Technical Quick change onto Model A rear end
Discussion in 'Traditional Hot Rods' started by neds29, Feb 21, 2021.
  1. neds29
    neds29
    Is it practical or even possible to install a quick-change onto a stock Model A? I'm thinking of a Model A with a flathead and '39 transmission along with juice brakes but still running a stock rear. And yes, I know the rear is weak and I'd have to be careful. Or does it have to be swapped out for something '33 or later?
    Sorry for what may be a stupid question but I'm stuck at home and dreaming.
    Ned
  2. alchemy
    alchemy
    Sure you can do it. Only weakness is an unsupported pinion, but many have been used in sprint and race cars for decades.
  3. Yes, there are Model A specific quick change centers just like the ones for the V-8's.
    Outback and gimpyshotrods like this.
  4. sloppy jalopies
    sloppy jalopies
    remember that the '32-'34 rears were spaced closer to the housing as the springs were "bowed"...
  5. alchemy
    alchemy
    The Halibrand center for a Model A and B is a model 101. The V8 model was known as a 201.
  6. fourd
    fourd
    from Colorado
    Kiwi Quick Change for Model A is what I have.
    Check past posts and I see a FB page. 40ADC4D8-9CA3-4524-B4A1-191D59BFED55.jpeg
  7. neds29
    neds29
    "Sure you can do it. Only weakness is an unsupported pinion, but many have been used in sprint and race cars for decades"
    Thanks to everyone who responded. I'm unsure of what an "unsupported pinion" is? Or why the Model A rear is different than any other car. Can you explain pls. Thanks.
  8. jaracer
    jaracer
    An unsupported pinion doesn't have a bearing past the gear, just bearings on the input side.
  9. klawockvet
    klawockvet
    I would have no fear of a mild flathead running through a model A rear end on a street machine being driven with some restraint. Many of us old guys beat the living hell out of model A rear ends in our youth. I have no trouble with the stock rear end in my banger that puts out more torque than a whole lot of V8's. However I don't go crazy with it either. I would love a quick change for the cool factor but my F150 RTS has been very satisfactory.
  10. brokenspoke
    brokenspoke
    My RPU has a T-5 from a S 10 4x4 keeping the torque tube to a Halibrand 101
    stillrunners likes this.
  11. It's hard to brake a rear end unless you have a tire that will stick to the Asphalt. Skinny rubber bands generally just spin. Now if you like to side step the Clutch there's a chance you could eventually brake something. That's not normally how we drive our Old Iron. I think your safe with a Model A diff.
    barrnone50 likes this.
  12. 51 mercules
    51 mercules
    I have a Halibrand 101 I'm going to use in my Model A
  13. The midget quick change is based off the model A rear
    There are three quick change sizes.
    The Midget
    The V8 or 6 spline in oval track racing
    and the Champ or 10 spline in oval track racing
    Deutscher likes this.
  14. Kiwi 4d
    Kiwi 4d
    originals were made in NZ , if you check “Kiwi Quick change” on Fake Book they are now made in Balmain NSW Australia, both V8 and model A.
  15. neds29
    neds29
    Thanks to everybody that responded. You answered all of my questions, all very clearly too.
  16. King ford
    King ford
    from 08302
    ...if you look at the picture of original advertising straight to the right of where it says" Downey machine company " you can see the pinion gear behind a cast in boss and a bearing on the nose of the pinion....stock model A rears didn't have that boss or bearing....V8 rear axles did and I would venture a guess that all quick change rear center sections did but would be very interested to know if the model A quick change used a model A pinion and thus lacked the nose bearing...
  17. alchemy
    alchemy
    The AB size Pat Warren doesn’t have a supported pinion. I’ve got one.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The Halibrand 101 didn't use the nose bearing either.
    Dan from Oakland likes this.
  19. neds29
    neds29
    Got it thanks. Ned
  20. ghalperin
    ghalperin
    I just picked up a Halibrand 101 center section. It was listed here in the cl***ifieds. 4:33 R&P, but no known gear sets. Are the gears 1" wide or 1 3/8"? After looking at the charts I was thinking a #3 23/24 or #4 22/26 gear set. I also need to do something with the shifter on the side of it. I think it's an in & out of some sort. Where can I find a tutorial or guide for this? I'm excited to add this to my roadster.
    n1%4H7v3Qy+CJDWVOkkfZw.jpg 7WcAqaquRPufFESLlFjVhA.jpg UhU0glZ+T12GHE9AqECaNA.jpg
    Outback likes this.
  21. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The ge****t widths are determined by the depth of the change gear cavity. You should be able to just measure the length of the splines between the lower shaft bearing and the turned down portion of the shaft. They look like 1" from here.
    As to the shifter: You might find a 1 piece lower shaft, but there is no reason that you can't just put it in the 'in' position. You might want to wire it to prevent it from accidently disengaging.
    The sets I show are:
    #2 - 23/24 (4.15/4.52)
    #3 - 23/25 (3.98/4.84)
    #3B - 17/19 (3.87/3.84)
    #3A - 22/25 (3.81/4.92)
    #4 - 22/26 (3.66/5.12)
    All using your 4.33 R&P
    My guess is that you will be happier with the #4 gear set @ 3.66 final ratio.
    Bruce
  22. sdluck
    sdluck
    It looks like a midget QC.
  23. 4bangerbob
    4bangerbob
    from AB, Canada
    No it is definitely for model A Model 101
  24. ghalperin
    ghalperin
    Thanks for the input. So is that shifter an in and out? If so, it would be good for flat towing.
  25. sdluck
    sdluck
    Never seen one with a in and out shifter that wasn't for a race car.
  26. 4bangerbob
    4bangerbob
    from AB, Canada
    The 101's come both ways, one without and mine with. IMG_5480.jpg s-l1600.jpg
  27. f6fhellcat00
    f6fhellcat00
    The new Winters early V8 center quick change doesn't use a pinion support either. In a quick change the pinion drive is facing the opposite direction and the end has the support on the spur gear not the pinion gear. So swapping out the original model A center section for a quick change is a much stronger upgrade. Not to many flatheads are going to break them.
  28. dirt car
    dirt car
    from nebraska
    In the circle track world even the supported bearing types suffered breakage including the bigger 301's & similar other brands, usually from a compe***or hopping a rear wheel or backing into another &/or the wall, many have been welded & successfully returned to use.
  29. Marty Strode
    Marty Strode
  30. alchemy
    alchemy
    That sure is pretty Marty!
    I sold my Pat Warren AB center. A rod shop owner probably saw my post in this thread and tracked me down, then was unrelenting in his pursuit to buy it for his client. I am sworn to secrecy what car it's for, but I can say it's a vintage race car getting restored to its original configuration.
