Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. RichFox
    RichFox
    Ripped off of Facebook. DOHC Ford V8 conversion. Anybody know anything about this? 151801495_1785800124921482_73203905186425084_n.jpg
    VANDENPLAS, alfin32, Fordors and 12 others like this.
  2. seb fontana
    seb fontana
    from ct
    Had to have a lot of faith in FH lower end, rods must have been crying...
    loudbang, Deuces, Thor1 and 1 other person like this.
  3. davidvillajr
    davidvillajr
    I'm in LOVE with this one. Buck Rogers/Flash Gordon powered hot rod coming right up!
    Phillips, loudbang and Thor1 like this.
  4. 34Larry
    34Larry
    My kid brother, (now 78) would have **** is britches over this. He had a RS/SS Camaro that he worshiped. (and me also.)
  5. sidevalve8ba
    sidevalve8ba
    2 stroke diesel, no valve train, it uses port induction and exhaust,18 cyliinders, 3 cranks, a pair of pistons in each cylinder,
    Apenaut, alfin32, jimmy six and 16 others like this.
  6. noboD
    noboD
    You better not lose the manual when you are setting the timing.
  7. Deuces
    Deuces
    Gotta be a tank motor.....
    Thor1 and loudbang like this.
  8. mgtstumpy
    mgtstumpy
    Commission by Jim Talbot
    Designed for and installed in Miss Rioco III (B-116)
    Designed by Leo Goossen (drawing 9098), built by Harry Miller
    260 bhp @ 6000 rpm
    • Designed for the 151 cu. in. supercharged cl***.
    • Miss Rioco III, a three-step hydroplane, designed by John Hacker. Sister boat to Sparrow (B-135).
    • Raced by "Richfield Ralph" Snoddy in the National Regatta in San Diego in mid-December 1928.
    • Removed from Miss Rioco III in summer 1929; Miss Rioco III re-engined with a supercharged Miller 91 marine (very similar horsepower output, but less torque) - to race in the International 1.5 litre cl***. With the new engine, Miss Rioco III won the York trophy races, and later that year, at Newport Beach, California, set an absolute speed record for the cl*** at 52.585 mph.
    • Thought to be lost, resurfaced in 1978, now fully restored by Lee Burkey.
    • Bore: 2.594 in.
    • Stroke: 3.5 in.
    • Valves: 2 per cylinder, 90o included angle
    • Camshafts: DOHC, driven by gear trains at front of engine
    • Crankshaft: One piece, counterbalanced
    • Connecting rods: Tubular steel, fork and blade style
    • Supercharger: 8" water jacket, duplex gear drive
    • Carburetion: One Miller updraft
    • Ignition: Bosch magneto driven by its own gear train at front of engine
    • Journals: Split
  9. mgtstumpy
    mgtstumpy
  10. RichFox
    RichFox
    Nope. I have owned 3 tank motors, This is a tank motor hotted up a little img89.JPG a GAA
  11. Deuces
    Deuces
  12. Phillips
    Phillips
    [​IMG][​IMG][​IMG][​IMG]
    Admittedly off topic, outside HAMB era, still cool.
    VANDENPLAS, alfin32, Deuces and 9 others like this.
  13. loudbang
    1910 universal T head
  14. Boneyard51
    Boneyard51
    There is a tool, some homemade that use “ baling “ wire to make hose clamps. It actually works good , compact , and will fit any size hose. I don’t have any pics of this tool, nor do I have one. But, in my career I have seen a few.
    Bones
    VANDENPLAS, Thor1 and Jet96 like this.
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Clamp***e
    You can make these too
  16. loudbang
  17. XXL__
    XXL__
    1959 2.0-Liter AC Ace Engine
    Currently at auction on Bring A Trailer. Lots of great history being discussed in the comments section. It was previously installed in the AC pictured by a PO. The current owner is reuniting the numbers-matching engine to the car.
    Aluminum block, cast iron head (seems like an odd combo).
    1959_ac_ace_1614271284eee9a0fc7b01496bb6IMG_2823.jpg 1959_ac_ace_1614273121bca76b9eee9IMG_2832.jpg Screenshot_20210304-140811_Chrome Beta.jpg Screenshot_20210304-140818_Chrome Beta.jpg Screenshot_20210304-140822_Chrome Beta.jpg Screenshot_20210304-140833_Chrome Beta.jpg Screenshot_20210304-140858_Chrome Beta.jpg
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'm guessing iron was used in the head to strengthen and stabilize the aluminum block and for better thermal efficiency properties.
    Neat little engine. That flywheel looks m***ive - I'll bet it idles well.
    chryslerfan55, Deuces and loudbang like this.
  19. seb fontana
    seb fontana
    from ct
    Vegao_O
  20. studebakerjoe
    studebakerjoe
    @seb fontana I was thinking that too as well as that Cadillac V8. I think HT4100?
    chryslerfan55, Ned Ludd and loudbang like this.
  21. jimmy six
    jimmy six
    Watching this shows one hell of a dead spot..
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  23. Jalopy Joker
    Jalopy Joker
  24. RichFox
    RichFox
    chryslerfan55, Jet96, LAROKE and 4 others like this.
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Does it read "SPIT FOUR"?
  26. mgtstumpy
    mgtstumpy
    DOHC Y-Block in South America, destroked
    Weslake Y-Block, again in South America
    Revised South America Y-Block, note the intake and exhaust port layout aka, SBF Windsor style. Firing order also changed.
    Revised Y-block fitted to early Falcon with new swept back exhaust layout.
    http://www.fordv8argentina.com.ar/diferenciasentref1f2.htm
  27. rusty valley
    rusty valley
    Back to the big ford GAA, it was in fact a tank motor. Early in the war the sherman tanks had a 9cly radial engine. They were expensive to build and maintain, and in real use required more than just a "truck mechanic" to keep them going. So, the gubment put out a call to the auto makers for a better solution. Chrysler came up with the crazy multy-bank, 5 6cly dodge motors on a common crankcase. they look wild, probably a photo in here some where. Ford had the GAA on the drawing board to be a v12 aircraft engine, so they chopped it down to V8 size and went into production. Late war shermans used them, and also the M7 gun motor carrage, which was basically a Sherman hull with a fixed 105 Howitzer instead of the rotating turret on top. I actually had one! Found 3 of them in Montana they bought surplus to be stripped and made into log skidders, but the fellow never got around to it. After the war it was up to the base commander to decide what needed to done to "de-militarize" the vehicles. Some commanders only removed the gun, and some, in my case, cut them up. Mine was cut across the center, and then the back half was cut in half again, so 3 parts to glue back together. I had it in the yard all blocked up and shoved together so we could play on it. I found The Ford GAA in a s**** yard in Kansas. It was mounted on a stand and used for an irrigation pump. It was all complete, still turned over, bought it for s**** aluminum price, about 400 bucks if i remember, this would be about 1990 or so. Finally some one wanted it more than me so i let it go. sorry, no pics, fire in 2010 took them all
  28. cavisco
    cavisco
    I think that deltoid design was used in Vietnam era Navy river boats.
    Deuces, Thor1 and loudbang like this.
  29. RichFox
    RichFox
    32 Plymouth with Y block head that predates mine by about 50 years
    You are right. Good eyes. The pictures came to me from Steve Jordan who now has the engines
  30. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I wonder why anybody would name their head "SPIT-FOUR"? Must mean sumpthin'to sumbody.
    chryslerfan55, Deuces, Jet96 and 3 others like this.
