Hot Rods 40 ford front spring
Discussion in 'The Hokey Ass Message Board' started by olscrounger, Feb 19, 2021.
  1. olscrounger
    olscrounger
    I must be getting old! Usually I can take out a 40 front spring, remove or add a few leaves as needed and put back in maybe an hour or hour and a half max. Never have used a spring spreader-just jackstands, a floor jack a bottle jack and a couple of wood blocks-have done many. Not so this time! Took me an hour just to get it removed and maybe hour and a half to redo and put back. Found the shackle bushings very distorted from install. Had some extras and all good now.
    At 78 not as easy crawling around on the floor.
  2. i.rant
    i.rant
    Admire how you keep on keepin’on. :)
    J. A. Miller and lothiandon1940 like this.
  3. Theres no flat rate to beat if your at home.If you can still get down on the floor,and get back up at 78 your way a head of many.
  4. lothiandon1940
    lothiandon1940
    Keep pushing on, Tim. You're still a hero to a whole bunch of us '40 nuts out here.......Don.:)
  5. lothiandon1940
    lothiandon1940
    .............Just curious if the bushings were distorted just from wear or were the wishbones split at some point and the forward ends not heated and bent to correct the deflection?
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    You Did Beat The Flat Rate Considering If It Had Been Taken To A Shop The Kids Would Have To Find A Video On U-Tube To Explain How To Do It...Did That Help?.. Flathead_Suspension_1938to41pass-comm.jpg
    CME1 and lothiandon1940 like this.
  7. olscrounger
    olscrounger
    bones unsplit--just looks like bushings were maybe driven in. All good now I think. Longest it has ever taken me to do one though.
    LOU WELLS and lothiandon1940 like this.
  8. hotrodA
    hotrodA
    HA! Well, it would have taken the rest of us three times as long. At least.
    Hamtown Al likes this.
  9. olscrounger
    olscrounger
    All good--sits right in front now-just gotta decide what to do next-sweet fresh flathead, Columbia, trans etc etc 47K mile car restored a few years back and not driven. Nice black deluxe--if there was not covid it would have already had all running gear taken out changed over to 327 etc. Int gonna get a few tweaks this week and then chg wheels and tires out-currently red-going to black wheels, red striping etc then see where this one goes. Lockdown not fun
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    maybe since it has a columbia you could just adapt a 327 to the stock trans and save a bunch of work and money....
    lothiandon1940 likes this.
  11. olscrounger
    olscrounger
    THX Mark--have a line on a fresh 283 with adapters flywheel clutch starter etc
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    sounds like the makings of a sweetheart.....
  13. olscrounger
    olscrounger
    sits better--after wheel chg then maybe a touch more in back--about like the CMG std we did. Black wheels red striping with tiny V8 logo
  14. Atwater Mike
    Atwater Mike
    Just 'tasty'... '40 perfection.
