Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Wardog
    Wardog
    Thank you Don, but I’m not done yet.
    Stogy likes this.
  2. Stogy
    Stogy
  3. Wardog
    Wardog
    Before I set my radiator and grille up for hopefully the last time I decided to put a front seal on the crank. I used a one piece rubber oil seal rather than a rope seal. It was a good time to clean the sump and have a look inside the engine.
    E3C35ABF-37F4-4A28-A0C9-944EB4210BCE.jpeg 37701BD5-7A74-4A8B-ACF0-5816C0AA7816.jpeg 06D115AB-90DD-45CF-AF94-FA10B9FEBB7F.jpeg 7120E03F-A61D-4786-8851-13B2FB9680FD.jpeg 61C5A31D-96F0-49AF-96D9-AD36DA5CBEE7.jpeg
  4. Stogy
    Stogy
    @Wardog is this the first time you have had the pan off this engine?...is that sludge due to the type of oil used as in non detergent?
    I use 10w30 but I also am running a 60s smallblock...I suspect Flattys are different...
  5. Wardog
    Wardog
    @Stogy Yes it’s the first time I’ve had the pan off. It could be the type of oil or long intervals between oil changes.
    I’ll be using a modern multi grade version of a 50 weight oil.
    midroad, brEad, Stogy and 1 other person like this.
  6. Wardog
    Wardog
    BEB7D43F-5F65-452F-B6A3-19ADD790C430.jpeg 45BBEF18-B73B-4CE5-B4A0-6B984B5A6568.jpeg B29DA589-15B8-4BB6-AB7A-18DAE46BF70C.jpeg D8635DB7-AA22-440D-AE88-9BB22F0559C9.jpeg 9E597F83-43CC-4578-B23F-EE951302478C.jpeg 7B31454E-904C-45FF-96F7-6DEEDF7D47AF.jpeg
    Here are some recent photos. I’m still working on it. It’s getting close to being done now.
    Deutscher, Stogy, Tim and 10 others like this.
  7. Wardog
    Wardog
    We finished the wiring this weekend. I drove it for the first time. I’ve got a few things to finish of but man it feels great to get behind the wheel of this car.
    A52F6CD0-6879-4320-89CA-9A0E594F7621.jpeg 9CB995EA-8DD5-41DF-84AA-E2910F668DEE.jpeg 292CAEAE-E355-482F-8E57-F9237BDB2A85.jpeg 68C21F01-3345-4EA7-850C-DB1061D9A024.jpeg B56DC80B-4321-4957-9AAD-6F7E4D71DE6D.jpeg
  8. Drylake
    Drylake
    Very nice!
    Wardog and Stogy like this.
  9. Cleat
    Cleat
    from Gifford WA
  10. Stogy
    Stogy
    Congrats on the Milestone @Wardog...the Checkered Flag to a new adventure is fast approaching...glad you've had a well deserved taste of what to expect...looking forward to the finishing touchs on your Vintage Hotrod...
    brady1929, Wardog and nunattax like this.
  11. Wardog
    Wardog
    Thanks for the comments guys. It seems to drive well. The rear spring settled pretty low so today I put 3 more leaves on the top of the pack. Now I need to finish my dash.
    Fairlane500 and Stogy like this.
  12. Wardog
    Wardog
  13. Wardog
    Wardog
  14. Aaron D.
    Aaron D.
    Looks like it drives great, and the sound is great too.
    Stogy likes this.
  15. Wardog
    Wardog
    It seems to do everything it’s supposed to, and drive nice. The smithy’s produce a nice sound.
    Stogy likes this.
  16. Wardog
    Wardog
    I finished my accessory gauges today. Apart from refitting some B pillar trims the interior is done.
    F36A603D-6910-42BA-8CE2-BCC110912319.jpeg 1712EA6C-17CE-48E1-A3E7-B641B761ADED.jpg
  17. Matthew H.
    Matthew H.
    What an amazing build
  18. Stogy
    Stogy
    Ole Screamer has a three gauge collar now...:D...Looks great Wardog, is that 2 temperature gauges, 1 per side? Sure would let you know how things are flowing...​
  19. Wardog
    Wardog
    Thanks. Yep, one temp per side. A friend of mine had one temp gauge in his flathead and boiled the side without. Because they have the two water pumps they can run as two separate systems.
    Deutscher and Stogy like this.
  20. Speedy Canuck
    Speedy Canuck
    I just found this thread, read the whole thing, and now it's almost done. Awesome work! Really cool to see this build take shape.
    Stogy likes this.
  21. Wardog
    Wardog
    Stogy and Speedy Canuck like this.
  22. Wardog
    Wardog
    My wife and I put a few miles on it this weekend.
    Deutscher, Jet96, Stogy and 8 others like this.
  23. 55zephyr
    55zephyr
    Nothing better than driving around fenderless with the wife next to you, I do it all the time. Great looking car.
    Enjoy and good luck, Ron.
    Stogy likes this.
  24. Wardog
    Wardog
    @55zephyr thanks. It was her first drive since the ch***is swap.
    Stogy likes this.
  25. Wardog
    Wardog
    I took my generator to my auto electrician today. He fixed a mistake I had made and set up the output amps on the test bench.
    It’s time to put some decent miles on this car.
    Deutscher, Stogy, brEad and 1 other person like this.
  26. Wardog
    Wardog
    Since hitting the road I’ve been refining it bit by bit. I’ve added leaves to the rear spring, synchronised the carbs and set the idle mixtures, pushed the top of the grille forward a bit, opened up the toe in and adjusted the headlights. The generator seems to be doing it’s thing but I haven’t been able to take it for a drive to check. One thing I was able to do was re shape the accelerator pedal for clearance when braking hard. B3398E8B-4232-4CCC-94E3-8973817ED755.jpeg E7077F05-14F4-4FD1-9CF2-273057A90F01.jpeg
    Tim, Deutscher, Jet96 and 7 others like this.
  27. Wardog
    Wardog
    I’ve been really busy lately. I’ve had time to change the head gaskets, more of a preventative measure than anything. I’ve also re done the front crank seal. I put in a one piece lip seal but didn’t use a sealant around the outer. It was leaking so I replaced it.
    I’ve driven it the last 4 days and it seems good.
    E98DE0CF-E2AA-422D-9430-D778495EDCD9.jpeg E85CF3D8-8C47-4C6E-B44B-1A798BF465F4.jpeg
    Tim, Deutscher, Jet96 and 12 others like this.
  28. Stogy
    Stogy
    Good stuff @Wardog...gettin' the bugs out and fine tuning...lovely pic at the Swoopy Dome...even colour coordinated...:)
    Outback likes this.
  29. Wardog
    Wardog
    Thanks. Yeah the plywood lined sound shell was a great back drop.
    Outback and Stogy like this.
  30. Outback
    Outback
    from NE Vic, Oz
    Great to see it out & about!
