Hot Rods Kohler Kustom shop projects photo dump
Discussion in 'The Hokey Ass Message Board' started by thunderbirdesq, Jan 12, 2020.
  1. thunderbirdesq
    thunderbirdesq
  2. thunderbirdesq
    thunderbirdesq
    some axle/spindle service, some under-the-bench Flathead eye candy, @louisb ’s 350 for his jimmy pickup finally coming together, and a pre-rebuild repair job on the halibrand 201 for my pal Jared’s restoration of the original bob hamke model t.
    0A5DE868-7355-4DA6-827F-D5F58A8D1A41.jpeg 8AA1B97E-C045-4E75-84E0-5A1BBA3C3B42.jpeg 92F5A5FB-4D6D-40C3-B83B-11C0FBF89240.jpeg 96323231-864D-40B5-B724-0A6C0E7EF6E7.jpeg C4250388-69C7-4643-AAB9-996C0CB06511.jpeg 315E3D71-64E8-49D9-B85B-01B5CFD5B905.jpeg 73CF67AF-3109-4B3F-BE18-DF10108547F7.jpeg E04FE8D6-2631-4CF8-9856-D2BF5028C806.jpeg 8A264029-FFCB-41B2-AA93-306E2F0A1826.jpeg
    Tim, 40ragtopdown, Anderson and 18 others like this.
  3. custom_lettering
    custom_lettering
    from Wall, NJ
  4. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes, I've never seen that repair before. Usually they are just built up with weld and then crack again. Looks like that case has had a hard life. Good on you for fixin' it right.
  5. Dangerousdan
    Dangerousdan
    from Arizona
    It looks like your going to be busy for a while. It's always great that you enjoy your work. You have a talent.
    Stogy, loudbang and thunderbirdesq like this.
  6. thunderbirdesq
    thunderbirdesq
    Thanks, it was torn up for sure. The pic next to the old welded/cracked support is actually a different center that I have to fix next. On this housing it was completely blown apart and 75% missing. I figure that this is the best way to make the strongest repair, also the machining is much easier to do on the new block prior to shaping and fitting, rather than doing it on the whole housing after its welded. Its a bit of a trick to weld around the inside of the pinion gear tooth chamber though! That last pic is before I pulled the pinion and fully welded the inside.
  7. thunderbirdesq
    thunderbirdesq
    Exhaust work on colts coupe, battery box, rear crossmember cover, more randoms, pats 33 chop is really starting to come around, prototype for a fuel block we’ll be offering soon.
    8C454B3C-3EC5-434F-BC03-230E67F19109.jpeg C397E884-4A79-480F-9896-44CEEC7CB037.jpeg 61B4B780-AED5-4D68-B250-B0AA7B97F532.jpeg 9479E5CD-279E-47BA-8564-833CE66EF0EE.jpeg 2D32639E-2748-49C7-8A7B-0527739DA084.jpeg 6840850A-8365-4DCE-8F04-58DF23F2D142.jpeg A15171C4-47A2-4A2C-B84D-B5B2828C39FF.jpeg 0F650073-E694-40CC-BA30-72DE697108FD.jpeg 99EFE70D-1088-4C09-B9D7-DE74433987B5.jpeg 008DB3A0-A970-40D5-AEAA-A9EE36E4A87B.jpeg 61FEE653-55B2-434B-88ED-DF2F5354088E.jpeg CAF96A3E-240E-44DF-AD6A-07BAA2F82AD9.jpeg AED0C4DD-E227-4E0F-8925-C86E30C3B62E.jpeg 6EEC605C-5EED-4C11-B9DA-CE0F105622A5.jpeg 72522888-CAEF-4CB1-A3FA-011A650AD883.jpeg 7CD88E80-8551-4B4C-8B41-825F3224F7AD.jpeg
    Tim, 40ragtopdown, alanp561 and 20 others like this.
  8. chopo
    chopo
    Stogy and loudbang like this.
  9. thunderbirdesq
    thunderbirdesq
    a couple coupes, making a 32 column lock work on an f1 box in an av8, fitting the gaps and fine tuning the details on pats 33, Traditional hot rod exhaust for colts coupe (we used two right side headers for some semblance of symmetry), Romeo’s 32 frame headed to paint... etc...
    7B8191F9-41DC-405D-BF24-DA81ED58345A.jpeg 0312B864-CBF3-4AC9-ABE6-CBABF54D9EE1.jpeg 5E2E2F88-848F-45E1-A8E2-C614860629C4.jpeg 2660AA4C-E9DF-4E6E-9FB6-F5406ADDCEF0.jpeg 836604F9-74E0-4578-9B56-FBAF34BD31EC.jpeg 376BA00A-1E93-4626-87C6-83B8D5BFCCCB.jpeg 8CC7A11C-7BB3-4C4C-8016-2DDCC3A752A9.jpeg 99ECD382-F09A-4BF0-B6BE-9353535A719D.jpeg F26147A8-E96C-4902-93CC-7744BC8C7B9A.jpeg
  10. vilanar
    vilanar
    from Finland
    Great Dump again !
    You have been busy , which is great....
    thunderbirdesq, loudbang and Stogy like this.
  11. Hollywood-East
    Hollywood-East
    Andy, Your offerings are one of my favorite post... Your kill'n it Dog! $
  12. thunderbirdesq
    thunderbirdesq
    Workin out some stainless lines and linkage for the pruned 371 induction setup...
    40ragtopdown, TomT, Stogy and 12 others like this.
  13. Just checking in.
    thunderbirdesq likes this.
  14. thunderbirdesq
    thunderbirdesq
    Working out the f1 steering on colts coupe, a he’s got one of our first fuel logs on his engine with some stainless lines too. Aged paint going down on romeos roadster ch***is, custom stainless stanchions for the molded cowl and a hard chop for #169...
    AAAEA107-6ADA-4B2E-9635-31E3C5766D8D.jpeg 6BC22CED-D0A1-4580-97C3-0D6F58418956.jpeg D907568F-B6E0-4C47-9D0D-7245D085A1AF.jpeg D4ACC308-7654-4EB0-A897-A80794FD1989.jpeg 95E6FE87-D981-4DC9-A78A-9F5F5121FA28.jpeg 157D4D59-3333-4119-B85A-8EFF36A6CF58.jpeg 1CA608CD-1699-4B4F-801D-7F6A5F17AB03.jpeg CF7D2DA5-203F-4EA5-807F-94D4534DAF93.jpeg F7A1E392-7688-4A29-BC68-5D2273AF835F.jpeg
  15. thunderbirdesq
    thunderbirdesq
    Hidden pcv port and baffle for the vintage cal custom’s on @louisb ’s jimmy engine, Sneaky peek at Brock’s supercharged sport coupe coming together, and some axle work, pushing the practical limits of a 32 drop blueprinted to replace a SoCal axle for rexrods, a couple for millworks and uncle Danny...
    6EBEFF1F-9B18-4571-8F96-8B0629A978C4.jpeg 9240F3A8-46AF-4E0E-A675-2AEAC5178B86.jpeg 7794E28A-BA52-46E8-BAEB-1811E2CD39FF.jpeg 9C6ACAC4-37EA-434A-B91C-D948E7D9968D.jpeg 9E8A32ED-9A89-4942-BCB7-13A2A51E01DE.jpeg 875D6BE3-85DB-44E1-87DA-448A639065D2.jpeg BA1CE1E5-81E5-477B-A59A-147609A5C3B9.jpeg 910A2B26-62E1-4BCB-84A2-277ABD645B59.jpeg 66F42AD0-3ED3-4458-B7E0-FF1EABD8FAEE.jpeg CCEE736C-9621-4C05-A65E-0CC5BE57A3A7.jpeg 9DB1F372-3578-452C-B53A-806F2C83E0AE.jpeg A73ACE85-A382-4172-9EBD-CF5DBD50D677.jpeg
  16. vilanar
    vilanar
    from Finland
    Beautiful work on those axles.. Thumbs up ! Both....
    thunderbirdesq and loudbang like this.
  17. thunderbirdesq
    thunderbirdesq
  18. louisb
    louisb
    That 40 needs some lettering. Maybe gold leaf.
    --louis
  19. Deadelvis2000
    Deadelvis2000
    from Austin, TX
    Your pics are a treat. Kinda like waiting for an Estrus 45 to show up in the mail in the 90's.
    Keep it up.
  20. rod1
    rod1
    Any new ones? Missing me some Esquire.
  21. thunderbirdesq
    thunderbirdesq
    Guess 2021 was a busy year or something…. C5C5E68D-A72A-43DA-BED0-6B7D43D585F5.jpeg 65D4DFE5-1417-41DC-90D6-B24DEB49C4CC.jpeg 9DE8242C-D80A-4276-BFDD-D1016EF5D9DD.jpeg 399440EC-88C6-4608-B980-50BAE43A9C24.jpeg ED7AECFE-BC91-475E-8A88-EC31D72D1A02.jpeg 10187E56-1240-4578-BDCA-9930B19CF6C1.jpeg E6B5BB8E-FD4B-44CE-80E3-BD20D43CA35A.jpeg 9A7F06B7-C289-4E4A-9FAC-4C50551D913B.jpeg AE3BD84F-1901-43B9-95F7-F8EE438DBFAD.jpeg 6F205774-03FF-4AAF-9598-0139FBA87115.jpeg
    emil, brEad, Stogy and 12 others like this.
  22. thunderbirdesq
    thunderbirdesq
  23. thunderbirdesq
    thunderbirdesq
  24. thunderbirdesq
    thunderbirdesq
  25. thunderbirdesq
    thunderbirdesq
  26. Sakke
    Sakke
    from Finland
    That is one Creative Shop !!! Great Work !!!
  27. thunderbirdesq
    thunderbirdesq
    Louis’ pickemup, somehow he talked me into a gm build haha
    AF74D482-D837-4D39-93C1-49DE622703C7.jpeg 9AAA4E27-0CDD-40A5-8E38-CDC808082E8C.jpeg 7D83C101-05D5-4854-9F85-532C3501944B.jpeg E6D7A823-9287-457F-A9E7-8A71A3B257B2.jpeg 3ECFEF8C-8965-4629-B327-701071E085E2.jpeg EBB6E01C-84C8-4EF8-831C-65D2EEB0F0EC.jpeg E0D5DA68-5293-4D01-98AA-CBFD574A1B74.jpeg 7B629F9F-4B28-4879-9E6A-7AFDAACF57F9.jpeg 73A154D5-0335-4074-9977-192222F119B7.jpeg 46EEF12C-EE30-4C33-B144-0E35E8F7DE5B.jpeg 311B4E54-A274-4D80-A688-2891836309F2.jpeg EF05CB35-DE48-4F70-A36D-BE6FA9442646.jpeg
    wagoon78, brEad, Stogy and 11 others like this.
  28. thunderbirdesq
    thunderbirdesq
  29. Joe Blow
    Joe Blow
  30. TomT
    TomT
