Sunday models
Discussion in 'The Antiquated' started by milo1303s, Mar 16, 2014.
  1. milo1303s
    milo1303s
  2. Mike-model
    Mike-model
    @lothiandon1940...I've ordered 2 JF bodies and both were just terrible. Both need a ton of work, but doable. The entire body was covered with porosity, read pin-holes. Not deep, but showed up in primer paint. Here a tip: if you're not using lacquer paint, buy a high quality fingernail polish called "ridge filler". Use the brush in the cap. Figure on paying around $10 for high quality. The stuff goes on thick and runs like to was melted, liquid lead...so smooth and fills every gap, scratches and pin holes! The stuff is magic. Ask your gal, she knows!
    The other body, a chopped '32 3 window, has flash and ungodly streaks...like "wtf" kind of junky finish! Anyways, both were dirt cheap @ $10 and $7, so I can't really complain....just sayin'.
    Mike..
  3. lothiandon1940
    lothiandon1940
    .........Thanks a bunch for the response. I was hoping for better news, but thanks for the tip regarding "ridge filler". I don't have the body in hand yet so I hope the quality has improved....Don.
    lothianwilly71 likes this.
  4. rudestude
    rudestude
    Ya quick it wasn't much this time ...just a "junk yard" a bunch of 36 ford stuff ,some custom parts and coupe and roadster conversion parts included is the 60's issued AMT 3 in 1 36 Ford coupe/roadster kit box also looked like there was even a old Monogram hot rod roadster in the mess.
    But I haven't received it yet ...7 days late so far ,due to bad weather...coming from Florida, last night it was in Pittsburgh?
    Anyways your comment on your earlier post about the models in the old R&C and others gave me a idea.
    I have alot of the old magazines and they do have some pretty good stuff on models, tips ,builds , general info on new releases and some cool old ads.
    I thought I would post some of them occasionally if anyone is interested in seeing some of the old stuff.
    Here's a sample...if its not for this thread I will remove them and stop posting them. 20210224_221325~2.jpeg 20210224_231059~2.jpeg 20210224_231113~3.jpeg 20210224_230953~2.jpeg 20210224_231020~2.jpeg 20210224_231037~2.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    mchook, NHRANUT, john worden and 6 others like this.
  5. rudestude
    rudestude
  6. Mike-model
    Mike-model
    UPDATE: Zoomies in the works now. Left side is OK. Tube ends need to be capped somewhat as the ends don't run even with the plug panels. The line runs upwards, so 1, 3 & 5 shortened, #7 sits good.
    Right side not so lucky, the radius is not tight enough, but since the tubes have been shortened already, they don't fit in the tube bender anymore as being too short now....my bad. Anyways, here the proper scale 2,5" pipes in aluminum;
    Right side tubes in brass are in the works, more soon on this....
    Mike..
  7. Mike-model
    Mike-model
    Folks, just an off-topic FYI now.
    I have a bunch of brown long neck bottles in stock, the grill is already smoking, and mild temps with a blue sky today.
    I made it!
    HAPPY BIRTHDAY to me.
    Seven-0 today. 70 years and I'm doing OK, but kind of scared with this number, haven't quite grasped the number yet.
    Cheers!
    Mike..
  8. rc57
    rc57
    Happy Birthday!
    chevy57dude, Mike-model and Deuces like this.
  9. Deuces
    Deuces
    top-list-gramps-will-love-these-th-birthdayts-for-him-kathln.jpg That's a lot of candles on your cake...;)
    Happy Birthday!!!!!!!......:D
  10. HJmaniac
    HJmaniac
  11. mchook
    mchook
    from upstate NY
    HAPPY BIRTHDAY!
    lothiandon1940, Mike-model and Deuces like this.
  12. mchook
    mchook
    from upstate NY
    Another junker rolled into the garage.;) pacer1.JPG pacer4.JPG PACER21.JPG PACER22.JPG
    My next project is going to be fun!!!
    81680250_10221294558939144_1248417040121724928_o.jpg.6571e7f2193ff00ce3fffcdf4650a14e.jpg SUNP0001 (2).JPG SUNP0003.JPG
  13. lothiandon1940
    lothiandon1940
    .........Received the '61 Starliner body from Jimmy Flintstone and was pleasantly surprised by the quality. Lots of flashing, took about an hour to trim all of it, but I was expecting that. No big deal. No hood, so now I need to trim and remove the hood from the Styline '61 Galaxie kit I'm using for parts, (all trim, etc.). Any advice on how to cleanly remove the hood would be greatly appreciated. The old hot*****er knife technique I would have used as a kid just won't work!:eek:.....Thanks, everyone....Don.
  14. HJmaniac
    HJmaniac
    Whew!...I am relieved you were pleasantly surprised.
    Check Ebay now for hood source
    AMT 1961 Ford Galaxie Sunliner Convertible Built | eBay
  15. edcodesign
    edcodesign
    My 36, still messing with the roof. 782ABE8A-CF6B-4216-807E-9D85855AD714.jpeg
  16. 41 coupe
    41 coupe
    from bristol pa
  17. Dan Hay
    Dan Hay
    Still moving forward on the 32 sedan.
  18. rudestude
    rudestude
  19. HJmaniac
    HJmaniac
    I got this off the old wrecker thread. I thoight this might interest you.
    https://www.jalopyjournal.com/forum/threads/old-wreckers.328231/page-5#post-11592858
    Here's one that you don't see everyday. A 1924 Lincoln 4dr car converted into a wrecker. Probably right around WW2. [​IMG][​IMG][​IMG][​IMG]
  20. Mike-model
    Mike-model
    I haven't a single clue about cutting out body panels nor any experience. This would be personally a nightmare thought. Glad you picked up a usable body and hope a fellow can chime in.
    Mike..
    lothiandon1940 likes this.
  21. lothiandon1940
    lothiandon1940
    ......It was a bit of work and quite tedious, but I managed to cut out and remove the hood from the donor model. Now on to the next challenge.
    Mike-model, HJmaniac and dehartcarl like this.
  22. rudestude
    rudestude
    My last ebay purchase.....not really , I have a 57 Crysler 300 thats supposed to be here tomorrow, anyways its the one that was supposed to be here on the 19th last month but due to bad weather, it came from Florida, it showed up yesterday.
    It was a what they call a junk yard lot, usually just a bunch of parts ...but this one was a vintage 36 amt 3in1 customizing kit trophy series ...that means Cool.
    Not alot of parts ,but it had parts that I needed for another build and a vintage Monogram Green Hornet t roadster, it had been****embled but was coming apart,was also in the box, and the box was in very nice condition and it also had the original instruction sheet, they are really cool for that series they have extra customizing info.
    I got the Hornet reassembled ,except a couple of suspension parts , have them ...just saw that I forgot to put them on...all the parts seemed to be there. 20210303_220027(0)~2.jpeg 20210303_220237.jpeg 20210303_220728~2.jpeg 20210303_220651~2.jpeg 20210303_220328~2.jpeg 20210303_220455~2.jpeg 20210303_220519~2.jpeg 20210303_214742~2.jpeg
  23. rudestude
    rudestude
    Some more shots of the "Green Hornet"
    I had some Hornet parts that I got with a past "Junk yard lot" purchase, it included some parts from a later release kit and a couple parts from a vintage released kit...easiest way to tell the difference is the color ...vintage kits are molded in a darker green and the tires are different...if just looking at parts, there's other things also . 20210303_213759~2.jpeg 20210303_214742~2.jpeg 20210303_214453~2.jpeg 20210303_215010~2.jpeg 20210303_215039~2.jpeg 20210303_215214(0)~2.jpeg 20210303_215302~2.jpeg
    Mike-model, mchook, quick85 and 6 others like this.
  24. rudestude
    rudestude
    T Time for two.....
    Or What to do with grand dads old Ford?
    Check out the seat in the Hornet....it was like that when I got it...was the previous owner going for the "sheep skin" upholstery look or did something die in the seat? 20210303_215350~2.jpeg 20210303_215238~2.jpeg 20210303_215543~2.jpeg 20210303_215849~2.jpeg
    Mike-model, mchook, quick85 and 7 others like this.
  25. rudestude
    rudestude
    My last ebay purchase showed up today.
    Nice kit , new still factory sealed, winning bid..mine..$17.99 + $10.10 shipping, not bad I guess.
    I really like 57 Chryslers, years back I had a 57 Chrysler Windsor wagon,before wagons where cool, it was lowered ...fun cruiser.
    Anyways this is a nice kit ...I actually needed it for a up coming build. 20210304_171945~2.jpeg 20210304_171750~2.jpeg 20210304_172007~2.jpeg 20210304_172147~2.jpeg
  26. rudestude
    rudestude
    Well this*****s ....please don't hate.
    That 57 Chrysler 300 is a cool kit...but like I said it's for a up coming build.....and I only got it for parts , I tried other sources for just the parts I needed...no luck.
    The only parts I need from it are the headlights and about a inch of each front fender , where the headlights mount.
    But I am going to see about a 57 Chrysler wagon resin body , then I can use the rest of the kit, most of it, and build one like my old wagon.
    Other parts needed : 60 Chrysler "Boomarang" taillights
    60 Chevrolet Impala front and rear bumpers and valances. 20210304_171232~2.jpeg 20210304_171146~2.jpeg 16146941715915834749524254795206.jpeg
    Mike-model, Deuces, NHRANUT and 7 others like this.
  27. quick85
    quick85
    ^^ Whatta krazy kid.
    Mike-model and rudestude like this.
  28. rudestude
    rudestude
    Thanks quick..you made my day , morning ?, I haven't been called that in year's, been called alot of other things....
    I will cut you in on what I'm doing ...like I need to start another build....
    My build is based on the 56 Chevrolet "Miss Taboo" .
    If you don't know about it's history, look it up online or here on the H.A.M.B., the car has some very interesting history and it's current care taker is with us on this site.
    I first saw the car at a show in Portland Oregon 1980..the year I graduated H.S. ...it was black and red then...and thats the version that I'm basing mine on.
    Will see how it goes...if anyone is not familiar with the car , look it up ,it got a very cool history/story and it's still bringing home the awards.
    The first picture is the one I took the first time I saw it. 20210226_130041~2.jpeg 16140563624464000082865221944430.jpeg 16144159742143171741052131990461~2.jpeg 16140563867258766773089936108785.jpeg 16140564178314023211883937160768.jpeg 1614940041473328548018273191111.jpeg
  29. rudestude
    rudestude
    Started stripping the side trim and emblems off.
    Not going to start any cutting until I go get a new saw..
    A very sharp one with a very thin blade.. 20210304_205956~2.jpeg 20210304_215010.jpeg 20210304_214938~2.jpeg 20210304_214956.jpeg
    Mike-model, Deuces, 41 coupe and 8 others like this.
  30. mchook
    mchook
    from upstate NY
