History Cadillac Emblem or not?
Discussion in 'The Hokey Ass Message Board' started by pro1street, Feb 20, 2021.
  1. pro1street
    pro1street
    I found this today and wasn't sure if it was an actual Cadillac Emblem or not. It's about 4" wide and 2¾" tall. It has tabs on the side that don't look to ever been bent over. Material seems to be a thick pot metal. Any info. would be appreciated. Thanks IMG_20210220_161044734.jpg IMG_20210220_161100592.jpg IMG_20210220_161111707.jpg
    kidcampbell71 likes this.
  2. Definitely Cadillac but what year or what use I can't say. It looks like it was not made to be painted the usual Cadillac colors but left plain, maybe for an accessory box.
    It's probably stamped steel and zinc plated, though, because pot metal tabs would break not bend. Is it magnetic?
  3. pro1street
    pro1street
    No it's not magnetic. I'm like you I think it's for some kind of accessory add on. I figure it must be some kind of after market part since it doesn't have any stamping identification.
    The Shift Wizard likes this.
  4. FritzJr
    FritzJr
    It looks like it must be from around 1964
    dana barlow and pro1street like this.
  5. 61SuperMonza
    61SuperMonza
    With tabs like that I would bet it was an emblem for the interior. I'm thinking dash or door panel.
    pro1street and Dave Mc like this.
  6. Cadillac dropped the Merlettes (Ducks) in 2000 and redesigned its badging and got rid of the wreath in 2014
    And after looking at images yours looks backwards to the real one.
  7. squirrel
    Looks like an aftermarket knockoff, designed to be just different enough from the real one that they would not get into legal trouble.
    I have no idea what is was intended to be used for. Most likely something to put onto your plain wheel covers, or just to stick on the car somewhere to dress it up. Might look in a 60s-70s JC Whitney catalog and see if you can find it.
    X38 and 302GMC like this.
  8. pro1street
    pro1street
    I'd say you're right Squirrel.
  9. Frankie47
    Frankie47
    from omaha ne.
    There are no ducks on it........
    flynbrian48 likes this.
  10. ClayMart
    ClayMart
    The "crown" motif at the top of the emblem you have has only five "jewels" or spires. When Cadillac used this as part of their emblem it always seems to have seven jewels. Looks like an aftermarket "wanna-be" emblem.
  11. flynbrian48
    flynbrian48
    It's not a GM part, raw like that, and like Frankie47 points out, it's incorrect. Where are the ducks? There should be ducks...;)
    Frankie47 likes this.
  12. 54vicky
    54vicky
    I am in the aftermarket crowd.a real caddy part would never look like that (junk)
  13. lostone
    lostone
    from kansas
    Yep me too.... After market knock off. Looks to me like maybe for a hub cap.
    Maybe a cheap aftermarket hubcap set then you could buy your choice of centers to put on it maybe.
  14. Doublepumper
    Doublepumper
    from OR-WA, USA
    Badge for a pedal car....?
    egads likes this.
  15. HOTRODPRIMER
    HOTRODPRIMER
    Early Cadillac sombrero hub cap, it's similar but like Jim I think it's a knock off. HRP
  16. Key fob.
