advantage when building cars..
    Made this which after a bunch of work ended up not working out anyways so I cut it up and made this
    These are the marks for me to put in my beads, I’m going to make the pieces for the other side and finish weld this before I roll the beads tho.
    Should be a good day tomorrow.
    Skickat från min iPhone med H.A.M.B.
  3. emil
    emil
    from sweden
    I got most of what I had on my agenda finished up today.
    Closing in and hope to weld everything into the body by early next week.
    Had some problem making the driver side floors, I don’t know how my brain malfunctioned but I ended up getting it finished on my second try.
    Tomorrow I have a double shift and then Sunday I should be able to get some more stuff done in preparations for welding it all into the body.
    Then next step after that is bolting it down and chopping the top.
  4. emil
    emil
    from sweden
    So today I managed to cut down this tall ol girl.
    First cut!
    IMG_1484.JPG IMG_1488.JPG IMG_1489.JPG IMG_1479.JPG IMG_5236.JPG IMG_5232.JPG IMG_5178.JPG IMG_1495.JPG IMG_1506.JPG IMG_5249.JPG
    Now it’s all cut down and ready to get back together.
    Hopefully I can get someone to help me lift it back on tomorrow, it was a bit of trouble getting off.
    Outback, chryslerfan55, Stogy and 8 others like this.
  5. oneratfink57
    oneratfink57
    from Wisconsin
    Floors came out awesome! Keep it up!
    Stogy, TrailerTrashToo and emil like this.
  6. brady1929
    brady1929
    Cool chop.
  7. emil
    emil
    from sweden
    First testfit to figure out where to cut it again.
    I want to avliden getting a ”hump” at the back of the roof so I’m going to look into leaning the rear of the roof to get a flow that close to mimics the flow of the rear of the car.
    Gotta spend some time planning it so I can make sure I get the look I’m after.
    Hopefully I start cutting on Wednesday.
    Outback, chryslerfan55, Stogy and 4 others like this.
  8. emil
    emil
    from sweden
    I want to avoid*
    Outback, chryslerfan55 and Stogy like this.
  9. edcodesign
    edcodesign
    Nice job, good luck !
  10. emil
    emil
    from sweden
    Today I cut up the roof and moved it around so I can start t******* and get everything in place.
    IMG_1598.JPG IMG_1604.JPG IMG_1606.JPG IMG_1614.JPG IMG_1615.JPG IMG_1619.JPG
    I cut the rear of the roof off, so I can move it up and lean it forward.
    I want to get rid of the hump at the back of the roof.
    Make it flow a bit better.
    It got a bit better than original, but I still feel like it has a bit of a bump so I will have to look into that later this week.
    Either I will have to accept it and leave it or cut and re-shape the entire back half of the roof.
    I only had a few minutes o look at it so hopefully it won’t feel as bad when I look at it tomorrow again.
    Outback, chryslerfan55, Stogy and 9 others like this.
  11. Leadslingingmerc
    Leadslingingmerc
    Looks awesome!
    emil likes this.
  12. emil
    emil
    from sweden
    Thank you! The fun starts now.
  13. 2NDCHANCE
    2NDCHANCE
    You have some serious skills. Awesome job. Cant wait to see your progress. Gary
    emil likes this.
  14. emil
    emil
    from sweden
    Thank you!
    Just got everything in place so now its onto trim and weld it in place.
  15. emil
    emil
    from sweden
    So after almost a full day of just moving stuff around I finally got it to where I want it!
    Ended up taking another in out of the back and narrowing the roof about half an inch (might take more if needed) to get the flow I was after.
    I also ended up trying to mimic the body line with the flow-in of the bottom of the rear window.
    Made sense when i got it into place.
    More of a streamlined profile and no hump!
    IMG_1667.JPG IMG_1671.JPG IMG_1669.JPG 15C40774-DE4C-42D5-B114-9BEE63AD3D40.jpg
    Got my picture taken by my girlfriend too, was so focused I hardly even noticed she was in the garage until I saw her leave again.
    Sorry about the mess! I need to clean up this weekend, but I also had to repair the whole upper part of the windshield because it was all rotted. Turned out nice I think.
    So this weekend I hope to be able to start t******* everything down and weld it in place.
    What do you guys think? Did I **** it up or is there more people out there who dislikes humpback roofs? [emoji1]
    Outback, chryslerfan55, brEad and 3 others like this.
  16. emil
    emil
    from sweden
    Here you can see the difference, with the yellow tape is from before and the other is how it ended up.
    Outback, chryslerfan55, brEad and 6 others like this.
  17. Chief 64
    Chief 64
    The new roof line flows very well!! Great job!!
    Where did you learn your sheet metal skills? Your profile says you do tattoos for a living. Is your second job at a sheet metal shop?
    emil likes this.
  18. emil
    emil
    from sweden
    No, self taught.
    Just been reading articles, watching **** on YouTube and obsessing. [emoji1]
    I’ve built some cars in the past but these are the first complete floors I’ve built and this is my first chop.
    I’ve repaired some stuff and built trunk floors before but nothing like this.
    I just have my vision of how I want it to look and since I design stuff for a living I have a fairly good eye for where and how to move the metal to get there.
    Thank you!
    I figured my real strength was in building ch***is but maybe not. [emoji1]
    I have a second job selling tools at a hardware store but just a few hours a month usually, but lately a lot of people have been sick so it’s been full time for a while on top of running my business. Since February it’s been back to normal pretty much tho.
    Haha sorry for the insanely long answer but I’m tired and started rambling.
  19. RustyDogg
    RustyDogg
    Excellent fabrication work! Great project and thanks for taking the time to update between 2 jobs!
    Guy Patterson, Chief 64 and emil like this.
  20. emil
    emil
    from sweden
    Thank you!
    I mean, I try to keep busy.
    I want to drive it this summer so I’ll have to keep at it.
    It sometimes rains a lot in Sweden and my T-roadster gets really cold and wet [emoji1]
  21. RustyDogg
    RustyDogg
    I think you'll make it at this pace my friend.
    chryslerfan55, emil and Chief 64 like this.
  22. cvstl
    cvstl
    from StL MO
    Those lines are great..... chopped 5 windows usually look a little odd with the hump. Nice job!!!!
    Outback and emil like this.
  23. emil
    emil
    from sweden
  24. emil
    emil
    from sweden
    So today got some pieces done and nested.
    C-pillars and A-pillars are there just need finishwelding once everything is in place.
    Required some cutting to make it fit good.
    Started fitting the top of the door too, takes a while to trim it down til it fits good.
    There is still work to do on the front of the door.
    Hopefully I will have the door together tomorrow so I can start on the other side.
  25. emil
    emil
    from sweden
    Today its been more of the same, ****oning up the front of the doors and the p***enger side B-pillar.
    I also started messing with the radius of which I will round the corners of the doors.
    I think this is close to what I will do, tried a few different both smaller and bigger versions but if I went bigger I think it would be nicer to tilt the B-pillars instead and smaller just didn’t make sense.
    Next is to make a pattern for the window openings in the doors and make sure they match, then cut out the spot welds of the windshield and start adjusting and measuring everything so I get it right in the money.
  26. emil
    emil
    from sweden
    So I have been very busy with life this last week or so, lots of work and taking care of my family so they don’t forget who I am.
    I managed to sneak in a few moments here and there tho.
    Made a wood template for the window opening in the driver side door, so I could mimic the window as exactly as possible on the other door.
    Here you can see the blue light shining through where it is off.
    So had to bring away some more until it matched the profile.
    Also had to figure out how to fill the gap in the door post, it has a brace inside which I can’t get to and work with without cutting the door all to ****.
    So what I did was fill the outside piece first, all the way from the back of the brace and around, and the I payed the top of the door post in place and folded the outside over like original, then I will do a little angle piece and weld in to complete the brace and the extra material will be hidden by the felt in the top where the gl*** slides in.
    Didn’t take picture of all that but will post when I get back home again.
    reagen, lurker mick and chryslerfan55 like this.
  27. emil
    emil
    from sweden
    There was a fair bit of work on this, because the driver side door was twisted, so I had to work it over a bit to get it to line up.
    Here you can see I had to weld an angle iron to the top and pry it down, you can see I put the top part of the door in first here but had to cut it out again.
    So I spotwelded the outside first, the worked over this a bit and the used hammer and dolly (read sledgehammer and a large metal wedge) and pushed the back part up to match before welding up the rest.
    Seems like ol Henry didn’t plan on us cutting these cars up like this [emoji1]
  28. Just.dale
    Just.dale
    Awesome work!!! You are a busy fella!!!
    emil likes this.
  29. cjtwigt
    cjtwigt
    Agreed.
    Awesome.
    Subscribed [emoji6]
    chryslerfan55 and emil like this.
  30. Fat47
    Fat47
    Really impressed with your fabrication skills. Between two jobs and raising your child it's a wonder you have any time to put in on the coupe. You also must have a very understanding girl friend.
