Hot Rods The 'General Mischief Coupe' Model A build
Discussion in 'The Hokey Ass Message Board' started by Jethro, Jan 3, 2020.
  1. Jethro
    Jethro
    I spent a few days finishing up the welds from the chop and had to stop because I was starting to "chase" tiny shrinks and warps....you know the ones you can't really see but can feel. Anyway I think I was just making more work for myself that was not going to be seen after paint so I just quit.
    I have been sealing up the floor because if the stars align I will be taking this to Bonneville. Maybe not this year but for sure 2022 . I can really appreciate the courage that some guys have taking their hotrods in bare metal to the salt. I don't want to have to redo everything so I'm sealing as much as I can to prevent salt invasion. Epoxy primer, urethane seam sealer , paintable bedliner and catalyzed Tremclad (Rustoleum).
    I also made a cover for the master cylinder with a quarter turn latch. 20210226_100907.jpg 20210226_105119.jpg 20210226_105147.jpg 20210226_105200.jpg 20210226_110413.jpg 20210226_110427.jpg 20210226_121133.jpg
  2. brEad
    brEad
    Looking good!
    High test 63, Stogy and loudbang like this.
  3. AHotRod
    AHotRod
  4. Phenomenal work. One question though, as it’s called “General “ mischief, is that a regulation hair cut? [emoji6]
    loudbang and Stogy like this.
  5. Jethro
    Jethro
    I had a quick look at the US Marines grooming regulations and it said something about 3 inches , so I chopped the General 3 inches . I guess that means it's within the guidelines.
  6. Indeed.
  7. Rooster72
    Rooster72
    I love it when people dare to be different, looks great
    Stogy, loudbang and chryslerfan55 like this.
  8. Jethro
    Jethro
    I've been trying to come up with a different yet traditional looking headlight stand. I'm not going to use the fenders so the fender braces are going to be wasted. One was already broken anyway so it was an opportunity to try something. I cut them off and machined some "cups" for the headlight studs. Welded and blended them with my belt sander.I think they will look good. A little lower and a little further apart. It's all about the look , if they don't look right they aren't. I really won't know until it's all together with wheels and paint. 20210313_172415.jpg 20210313_172329.jpg 20210313_172318.jpg 20210313_172222.jpg
    oliver westlund, Stogy, Tman and 10 others like this.
  9. greaser
    greaser
    Will the headlights clear the tires when steered lock to lock?
    Stogy, akoutlaw and loudbang like this.
  10. SPEC
    SPEC
    Looks great.
  11. dumprat
    dumprat
    from b.c.
    Neat idea Jeff. You could attach them on the side of the frame too.
  12. Jethro
    Jethro
    Best guesses and measurements say they should......BUT I will only really know when it's all together
    Yeah , I would just have to clock the lenses a quarter turn. Good idea!
    chryslerfan55, Stogy and loudbang like this.
  13. dumprat
    dumprat
    from b.c.
    Model T lights kinda mount that way.
  14. Jethro
    Jethro
    The latest lil project...
  15. dumprat
    dumprat
    from b.c.
    That's cool! I would be concerned about the imprint that would leave in my forehead in an accident.. lol
    Stogy, patterg2003 and loudbang like this.
  16. loudbang
    Ingenious. :)
    Stogy and chryslerfan55 like this.
  17. Jethro
    Jethro
    I'm touched by your concern for my safety.....here's my traditional take on a modern safety item 20210330_140156.jpg 20210330_140203.jpg
  18. dumprat
    dumprat
    from b.c.
  19. Jethro
    Jethro
    It's been nice enough to get the shop up to temp and do a little painting. I used Tremclad (Rustoleum) gloss black for the wheels , axle , radius rods and ladder bars and semi gloss black for the frame. I used a generic acrylic enamel gloss hardener in both and after 2 days they are rock hard dry. I'll order the tires soon and maybe I'll be able to get the ch***is together before summer. 20210403_102722.jpg 20210403_102709.jpg 20210403_102555.jpg 20210403_102518.jpg 20210403_102452.jpg
  20. Looking great!
    -Brent-, Stogy and loudbang like this.
  21. Jethro
    Jethro
    The DHL guy dropped some new shoes off yesterday and I had to show em off . Coker Firestone blackwall 700-16 and 550-16. The neighbour let me use his tire machine to mount them (good neighbor). So the General put on his new shoes and I had to set the motor in place just cause.
    It seems like a lot of progress but now I have to do bodywork....UGH! Oh well , gotta get done sometime. 20210424_094224.jpg 20210424_094237.jpg 20210424_100707.jpg 20210424_100720.jpg 20210424_100732.jpg
  22. Jethro
    Jethro
    Because I have to get an inspection to get this registered and licensed I need a proper exhaust. The inspection manual is very clear about no cutouts or exhaust in front of the p***enger compartment. I'm going to run two pipes out the back but I have to wait till the body is on to do the tailpipes and over the axle pipes. I made my own mufflers by the way. I know some guys will say " why waste your time when you can buy them" , they are made from stuff in my junk pile so they cost nothing. One more little checkmark on the list of things to do.
    patmanta, Tim, chryslerfan55 and 8 others like this.
  23. typo41
    typo41
    Great build, silly question, what is the trans? Did it bolt right to the stock trans?
  24. Sure looks like a T5 and stock bell, makes me wonder also since I have the same parts floating around the shop
  25. Jethro
    Jethro
    It's a T5 from an S-10 and the bellhousing is from a 235. I had to make a mount for the clutch slave cylinder. If I could find a bell from a 60 truck 235 the slave mount is built in and on the p***enger side instead of the drivers side.
  26. Jethro
    Jethro
    So , when you're in a big city walking across a bridge sometimes there is a grate or screen that's supposed to keep suicidal people from jumping off. Not sure if they work or not but the thought is there.
    I've never liked the name "suicide" front end. It kind of implies that the driver has a death wish or something. There have been a couple of guys living rent free in my head for a while , they've been the ones saying "oooh I don't like the look of that" ...." Yer gonna dig those frame ends straight into the dirt if yer spring breaks"
    I mostly ignore the voices but I'm not suicidal so here is my take on a multipurpose SPD , headlight mount , rad mount.
    I made the SPD out of 1/2 X 2-1/2 steel and bolted it through the top of the frame with 3/8ths bolts. I drilled and tapped the plates for 5/16 bolts for the headlights and rad mounts. The SPD should be the last resort if my shock mounts fail. Maybe overthinking things but I needed an answer for the rad and headlights and I think the rolling bones guys have an axle catcher on the front of their frames for the same reason. 20211029_114041.jpg 20211029_113956.jpg 20211029_113843.jpg 20211029_113833.jpg 20211029_113756.jpg 20211029_113736.jpg
  27. brEad
    brEad
    How about a pic showing how the spring mounts to the bones? Looks clean from the front.
    Stogy, OFT and loudbang like this.
  28. Jethro
    Jethro
    I found a piece of perforated metal and cut it to fit in the shell. It has a galvanized finish
    I'm still deciding whether or not to paint the insert black. 20211031_112414.jpg
  29. OFT
    OFT
    I'd go black to match axle.
  30. dumprat
    dumprat
    from b.c.
    I agree with the black!
