Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 33Doll
    33Doll
    Filled the old steering box holes!
    American side!
    And the British Side!
    Just gots finish the outside rail!
    Ran out .030 right in the middle of the job! Switched to .025 had to play with the settings several times, or I would got more done! But moving along Brakes all done a few more welds and Paint the frame!!!!
  2. dumprat
    dumprat
    from b.c.
    Looking good! I bet your excited to put the body back on.
    RICH B, 33Doll and loudbang like this.
  3. 33Doll
    33Doll
    Yup!
    I just got a weld a few capture nets, and finish the outside where those holes are plugged, then it’s paint!
    The front has already been rebuilt right before it was shut down, so I just have to clean it up and paint it and then reinstall it, then I just got a clean the rear end housing and take apart the leafs and clean and paint them put some new poly liner re***emble the rear end, and then it’s just a matter of re***embling the ch***is. Except for the plumbing part, but I got that nickel copper blend, so it ought to flare real nice, and Bend real nice!
  4. RodStRace
    RodStRace
    Get an extra length and use it to learn bending.
    I've heard here on HAMB and from people in real life that the copper blend stuff bends well by hand but is not as smooth when using tools.
    Oh, and ALWAYS double check that the fitting is installed BEFORE flaring! :D
    Stogy, loudbang and 33Doll like this.
  5. To paraphrase Dolly Parton—it costs a lot of money to look this trashy. Do what makes you happy. I have a patina paint job on my ‘33 and I never have to cringe when I hear a rock hit or some one sets a beer on it.
  6. Shiny paint is way overrated IMO.
    Stogy and 33Doll like this.
  7. 33Doll
    33Doll
    Finally Finished the holes, also went back and built up the low spots on the inside patches!
    Flipped her over, gonna weld the capture nuts tomorrow, then wipe her down for paint!
    Getting Excited!
    IMG_1389.JPG IMG_1390.JPG IMG_1393.JPG IMG_1395.JPG IMG_1397.JPG IMG_1399.JPG IMG_1401.JPG IMG_1402.JPG IMG_1405.JPG IMG_1407.JPG
  8. 33Doll
    33Doll
    Jim Bouchard, brEad, loudbang and 4 others like this.
  9. 33Doll
    33Doll
  10. 33Doll
    33Doll
    Now we getting Somewhere!!!
    Love that industrial paint but Boy is it Messy! And it tacks
    Pretty Quick! But it self levels if you do it right! I got some runs and
    ****, but oh well! It will never rust again!
    IMG_1418.JPG IMG_1419.JPG IMG_1420.JPG IMG_1421.JPG IMG_1422.JPG IMG_1423.JPG IMG_1424.JPG
  11. dumprat
    dumprat
    from b.c.
    Great part is you can wet sand the runs and wax it up! Should look beautiful!
  12. roll of the dices
    roll of the dices
    Looking good!
  13. 33Doll
    33Doll
    Im not to bright!
    Did not even cross my mind that the paint would go through my clothes!
    The wife had to put on rubber gloves and scrub my Back and **** cheeks with paint thinner! Lol!
    AHotRod, brEad, loudbang and 2 others like this.
  14. Stogy
    Stogy
    :rolleyes:...Hamber @Rocky will certainly relate to that...:D
    kidcampbell71, loudbang and 33Doll like this.
  15. Rocky
    Rocky
    Classified Editor
    AHotRod, brEad, kidcampbell71 and 3 others like this.
  16. Stogy
    Stogy
    Better than hot slag in the bag...:D:p
    Truly we wear what we use eh!! Hope you fellas cleaned out your fingernails this weekend for your sweeties eh!!:p
    brady1929, 34 5W Paul, brEad and 2 others like this.
  17. Rocky
    Rocky
    Classified Editor
    Slag in the bag,,heh heh.....My photo was taken a few years ago while taking chemo...lost all my hair for awhile. It came back even stronger and it's dark brown instead of the gray it had been. Strange.
    34 5W Paul, loudbang and Stogy like this.
  18. Stogy
    Stogy
    It started through an open shirt rolling molten metal is scary...paint ****s too, sealants in hair...Rocky your a good sport hope things are going okay your way...getting old is a journey no matter who we are...varsol isn't Oil of Olay neither is paint...:eek:
  19. 33Doll
    33Doll
    Man I wish you guys could see how smooth this paint turned out after it’s settled and cured! If it wasn’t for the frame having all these pits and factory flaws it would be perfectly smooth like gl***!
  20. Stogy
    Stogy
    :rolleyes:...A pretty sizable Milestone...big pat on the back on that 33...ewe...paint...:D
    Seriously you're a really motivated Hamber...you could bottle that energy and sell it by the pound...;)
    Go @33Doll Go...
  21. 33Doll
    33Doll
    Thanks!
    Hopefully if there aren’t to many regular boring life interruptions this
    Weekend maybe I can get rear-end housing cleaned, drilled and weld a drain plug in, maybe paint??? Then While it’s drying... take apart the rear spring, clean sand, and round the edges
    Of the leafs, for less binding,
    And new poly...
    We will see... Regular chores always get in the way!
    Now that I got the new 33 Doll plates...
    I’m going to
    “attempt” for the fourth time to go to the DMV tomorrow, and finally get that ****er in my Name!
    Pray for me!!! (Especially my at***ude!)
  22. Stogy
    Stogy
    Plates look spiffy...always admired that color combo...yes good luck at the DMV
  23. 33Doll
    33Doll
  24. 33Doll
    33Doll
    YAAAAYYYYYY!!!!!
    Finally!!!! In My Name!!! With.
    The 33’ Doll plates!
    I actually like the black and yellow is better than the original blue and yellows from the 70s anyway!
    (I can finally exhale though when the pink slip actually shows up in the Mail!)
  25. 31Apickup
    31Apickup
    loudbang, Stogy and 33Doll like this.
  26. 33Doll
    33Doll
    Yes sir! And I can’t believe I got to see the same gal again to help me the first time I just showed her the plates and she remembered me from last year!!
    For all of you out of California that’s like unheard of to see the same person!
  27. brEad
    brEad
    Congrats getting it plated!
    loudbang, 33Doll and Stogy like this.
  28. 33Doll
    33Doll
    Frame is all done, and set up for ***embly!
    Just gotta clean/rebuild the rear-end!
    ( Which will be easy bought all new guts!) then clean and paint the front
    End. ( it was rebuilt right be for it was shut down in 95’ I actually did most of it, if I recall? I know I did the spring.
    And reamed and replaced king pins,
    Honed, the old wheel cylinders, they are shot now. Funny how
    These things slowly come back to me.
    I remember rebuilding the spring specifically rounding the edges, and putting a little taper on the bottom side so they don’t dig in, using the poly.
    Wow 95 was a long time ago!
    Doesn’t seem that long!
    Gonna do the same thing to the rear Spring.
    It also brings back memories of building models, just just life-size now LOL!
    IMG_1459.JPG IMG_1460.JPG IMG_1461.JPG IMG_1462.JPG IMG_1463.JPG IMG_1464.JPG IMG_1465.JPG IMG_1466.JPG
    I hope you guys have been enjoying this whole thing with me!?
    I tend to get sentimental, and ramble a bit sometimes, and post a ****load
    Of pictures! Sometimes I get off track a little bit, but it always comes back to this car!
    Peace!
    -Rick
    tb33anda3rd, brEad, charleyw and 12 others like this.
  29. roll of the dices
    roll of the dices
    Frame came out really nice. That industrial Rustoleum has a nice finish.
    Are you going to use it for the rest of the suspension parts?
  30. 33Doll
    33Doll
    No, Im using dupliclor Graphite wheel paint, and a Duplicolor cast aluminum
    For a tu-tone effect. Although that rustoleum paint would be great for a truck to protect the underneath.
    Its thick, and
    Dries like porcelain. I’m sure have to s****e some of that were things bolt together cause it’s pretty thick
    But I know the frame will never Rust again in my lifetime!”
    brEad, loudbang, Jim Bouchard and 2 others like this.
