Hot Rods 303 Olds clutch problem
Discussion in 'The Hokey Ass Message Board' started by Lockjaw, Feb 21, 2021.
  1. Lockjaw
    Lockjaw
    I have a 303 motor ,aluminum flywheel and Muncie 4speed. Cutch was for a cad lasalle trans .the clutch is large Ford ( early Ford style) I would like to use a hydraulic throw out bearing but the one that fits the Muncie isn’t big enough dia. To work! Suggestions other than re-drilling flywheel would be welcome. E985F8FE-2647-4199-ABF2-7E1BD8B21051.jpeg 08DBA714-14FD-40CB-A0DE-5AF2DF417E5A.jpeg DFD60BE4-48E9-4AFF-8D62-7CC75D7481D2.jpeg 62E0F0D1-F5CB-4FE5-BD86-6174B864DDE8.jpeg
  2. 19Eddy30
    19Eddy30
    from VA
    Make a ring ( washer ) 3/8 thick may be thicker (1/4) to go from throw out bearing size to Pressure plate finger / lever,.. sometimes you have to think outside the box & experiment!!
  3. Or redrill the flywheel and use a GM pressure plate.
    Nailhead Jason and ottoman like this.
  4. Lockjaw
    Lockjaw
    it's aluminum and not re-drillable.GM pressure plate different bolt pattern so solution I ***ume is going to be in the throw out bearing. On the washer it's a wear area so I don't think it would survive. Hate to get a new flywheel but I might have to
  5. ottoman
    ottoman
    from Wisconsin
    Why is it not re drillable? Is it too thin where the chev pressure plate holes need to be? I have redrilled aluminum flywheels but never a 303... picture of the engine side of the flywheel?
    Budget36 likes this.
  6. Bert Kollar
    Bert Kollar
    A hardened washer should work
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Maybe it would be easier to get a clutch fork and an early ford throwout bearing. If you must have a hydraulic clutch you could just put a slave cylinder on it. This setup would be far more serviceable in the event of future hyd failures as you would not need to remove the trans to repair it
    Tim, triumph 1, 19Eddy30 and 3 others like this.
  8. RichFox
    RichFox
    You could look for a hydraulic throw out bearing that is large enough to fit the Long type fingers, Then see about adapting it to the setup you have. When I had the same deal without the hydraulic deal I had to make a br*** bushing and press it into the bearing to make it fit the collar shaft.
    Pist-n-Broke and Tim like this.
  9. Nailhead Jason
    Nailhead Jason
    I won’t use another hydraulic throw out like those. I’ve had Nothing but problems with that style. I’d do like @Moriarity said and use a early for fork and throw out bearing hooked up to a slave cylinder. When the hydraulics need work for the clutch, you don’t have to mess with pulling the trans or motor out.
    37slantback and Moriarity like this.
  10. 4ty
    4ty
    Above is the way to go. I had a 32 5W I put a 55 Olds engine in, 11" ford pressure plate with a 10 1/2" disc mated to a 39 trans and used a hyd slave cyl. No problems. P/Plate bolted right up to the Olds std shift flywheel. All info obtained from the "little" books back in 1961.
    Paul in CT
  11. Rocky
    Rocky
    Classified Editor
    Whatcha building, Jaimie?
  12. Budget36
    Budget36
    I was thinking the same thing.
  13. speedshifter
    speedshifter
    Liston to Moriarity & Nailhead Jason. Outside hyd. cyl is more trouble free, simple to repair or replace. Greg
    Nailhead Jason and Moriarity like this.
  14. Budget36
    Budget36
    My reply was why the fly wheel could not be redrilled.
    Do you have insight on that ? The PP looks to sit way outside on the edges, so maybe no meat there?
    Anyways, that is what I was wondering:)
  15. Lockjaw
    Lockjaw
    IMG_3459.JPG IMG_3463.JPG IMG_3475.JPG Thanks for all the replies. This car is the last to use up some of what is still sitting around that I didn’t have the heart to sell off. Car is a fibergl*** cobra body Ford dropped axle 471 blown 303 olds Muncie 4 speed and quick change rear. Only problem so far has been the clutch. Motor has a really nice aluminum flywheel and I sold off the stock flywheel . Using a slave cylinder is going to make the most sense but take up some room. Thanks for input now on the hunt for a flywheel.
    Tim and cactus1 like this.
  16. Lockjaw
    Lockjaw
    Here is a picture of back side of flywheel. Should have shown this in original pictures View attachment 4986870 View attachment 4986870
    Nailhead Jason, Tim and Budget36 like this.
  17. I've heard a picture is worth a thousand words.
  18. vtwhead
    vtwhead
    Compact bracket and a 60's GM truck slave won't take up much room fwiw:
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    You might consider one of the many clutch cables available ..
    Tim likes this.
  20. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Don't know if you ever got the answer you need, but I saw this in an old (1971) book I had.
    Tim likes this.
  21. Tim
    Tim
    from KCMO
    Whoa that’s gonna be nuts!
  22. vtwhead
    vtwhead
    Any updates on this? I see that you have a clutch/flywheel in the cl***ifieds....:rolleyes:
