Projects Not Your Average Coupe Build: ‘37 Chevy Unearthed
Discussion in 'Traditional Customs' started by oneratfink57, Jan 31, 2017.
  1. I'm curious how they'll sound too. I love the look of the Smithys but don't know anyone who runs them
  2. oneratfink57
    oneratfink57
    from Wisconsin
    I hoped they were actually hammer tone paint like they claim, but it’s really just painted that color.
    With any luck, I’ll be able to hear them this summer
  3. oneratfink57
    oneratfink57
    from Wisconsin
    Nothing too exciting today. Bled the master cylinder, finished some welds on the exhaust.
    Then painted and installed the MOOG steering components. Picked up a manual steering box off a fellow H.A.M.B.er.
  4. oneratfink57
    oneratfink57
    from Wisconsin
    I promise the end is near for pictures of just the frame lol. I mounted up some fresh H78 15 white walls. I was going to get the 4” wide whites, but these match the G78 front white walls ive already got
    Also got a nice set of 53 olds caps
    One of my kids came out and helped me bleed the brakes today. Getting functional brakes and steering are pretty big milestones, I’m glad to finally be crossing some of this mechanical stuff off the list
    Also dropped the trans and pinion yoke off at the local(ish) driveshaft shop this afternoon. Should have new driveshaft on Monday.
    Stogy, chryslerfan55, brEad and 5 others like this.
  5. oneratfink57
    oneratfink57
    from Wisconsin
    Driveshaft’s done!
    Picking up engine from machine shop tomorrow
    Stogy, unforgiven, 40two and 8 others like this.
  6. oneratfink57
    oneratfink57
    from Wisconsin
    Finally got the 283 back and ordered all the goods.
    Highlights are block is 0.060” over. Powerpack heads have hardened valve seats and new guides installed. Went with the 0.435” lift Isky 262 Supercam after a few days of deliberation.
    Should be a good low-midrange cam for the now 292.
  7. oneratfink57
    oneratfink57
    from Wisconsin
    A few years later, got around to welding the underside of the floor and painting it.
    If anyone is curious, I discovered why people buy/ make rotisserie’s! Next time I guess?
  8. 1971BB427
    1971BB427
    from Oregon
    Just discovered your build, and went through the eleven pages today! Great work on the coupe! It made me feel better about doing my rotted out '39 Chev coupe, as I thought mine was too far gone, yet it had less rot than yours had! Mine is ready for paint this spring I hope.
    Looking forward to watching this build now, and seeing the progress.
    loudbang and oneratfink57 like this.
  9. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks 1971! There’s always that one guy out there that’s just a little crazier lol. Glad to hear you saved one and put it back on the road. Hope I can take mine for a burn around the neighborhood by end of summer
    chryslerfan55, brEad and loudbang like this.
  10. oneratfink57
    oneratfink57
    from Wisconsin
    It’s getting crowded! Had to shuffle everything to help a buddy replace the front diff in his Sierra.
    This weekend might be dedicated to just cleaning up the shop.
    one cool observation was taking note of the before and after ride height. The tire is bigger, but between channeling the floor and lowering the suspension, I got the 4 to 5” of drop I was looking for
    Before:
    After:
  11. 1971BB427
    1971BB427
    from Oregon
    If your coupe has the stock rear spring pack, they sit extremely high! I changed mine out to use '55-'59 Chevy pickup front leaf set, and still added a 1" lowering block to get it exactly where I wanted it.
    oneratfink57 and loudbang like this.
  12. oneratfink57
    oneratfink57
    from Wisconsin
    Good to know on the truck leaf springs! I made the leaf spring mounts and shackle hangers to accommodate 2.5” wide super glide springs from speedway, which dropped the suspension a decent amount and I also did 2” lowering blocks.
  13. 1971BB427
    1971BB427
    from Oregon
    The truck front springs are 1.75" like original early Chevy springs, but flatter. So yours being wider now wont be an option anymore. I kept the stock main leaf, and made up my set from the pickup springs I took off my donor front axle when I put new shorter springs up front.
  14. Jacksmith
    Jacksmith
    from Aridzona
    Sits real nice now! Bet it looks just right with the fenders on.
  15. oneratfink57
    oneratfink57
    from Wisconsin
    I hope so!
  16. oneratfink57
    oneratfink57
    from Wisconsin
    Another ride height before and after
  17. oneratfink57
    oneratfink57
    from Wisconsin
    Christmas in March!
    40two, A23, Shadow Creek and 3 others like this.
  18. Jacksmith
    Jacksmith
    from Aridzona
  19. oneratfink57
    oneratfink57
    from Wisconsin
    Got distracted again with spring house projects etc. but finally got time to start ***embling the 292
    Hope to ****on everything up this weekend and paint it
  20. oneratfink57
    oneratfink57
    from Wisconsin
    One of the kids wanted to jump in and help finish the engine today. She was a big help!
    And what do you know, it’s another small block Chevy lol
  21. oneratfink57
    oneratfink57
    from Wisconsin
  22. oneratfink57
    oneratfink57
    from Wisconsin
    Wire brushed and painted factory oil pan and timing cover today
    Once I get these bolted up, I’ll be moving on to my first automatic transmission rebuild.
    Will be making a holding fixture for the TH350
  23. vtwhead
    vtwhead
    Late to the party here. You may have covered this but on the '37 coupe I built for a friend we found that the rear tire was not centered in the rear opening after we started ***embly. Had to move the rear back 3/4 of an inch. IIRC we used Nova springs with hardware from Ch***is Engineering. Have you checked this or covered it already?
  24. 1971BB427
    1971BB427
    from Oregon
    I moved the rear axle back 1.5" on my '39 to center it.
  25. oneratfink57
    oneratfink57
    from Wisconsin
    Vtwhead/ 1971BB427,
    Thanks for the info! Unfortunately I think it’s something I’ll have to do. I used the 2.5” drop springs from speedway but never measured from the eye to the pin to confirm.
    I will be running skirts so I’m not too concerned about the aesthetics, but once I do the rust repair on the inner fender so I can bolt the fenders on, it will bother me and I’ll have to fix it lol
  26. 1971BB427
    1971BB427
    from Oregon
    You can redrill the hole in the main leaf only, and then re***emble the stack of leaves. Sometimes the shift of the rest of the set requires on to be trimmed on one end, but a bandsaw or portaband does that easily. I've done this often using a carbide drill bit, and they drill easily. No reason to drill the whole stack, just shift the others once the main is drilled.
    ottoman, oneratfink57 and loudbang like this.
  27. oneratfink57
    oneratfink57
    from Wisconsin
    Nice!
  28. oneratfink57
    oneratfink57
    from Wisconsin
    Motor is done!
    Welded on the oil pump pickup
    Installed pump (almost forgot the drive!), timing cover, and oil pan.
    Now I can roll it in the corner for the rest of the summer (sometimes I wonder why I do the things I do)
    Next, I’ve got to pull the block and trans out of the coupe, so I can make a trans holder and rebuild the th350
  29. oneratfink57
    oneratfink57
    from Wisconsin
    Made the transmission holding fixture today.
    Used the same 1” threaded bosses I used on the floor
    Might end up throwing some extra stiffeners on the tube frame, because the gauge steel tubing I used was pretty thin.
  30. oneratfink57
    oneratfink57
    from Wisconsin
    Another summer has come and gone, and I’m starting to make progress on the coupe again.
    Today I made a column drop out of a crusty original one and some s**** metal to accommodate the updated 2” steering column
    tacked the 1” flat stock to a 2” OD tube, and used the oxy acetylene to make the bends a little easier and more uniform
    was originally going to buy pipe hanger clamps to save some time, but the hardware store didn’t have them in stock
    The original column drop was pretty banged up, in addition to being too small of a diameter, so I used it as a donor
    Not the prettiest but it does the job for the right price! And looks original-ish
    mvee33, 54delray, 1971BB427 and 6 others like this.
