Technical Beadrooler motor kit
Discussion in 'The Hokey Ass Message Board' started by WDobos, Feb 19, 2021.
  1. any
    2 vote(s)
    66.7%
  2. any
    2 vote(s)
    66.7%
Multiple votes are allowed.
  1. WDobos
    WDobos
    A few yers ago a guy on here was selling kits to make a hand opernated beadroller into a powered unit. Anyone out there selling kits to do this. The shaft on my beadroller is 3/4" and the ones Eastwood sells is differant.
  2. J. A. Miller
    J. A. Miller
    from Central NY
    There are several YouTube videos on how to do this. Search bead roller motor.
  3. I bought my kit from Jegs. It was a Mittler Bros brand. Was cheaper to get it through Jegs then Mittler. Freight was about 1/2 too! Came with foot pedal, adaptors everything to convert a manual. I built my own bead roller and used the electric conversion kit to power it.
  4. Jmountainjr
    Jmountainjr
    McMaster - Carr has Lovejoy couplings in any size you need and you buy the drive couplings individually so having two different size shafts is not an issue. It's not a hard conversion. If you want variable speed you will need a DC motor. It's easy to wire an AC motor for forward / reverse. Typically you want a 10-20 RPM motor with decent torque. Get a foot control that has an electrical plug so it's easy to disconnect.
  5. rockable
    rockable
    I bought this one. It was easy for me to mount and it works great, so far. It has plenty of grunt and will crawl, when needed. I did have to buy a Lovejoy coupling to make the kit adapt to my 3/4" shaft. McMaster Carr has them. You buy the metric half for the motor, the insert and the inch half for the bead roller.....3 pieces.
    https://www.woodwardfab.com/product/motor-kit-wfbrm/
  6. Mr48chev
    A check shows that the Eastwood like I have have 22 MM shafts while the Mittler Brothers have 3/4 (at least the Bead Roller, 24" Manual (mittlerbros.com) one ) shafts.
    I'll probably be hand cranking for a lot longer though.
    X-cpe likes this.
  7. Jmountainjr
    Jmountainjr
    McMaster-Carr has metric Lovejoy coupling parts.
  8. Blue One
    Blue One
    from Alberta
    Why use a kit?
    Buy the Eastwood bead roller and motor if you want to take the easy route.
    Or maybe you can do what I did and set up yo
    your own.
    See my thread.
    https://www.jalopyjournal.com/forum/threads/another-bead-roller-beef-up-and-power.756945/
    Hot Rods Ta Hell and fauj like this.
  9. I have been eyeing this maker motor... it makes 31 ft-lb of torque at 5 RPM...
  10. Blue One
    Blue One
    from Alberta
    A 12 volt motor isn’t what you want for a bead roller.
    fauj likes this.
  11. rockable
    rockable
    You absolutely want variable speed.
    lake_harley and Blue One like this.
  12. Paul
    Paul
    Editor
    I have friend that a used garage door opener and bicycle gears and chain on his, forward and reverse but no variable speed.
  13. Blue One
    Blue One
    from Alberta
    Not really true. Mine works fine with a speed of 2.8 rpm.
    I wouldn’t want it to move any faster and I’ve done plenty with my setup.
    Slow and steady and controllable wins the race when bead rolling.
    rockable and Budget36 like this.
  14. rockable
    rockable
    I wouldn't trade mine for a fixed speed. Each to his own. :)
    Fitty Toomuch and mcsfabrication like this.
  15. telecaster_6
    telecaster_6
    Find a treadmill, pull the motor and control board off it. Just have to wire in a foot pedal. Works great, tons of torque, and variable speed.
  16. 31Apickup
    31Apickup
    I made up a flange to mount a Pontiac flex plate I had. Used a gear off a starter motor. Using a variable speed drill ( just clamped in place in photo) and a foot controller it works pretty good. Have to build a permanent mount for the drill motor.
  17. I really like this idea. Lo-buck and gets the job done, and if you get a bit creative you could have more gearing options.
  18. 1971BB427
    1971BB427
    from Oregon
    I voted for "any" in your poll.
    Sporty45 likes this.
  19. Mimilan
    Mimilan
    Use a 12 v electric winch motor and planetary gearbox.
    https://www.harborfreight.com/autom...ches/2000-lb-utility-trailer-winch-57365.html
  20. 27 Tall T
    27 Tall T
    from Butler Pa.
    Look for Jere Kirkpatrick Vally Forge Welding on You Tube, He has a few good videos on powering a bead roller and other mods. I did mine following his plans, and am happy with the results. He also has good videos on metal shaping,and home made tools.
  21. Sporty45
    Sporty45
    Yeah, but which "any"? :p
    Fitty Toomuch likes this.
