Projects Straight Axle 63
Discussion in 'Traditional Hot Rods' started by DanVI, Feb 15, 2020.
  1. DDDenny
    Dan
    Some of the early 66 production L79 blocks were a "721" and then the "362" finished out the run through 67.
    Thor1 likes this.
  2. TheSandman
    TheSandman
    Very cool build! I looking to start my first g***er build soon as well!
    Thor1 and loudbang like this.
  3. Rooster72
    Rooster72
    That body stand is a great idea
  4. FatBob
    FatBob
    Tunnel ram looks good Dan, changes the whole look of the engine bay! Saw someone mention putting the battery in the front, glad to see you have it in the back where it belongs on a hot rod!
    greasemonkey54, Thor1 and loudbang like this.
  5. DanVI
    DanVI
    Well it has been a hell of a long time since posting. I have been tinkering and have made progress. I am hoping to be on the road in the spring!
    I have wired the car, finished up the drivetrain and installed the interior which are big steps.
    I have also paint matched the few spots that had the paint removed. The match is good although the shine is off. I wetsanded and polished the entire car before installing the front and back gl***. I ended up taking the glossy finish down with grey scotch brite.....waaaaay to shiney for this guy. The trim, handles are all on along with the bumpers.
    More recently I finished plumbing the trans and fuel lines to the mechanical fuel pump and am working to finish up brake line plumbing as well as oil pressure/water temp senders.
    Oh and I found a good running used 283 (yes 283.....) from a buddy. I regasketed it completely and added a set of worked over "601" 53cc 1.84/1.50 cylinder heads. Thanks to fatbob for the "256" cam and lifters. The drivetrain is installed and complete ready for the first fire up in the spring.
    I probably forgot a bunch but she is getting close!
  6. Thor1
    Thor1
    Dan,
    Your car is looking fantastic! Can't wait to see more updates.
    Steve
    loudbang and mad mikey like this.
  7. mad mikey
    mad mikey
    Looking great, nice job. I bet you can't wait to fire her off.;)
  8. 6sally6
    6sally6
    Look'in like a hot rod!!!!!!!!
    6sally6
    Thor1 likes this.
