Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    Yes, but it would really only work out to about a half gallon.
    loudbang and Stogy like this.
  2. Dick Stevens
    Dick Stevens
    That half gallon could make the difference in making it to the next gas station or not, though! :D
    Stogy and Paul like this.
  3. Stogy
    Stogy
    He's gonna have a fuel gauge...T's have a stick don't they...:p
    brEad, Paul and loudbang like this.
  4. Paul
    Paul
    Editor
  5. Stogy
    Stogy
    Right on...I saw a T Coupe at a cruise a couple years ago and learned a few things...one thing for sure after running out of gas in my Coupe twice I have never done it again...I always fill it before it hits 1/4...
    bchctybob, Paul and loudbang like this.
  6. vtwhead
    vtwhead
    You are an inspiration Paul! Nice work, great tech and pics.
    Stogy, loudbang and Paul like this.
  7. kidcampbell71
    kidcampbell71
    Unbelievable. The tank fitted to a turtle deck, perfectly. Maybe one sock too many.
    "Tank" you for the tech' post.
    Interesting your bit set. I have a similar left hand turn 6" bit set, for aircraft. Wisconsin made. Love them.
    bct, Stogy, brEad and 3 others like this.
  8. jay t.
    jay t.
    Nice work Paul, will the inside of the tank get coated with anything?
  9. jay t.
    jay t.
    Oh and what gauge metal is it? Thanks
    Stogy and loudbang like this.
  10. Paul
    Paul
    Editor
    Thanks,
    Probably not. Maybe.
    I'll keep an eye on it, if it shows any signs of rust I will have to do something about it.
  11. Paul
    Paul
    Editor
    18 gauge
    bchctybob, Stogy and loudbang like this.
  12. jay t.
    jay t.
    I was going to buy an aluminum fuel cell for my project but might try building a tank first. Just worried about the rust issue.
  13. gonzo
    gonzo
    If you decide to line the tank I've had really good luck with Caswell tank sealer. It's the only stuff I've found that will consistently hold up against ethanol.
    Stogy, brEad, loudbang and 1 other person like this.
  14. Paul
    Paul
    Editor
    Thanks
    Stogy, loudbang and gonzo like this.
  15. Paul
    Paul
    Editor
    Fuel level sender and fill neck came in the mail.
    I cut and drilled holes for the sender,
    tacked the ring I had made earlier in place,
    modified the sender to fit my tank
    and temporarily bolted it in place to test fit.
    PXL_20210226_184457305.jpg PXL_20210226_185616772.jpg PXL_20210226_193955066.jpg PXL_20210226_194001715.jpg PXL_20210226_195611491.jpg PXL_20210226_195620220.jpg
    The 39 guy, AHotRod, brEad and 7 others like this.
  16. Paul
    Paul
    Editor
    Cut a hole in the turtle deck for the filler neck,
    marked and cut a hole in the tank
    and welded the neck to the tank,
    and checked fit and look.
    I think this will do.
    PXL_20210226_203357606.jpg PXL_20210226_204517749.jpg PXL_20210226_204842780.jpg PXL_20210226_211939719.NIGHT.jpg PXL_20210226_213700028.NIGHT.jpg PXL_20210226_213520024.NIGHT.jpg
    Just Gary, AHotRod, brEad and 14 others like this.
  17. Part Timer
    Part Timer
    Looks good Paul
    It’s truly amazing how much room our T’s DON’T have!! Seeing your fuel gauge sender made me question my decision to not put in a fuel gauge (only a little). Makes it more like a motorcycle. I watch the odometer, but my sore *** is also a good indicator! Enjoying your build thread.
    Mike
  18. gbones32coupe
    gbones32coupe
    You do nice work I like how you used the wood to bend it the way you wanted it in the jig you made fancy
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  19. Paul
    Paul
    Editor
    Tank all welded up and pressure tested.
    AHotRod, Shadow Creek, brEad and 14 others like this.
  20. dumprat
    dumprat
    from b.c.
    Looks great!
    loudbang, Paul and Stogy like this.
  21. Stogy
    Stogy
    'Paul's Hotrod Shop'
    The Motto
    'I Drive what I Build like a Hotrod'
    :rolleyes:...I can see the sign now...thanks for sharing Paul...;)
    The Turtledeck tank...that's where the tank was with the stick...I think it was 1/2 the width or less of the trunk on the right side...
    I am going to find those pics...they were Coupes...
    Hambtastic Eh!!
    loudbang, Paul and triumph 1 like this.
  22. Paul
    Paul
    Editor
    Snagged this 'bird rear seat off craigslist yesterday,
    it might work..
    -if it looses about twelve inches across the seat
    I think it's a '61 or '62 so it fits the era I'm shooting for..
  23. That tank is killer, nice work!
    loudbang, Stogy, Paul and 1 other person like this.
  24. Paul
    Paul
    Editor
    threw together a cradle to set the tank in
    just gotta fab up something to hold it in place and I can move on to the next project
    PXL_20210303_000958050.jpg PXL_20210303_004826361.jpg PXL_20210303_004835909.jpg
    AHotRod, 51box, Graham08 and 15 others like this.
  25. Paul
    Paul
    Editor
    Played with wheels and tires
    Blasted a pair of 15x5 Ford wheels for the front
    and a pair of 15x6 Olds wheels for the rear.
    Shot the fronts with Zero Rust non flat primer followed by Rust-oleum gloss black.
    front tires, 5.60-15 Coker Cl***ic 2.75 WWs came yesterday.
    Pushed new valve stems in the wheels and wrestled the tires on.
    Used a ratchet strap to force the tire beads out to the rims,
    Filled to 26 psi, washed, dried,
    and balanced.
    one took 2.25 oz and the other took 2.5 oz
    and mounted.
    gotta wait for it to stop raining to paint the rears..
    PXL_20210314_171615861.jpg PXL_20210314_171620239.jpg PXL_20210314_171636242.jpg PXL_20210314_175256720.jpg PXL_20210314_175948389.jpg PXL_20210314_180339962.jpg PXL_20210314_183123298.jpg PXL_20210314_184138996.jpg PXL_20210314_184143702.jpg PXL_20210314_185821304.jpg PXL_20210314_191414387.jpg
    Just Gary, bchctybob, brEad and 17 others like this.
  26. rob-redm
    rob-redm
    oh yeah ! I'm digging it.. looks great Paul
  27. Nice
  28. Paul
    Paul
    Editor
    Rattle can job for sure but they should do just fine.
  29. dumprat
    dumprat
    from b.c.
    Look a nice to me!
  30. AHotRod
    AHotRod
    Watching you makes me want to make a Hot Rod from scratch, I love fabricating.
    Very nice craftsmanship Paul.
