I'm trying to identify the manufacturer of this Cadillac bellhousing used on 54-62 331, 365 & 390 ci engines. The only casting markings I can find are on the starter cone KD 25 Any help would be appreciated. Thanks Dan
I found it listed for 55-64 Cadillac to a 55 up GM p***enger, 3 or 4 speed. No indication of what flywheel or starter is to be used.
That is a very desirable adapter...it only fits Cadillac 1955 to 62..and you can put a Muncie or T10 behind it..
You got Lucky! But Sqeek Bell also made a similar one at one time if anybody else is looking. And yes you can use and Olds Fly wheel on a Cad. You will need the Cad starter though as it mounts on the P***enger side. Same one you use with a starter flip on an Olds. - Tim Guess I should have read throug the post. That great chart explains it all.
