Hot Rods Let’s see some more overrated Hemis!
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Feb 26, 2021.
  1. It’s from Hot Heads
    Deuces, loudbang and Eh-Bone like this.
  2. GordonC
    GordonC
    Man you guys are brave souls hanging that much expensive hardware off an engine stand without any other support! I'd be scared to death the bolts would pull out and all that money would be sitting on the floor. Hell, I even put a support at the front for my puny ***ed flattie short block!
  3. hemihotrod66
    hemihotrod66
  4. Brand Apart
    Brand Apart
    from Roswell GA
    Here's mine.not sure if it's overrated as I have yet to run it. Ignore the distributor hold down and the fact it was machined @ the shop a the late great Chevy engine guy Lamar Walden. Hopefully this is the year it's running and Dyno tuned by Rob Walden his son who is keeping the family business running strong. Great people to know and deal with for generations. image.jpeg
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
    1957 Imperial 392, matched set of primary and secondary 1963 AFB's on a Weiand manifold.
    KK
  6. 241 was in my T RPU many years before i got it. JW
  7. mickeyc
    mickeyc
    I agree 100% with you Gorden. The majority of engine stands are made with
    thin wall tubing and are in the same vane as jack stands. I build my own
    engine stands or have bought a couple that are obviously well built and
    robust. Not claiming to be an design engineer by any means. I do have
    confidence in my abilities to build or evaluate an adequate engine support
    to my satisfaction. I did have a structural engineer acquaintance check out
    the two I have on hand. One I built and one someone else built. Both were
    were up to his approval standards. I do know of a couple that failed
    under heavy engine ***emblies. I also support the front of the motor as well.
    Deuces, loudbang and GordonC like this.
  8. BrandonB
    BrandonB
    from nor cal
    Hemis are like pretty women, they don't really need any makeup.
  9. Rooster72
    Rooster72
    sooo many cool versions , really dig the Ford with 2 blowers
    chryslerfan55, loudbang and Deuces like this.
  10. slayer
    slayer
  11. Minnesota
    Minnesota
  12. woodsnwater
    woodsnwater
    from North Al.
    I never p*** on an opportunity to show a pic of mine.
  13. 4tford
    4tford
    392 in my 40 ford
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    ......Completely.......
  15. Jeff Norwell
    Jeff Norwell
    MODERATOR
    ....Overrated..........
  16. Bandit Billy
    Bandit Billy
    ^^^^Beautiful!!
    Deuces, loudbang and Jeff Norwell like this.
  17. AndersF
    AndersF
    When i bought my first Hemi my friends thought i was dumb to drive with that old ****.
    Then it got a bit cool that i have that old ****.
    And now they are overrated. Oh well, i guess i will stick with them for a while more.
    The 53 Dodge that started it all. I bought it dec 86.
    A 140 hp 241 Hemi with 3 spd manual.
    My wifes Dodge 56 D500 she bought in mars 89.
    A 260 hp 315 with a 2sp Powerflite automatic.
    My other 53 Dodge sparepart car. 241 and 3 sp manual.
    One of my spare Red Ram. A 55 270 with 170 hp. Here mated to a Ford 3sp for my hotrod.
    I had a spare 241 but it was sold to a friend that needed something overrated to his Mercury-49
    instead for the overrated flathead it had.
    Some spareparts couse i cant trust that the dealer have any left.
    Not all is gold but try to collect spareparts if i can afford them.
  18. phat rat
    phat rat
    Curious did you buy or make that thermostat housing? I made mine it's a bit different from yours. EF_mwd8XkAA3r_A.jpg
  19. 4tford
    4tford
    Bought it from hot heads
    Deuces, chryslerfan55 and loudbang like this.
  20. RmK57
    RmK57
  21. saltflats
    saltflats
    from Missouri
    Here's mine :)
    slayer, Deuces, loudbang and 2 others like this.
  22. Dee Simmons
    Dee Simmons
  23. LOU WELLS
    LOU WELLS
    from IDAHO
  24. phat rat
    phat rat
    When I asked the question above about the thermostat housing I referenced the wrong post.
  25. dwollam
    dwollam
    In my current project, '33 Plymouth PD Coupe
    Dave
  26. Mark Grabo
    Mark Grabo
    from Upstate NY
