Technical Path of least resistance, Chevy closed to open drive
Discussion in 'The Hokey Ass Message Board' started by Busted Knuckles, Feb 22, 2021.
  1. Busted Knuckles
    Busted Knuckles
    Our recently picked up 47 Chevy has a stout 261 with a 3 speed, all new parts, looking to be able to make highway speeds at 70-75mph. I have a 56 Chevy 3.70 car rear to start the conversion. What is the most direct path both for maintaining a manual and for going automatic? Please share parts needed to do both
  2. junkyardjeff
    junkyardjeff
    A T-5 would be the easiest to do,Buffalo Enterprises made a adapter to the existing bellhousing if they are still in business,Lokar makes a parking brake cable that will work woth the original parts.
  3. vtx1800
    vtx1800
    you'd best get something with over drive. I have 3.70 gears in my 38 Chevy and even with tall tires it's spinning pretty well at 70, over 3000 RPM....since we have snow up the wazoo here I haven't had the car out.....can't remember the exact RPM per mile per hour. Overdrive is your friend.
  4. Busted Knuckles
    Busted Knuckles
  5. Dyno Dave
    Dyno Dave
    I described on 1954 Bel Air's Rear End' swap, my conversion to a S-10/Camaro 5-speed. Used a later bell housing so no adapter was needed. I liked the use of somewhat newer parts, thinking of easier replacements if needed. Dyno Dave
    Busted Knuckles likes this.
  6. Mark Wahlster
    Mark Wahlster
    28" tall tires with a 3.73 final is 67mph at 3000rpm
    P235/75R-15's are 28.5-29" tall depending on brand etc.
  7. hotrodjack33
    hotrodjack33
    The 55-57 rear is a bolt in EXCEPT you will have to re-drill the mounting pad to center the rear end. The mounting pins on the 47 springs is about 1-1/16 ahead of center.
    Busted Knuckles and Moriarity like this.
  8. 1971BB427
    1971BB427
    from Oregon
    I'm running 3.73 gears, and 29" tall rear tires on two different hotrods I own. One is a 1:1 final drive, and the other an OD with .63:1 final drive. The one is doing 3,000 rpm's at 70 mph, and I hate driving long distances at that rpm. The other is cruising at 2100 rpm's and I love driving it ANY distance! Then there's the fuel economy on the freeway that the OD also gets! A 350 with around 375 HP and it gets 18 mpg on the highway all day!
    I'd do the T5 swap, and put the 3.70 axle in your '47 and never look back! Your straight six will thank you for it!
    Dyno Dave and Busted Knuckles like this.
  9. junkyardjeff
    junkyardjeff
    Is this a 47 that looks like a 41 to 46 or the one that looks like a 48 to 53.
  10. Busted Knuckles
    Busted Knuckles
    World Cl*** T5 is being picked up this weekend! Screenshot_20210208-210001_Facebook~2.jpg
  11. junkyardjeff
    junkyardjeff
    I am wanting to build one with a 261 I have but its going to get a late 50s 3 speed with o/d.
