Hot Rods Seat decisions.....
Discussion in 'The Hokey Ass Message Board' started by chopo, Feb 22, 2021.
  1. chopo
    chopo
    [​IMG][​IMG][​IMG]
    First one is very nice to sit in. Number 2 looks good but not a 300 mile seat. And number 3 just is lacking something
  2. gnichols
    gnichols
    from Tampa, FL
    Comfortable, and adjustable, win every time.
  3. 40FORDPU
    40FORDPU
    Number one rolled and pleated, would be my choice.
    Nice dashboard.
    scotty t, chopo, Packrat and 2 others like this.
  4. lothiandon1940
    lothiandon1940
    Sent from my iPhone using The H.A.M.B. mobile app[/QUOTE]..............Sounds like you've already made your decision.:D;)
    Dino 64 likes this.
  5. jetnow1
    jetnow1
    from CT
    First one wins hands down. Looks right and it comfortable, what is not to like?
    210superair likes this.
  6. WB69
    WB69
    from Kansas
    Number one in my opinion.
  7. catdad49
    catdad49
    A59CA6E9-55EE-4693-9EA3-75FDC3CB4E2F.jpeg Put a bench in mine, much better than the buckets.
    Dino 64, dana barlow and Driver50x like this.
  8. hotrodA
    hotrodA
    Definitely #1.
    What’s it out of?
    dana barlow likes this.
  9. squirrel
    can you find some original springs, and cover them?
    F-ONE likes this.
  10. catdad49
    catdad49
    Mine is middle seat out of a Caravan which I made adjustable, added 1” foam to both pieces and My Wife did the upholstery.
  11. Elcohaulic
    Elcohaulic
    GM Strato bench with arm and head rests....
    williebill and scotty t like this.
  12. ekimneirbo
    ekimneirbo
    Buckets fit my buns best............
    If you don't make it comfortable, you will find that you don't drive it nearly as often. Those old cars are often small and cramped to begin with, so choosing something that adds a little room pays off later.
    Ned Ludd and irishsteve like this.
  13. indyjps
    indyjps
    Seat 1 looks like the right angle, seat 3 doesnt seem to be.
    The trick is extending the side cover down over the track, without using a big padded bolster reminiscent of a boat/ conversion van interior. If you can find any kind of chrome or stainless trim that can be adapted to the side of the seat it really makes it come together better.
    Lot of SUV, van third seats and pick up rear seats are out there as donors, but they dont come with seat tracks and may not lean forward.
    Small truck ( mini truck) era seats at least have sliders, may be split bench and need the headrests removed, many have a notch for shifter as well.
  14. JWL115C
    JWL115C
    You can't go wrong with a Glide bench. Adjustable back and forth, seat back adjustable and cushion opens up. Also, Tanks Inc. offers a nice mounting bracket that is adjustable for height.
  15. indyjps
    indyjps
    Hows the width on those for a hot rod, does a 60's mid size bench fit or does the frame need modified ?
  16. goldmountain
    goldmountain
    I have bought seat number three two times now. Still not good enough to use.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  17. Squablow
    Squablow
    I have a Strato-Bench sitting in my office right now, it's roughly 55 inches wide. No chance that's going to fit in a Model A Ford, even if you completely sectioned the armrest out.
  18. chopo
    chopo
    Rear of Isuzu amigo
  19. 51504bat
    51504bat
    I have a Glide engineering seat in my '39 p/u. 100% improvement over the stock seat. But in my p/u at least for me it is all the way to the back of the cab with no room for backward movement or tilt. I'm 6' but for anyone taller it might not be as comfortable. One plus is the seat lifts up for under seat storage. I did have a Caravan seat in a '40 Ford big truck I used to own and it made for a pretty firm seat. seat.jpg
  20. deucemac
    deucemac
    I agree with JWL. I have a glide seat in my roadster. Chose it because I would walk the L A Roadsters meet for hours every year and my legs would get very tired. I would head over to the Glide display and sit on one of their demos. I really liked this one bench seat. As it turned out, it was a seat for a 32 roadster! So, when it came time to buy a seat, Glide was it. So far, after driving it everywhere and some long hours, it still is comfortable. My upholsterer used different foam and ultra leather. It beats shopping endlessly or cutting down a seat and hoping it will work for the long run.
    fauj likes this.
  21. mgtstumpy
    mgtstumpy
    I have the OEM seats in my 35 tub and sometimes wish the front was adjustable, it's not so good on the back after a 300klm journey.
  22. Dino 64
    Dino 64
    from Virginia
    First one, IMHO. I also used a Caravan middle seat 367598FB-D628-4A3A-B2BA-DF841FA7F40F.jpeg
  23. TCATTC
    TCATTC
    Does the back of that seat fold forward?
    Dino 64 likes this.
  24. Dino 64
    Dino 64
    from Virginia
  25. Not to hijack, but what years of caravan are you guys using?
    Dino 64 likes this.
  26. TCATTC
    TCATTC
    And what are you using for adjusters?
    Dino 64 and fauj like this.
  27. goldmountain
    goldmountain
    I adapter seat adjusters from a junkyard bucket seat to a Caravan bench. Just had to remove the upholstery and foam cushion before welding.
  28. Dino 64
    Dino 64
    from Virginia
    Mine is from a 2000. Had to shorten the handle that releases the seat back. I got some universal sliders from Speedway for adjustment for and aft.
    fauj likes this.
  29. catdad49
    catdad49
    Yes, the seat folds. I used the adjuster from a rear caravan seat, cut down to the max. This method would not work in anything but an unchopped car.
    Dino 64 likes this.
  30. Dino 64
    Dino 64
    from Virginia
    Mine’s chopped almost 3”, what difference does it make ? Just curious ;)
