Hot Rods Traction Masters
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Feb 16, 2021.
  1. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Been looking at these... not sure if they are like the originals.... I have always heard the front tabs need to be welded on the frame...... Anyone have any 1st. hand experience with these... Looking and thinking about my 57 Ford.
  2. 325w
    325w
    I bought some for the 54 I had a few years back. But the ones I got located on the front spring mount. No drilling just bolts. I did this because I had wanted them years before on another 54.
    Don’t remember the company name. They were well made.
    Deuces and Jeff Norwell like this.
  3. DDDenny
    Jeff
    I built (and sold) ten sets of these in the 80's, I have a 67 Nova so the 62-67 was the primary application. This is a (somewhat) copy of an original used set I had found at a swap meet so don't know the application and yes, they are designed to clamp to the leaf springs as compared to weld-on bracket style.
    The rear attachment point (pivot) is a pair of brackets welded to the OEM spring/shock mount. They were for street driving so the need for (slight) movement was needed as compared to the limited movement of a drag car. This was accomplished by sandwiching 1/4" thick rubber stock on both sides of the spring and using lock nuts set just short of tight for movement over rough roads, etc.
    In applications like a Nova which is a monoleaf spring it is important to clamp them as close as possible to the front spring mount but on multileaf applications it is not as critical so if a person happens to find a set for something other than say a 57 Ford, a little adaptation is easily accomplished.
    Deuces, Jeff Norwell and elgringo71 like this.
  4. DDDenny
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Deuces, mgtstumpy and fauj like this.
  6. 325w
    325w
  7. 55blacktie
    55blacktie
    Jeff Norwell likes this.
  8. 55blacktie
    55blacktie
    Jeff, the bars in your photo are almost identical to what's been on my 55 T-bird for many years. They do bolt to the spring/shock plates at the rear, but the forward mounts are bolt-on. The front mounts, could be either bolt-on/welded to the frame. My bars and brackets were chrome, but I had them powder-coated 20% gloss black. They are Tractionmaster bars and pretty much the same as those used on Shelby GT350 Mustangs. My father was the 2nd owner, and the car has been in the family for approximately 50 years.
    Deuces, stillrunners and Jeff Norwell like this.
  9. 55blacktie
    55blacktie
    I ordered replacement bushings from Tractionmaster. The new bushings looked like they were polyurethane, but the originals were natural rubber. One of the bushings was too tight, which necessitated my using the best one of the original bushings in it's place. It was one of the few rubber parts on the car that didn't have dry rot. Tractionmaster is still in business in Southern California.
  10. Atwater Mike
    Atwater Mike
    A gent from Fremont (a mile from the old dragstrip) had a pair of the original authentic 'Traction Masters', complete with the gennie Motor Trends blue sticker...
    Garage sale, I spotted a nice 10" cast iron fry pan. Bought it, $2.
    I then saw the traction masters hanging in his garage. "Are they for sale?" He asked what I'd want 'em for.
    "54 Ford Coupe...406 FE, 3 on the tree, heavy top loader close ratio, 9" ****..."
    He said, "Please take 'em, as long as they're goin' on a Ford!"
    Gifted 'em. Cool.
    My bud Don Serventi and I 'bootlegged' Traction Masters in our Jr. year of high school, San Jose Tech.
    We sold no less than 60 pair in 2 years, out of the trunk of Don's '56 Chevy.
    I was also selling reversed steel wheels, great business!
    Budget36, Deuces, Joe Travers and 8 others like this.
  11. jnaki
    jnaki
    One of the nicest 57 Fords on the HAMB with Traction Master bars... great photo @POTATOTRUCK
    https://www.jalopyjournal.com/forum/threads/do-i-need-traction-bars.1200218/page-2#post-13686222
    Hello,
    We put on many original Traction Master Bars on our groups Chevy sedans. They were the original ones and at the time, no other company came close to the quality build and simplicity of the original. They were the bolt on kind for the street traction and looks. For our Chevy sedans, (55 post, 56 post, 57 Bel Air and even a 54 Bel Air, ) Traction Masters were simple and efficient for our cars.
    But, when we built our 1940 Willys Coupe for the street legal Gas Coupes And Sedan Cl***es in 1959-60, we welded on the original Traction Master Bars in front to the frame and then used the original set up with the rear axle using the supplied U-Bolts. Most of the street legal racers at the time were using the welding method, due to the tremendous horsepower sent to the back on full acceleration. The 56 Chevy rear axle set up was perfect for the original traction master bars.
    Jnaki
    After a lot of measuring and marking, I was given the first official welding job for the front bracket of the Traction Master bars. I certainly did not want to screw up the welding in front of my brother. So, I have to admit, he approved my final gas welding of those two front brackets and I was a proud teenager.
    http://www.tractionmaster.com/index.html
    upload_2021-2-17_5-17-16.png 1951 Olds sedan cruising in Long Beach, late 1957
    The one problem we had with Traction Master Bars was that once installed, they become the lowest part of the car, closest to the ground. So, when my brother lowered his 51 Olds Sedan in a California Rake, those Traction Master Bars s****ed the ground on some bumps. When the final springs were added, the angled rake was a little higher, but on the drive-in theater hills, we had to go sideways to get into the area where our friends were all parked. They did help the big Olds Sedan get good traction. YRMV
    51 Olds Moon Discs lowered Cal Rake 1957
  12. alfin32
    alfin32
    from Essex, Ma.
    Back when I built the ‘55, I was able to buy them from Traction Masters, and yes, they are welded to the frame.
    AHotRod, rod1, Deuces and 2 others like this.
  13. When welding the forward bracket to the Frame location is very important. You are technically making a 4 bar set up. Mount points must be correct in length and drop or you have a bind. Make sure what your doing is right for what you want. In other words you will have 4 pivot points, make sure you have them correct to each other.
  14. hemihotrod66
    hemihotrod66
    I myself would use Cal Trac bars....If they make something for your year of car...
  15. RmK57
    RmK57
    If you use Caltracs on a 57 Ford you have take a small slice out of the frame for the inside plate to clear.
    Not everyone wants to cut into a frame. I did and they work fantastic although not really traditional.
  16. Cheeta
    Cheeta
    Here is mine, 40 ford coupe with a 57 chevy rear end. traction master 1.jpg traction master 2.jpg
    AHotRod, GuyW, Shadow Creek and 4 others like this.
  17. jimmy six
    jimmy six
    Would love to have a bolt on set for my 56 Victoria. Admired them since the 60’s..
  18. 51 mercules
    51 mercules
    I wonder if that's what's on my merc that was built back in the 50's?
  19. 55blacktie
    55blacktie
    Genuine Traction-Masters will have M-1 cast into the bar ends. Currently, their website only lists weld-on bars, but mine are bolt-on. The front mount is triangular/w one hole utilizing the existing leaf spring front mount. A second hole had to be drilled into the frame. If I can figure out how to post a photo, I will.
    Joe Travers, Deuces and Jeff Norwell like this.
  20. DDDenny
  21. yellow dog
    yellow dog
    from san diego
    The single shear mount at the front was a constant failure point with any tire, otherwise
    geometry not too bad for a quick install (lots of antisquat).
  22. loudbang
    I bought a new pair direct from Traction Masters in 1967 and they did indeed have a front mount that had to be welded to the frame. That front mount was like an L shaped piece of metal with a hole in it. Not too strong I RIPPED one in half with a slightly OT 67Mustang fastback with a 390 4 speed and new M&H 7 inch slicks.
    Stretched the metal, literally pilled it apart no cracks just a clean destruction of the bracket.
  23. Joe Travers
    Joe Travers
    from Louisiana
    Have any of you cats tried to contact them recently? Don't have business hours listed on webpage and no one answering the phone. Sent 'em an e-mail, hoping someone will respond. Hope they didn't fold 'cause I need mucho help with a rare application. Thanks!
    Joe
    Deuces, Jeff Norwell and loudbang like this.
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I called a few weeks back and talked to a gentleman at the original Burbank location,.... ordered a set and he told Screen Shot 2021-05-24 at 1.54.48 PM.png Screen Shot 2021-05-24 at 1.55.01 PM.png he needed a week or so to build them... The send out by the mail service.
    All seemed good and I will report back when I receive.
    Jeff
  25. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Exactly..... My car is just a good overall street car..... not interested in slicing into the frame.
    fauj, loudbang, kidcampbell71 and 2 others like this.
  26. Joe Travers
    Joe Travers
    from Louisiana
    Thanks for the feedback, Jeff. Best time to contact now is after Noon, PST. They are hunting inventory for my application. Just relieved they are still in business!
    Joe
  27. MeanGene427
    MeanGene427
    from Napa
    I have an old unused set in the shop, going to take a look at them in the morning
    Deuces and loudbang like this.
  28. Pop Chevy
    Pop Chevy
    I run the McGaughys on my 60 Vette. With a set of heavy shocks, I have eliminated the severe wheel hop the car had . Mine are bolted in the front to the front spring eye. Running drag radials and getting some hard launches at the track cutting mid 11's.
  29. 1971BB427
    1971BB427
    from Oregon
    We built them in shop cl*** in high school by removing our spring plate and welding brackets on it for the tube. Then just made up a clamp setup for the front to clamp to the leaf spring just behind the spring eye. They worked great, and cost was cheap. Traction Masters still sells this clamp type option to avoid welding them on.
  30. tubman
    tubman
    Thanks for the posts, guys. I hadn't thought about "Traction-Masters" for at least the last 50 years.
    As I remember, they were one of the few things you could add to your car and still be legal to run in the "stock" cl***es under NHRA rules; they were considered "Safety Equipment".
