Looking to Get Started...
Discussion in 'The Hokey Ass Message Board' started by Tribalmonkey, Dec 14, 2020.
  1. I'm loving the progress you've made. I love those old banger coupes
    lothiandon1940 and loudbang like this.
  2. alchemy
    alchemy
    Flip the cowl lights side for side so they droop down. I saw that on another HAMBer's car. Looked cool if you insist on keeping them.
  3. drdave
    drdave
    Interior isn’t so hard a job. I got a kit from Mac’s and it is fitting great. Very pleased with the quality and fit.
    loudbang and lothiandon1940 like this.
  4. Tribalmonkey
    Tribalmonkey
    Thanks greasemonkdy54 - I am really having a blast. Working on it is fun but driving it around is really the best part.
  5. Tribalmonkey
    Tribalmonkey
    alchemy - Yes, I have seen them flipped up side down. I might eventually do that.
  6. Tribalmonkey
    Tribalmonkey
    drdave - Good to know. Did you use the Cartouche kit? Does it come with upholstery or just the backers? Sounds like something I should check out. I think it is going to be a rabbit hole for me though. I’m sure that when I peel back what I have in there now I will find more work. Rust, paint, seals....
    drdave likes this.
  7. Tribalmonkey
    Tribalmonkey
    Just ordered a Smithys muffler.
  8. gbones32coupe
    gbones32coupe
    That is good to take your 13 year old boy out for a cruise I remember doing that with my brother just a few times when I was younger the model a never ran good with the 2 four barrels so it kept my brother from driving it but I remember those rides were the best. Something happens when you are young and ride in one of these cars. I know it effected me. That feeling of a real time machine. The rumble and shake the smell. Burning paint on the headers and gas and exhaust smell in the air. hanging your arm out the window. Feeling the wind roll through the cab fuzzy dice blowing in the wind. It paints a picture for a kid that is unforgettable.
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  9. Tribalmonkey
    Tribalmonkey
    Tim, Gerald Sleater, drdave and 4 others like this.
  10. tb33anda3rd
    tb33anda3rd
    I always laugh at the misconception that mechanical brakes can't possible work and it takes balls to use them. cut a couple "lines" on a mechanical brake and you still could stop. try that with hydraulics.:cool:
  11. Tribalmonkey
    Tribalmonkey
    Started to remove the windshield to install some new weather stripping knowing that it was gonna be a rabbit hole. First off the bolts holding the windshield frame hinge at the top just spun and wouldn’t come out. So I had my boys help me. That led to one of them breaking off my p***enger side cowl light. IMG_5460.JPG
    Then I had to start taking out the (****py) interior panels (read headliner) to get to the backs of the bolts that were spinning.
    That led to the discovery that above my windshield/headliner it was stuffed with ‘stockings’ and towels.
    And a key - felt like an archeologist. [emoji2]
    Some days I should just stay in the house and read a book. Ha!
    Tim, drdave and lothiandon1940 like this.
  12. Tribalmonkey
    Tribalmonkey
  13. Tribalmonkey
    Tribalmonkey
    My wife went immediately to the possibility that ‘Pappy’s’ previous owner was a serial killer and he collected the stockings from his victims. “The Stocking Murders” she can be a bit creative.
  14. More likely, the sox etc prevented the top material from flapping in the breeze
    and the key was a spare, try it in the pop out ignition switch!
    Or maybe the former owner had something on the side!
    Tribalmonkey likes this.
  15. Tribalmonkey
    Tribalmonkey
    Fits in the rumble seat lock but doesn’t turn :-/ IMG_5476.JPG
  16. Tribalmonkey
    Tribalmonkey
    Tim, Gerald Sleater, drdave and 3 others like this.
  17. Tribalmonkey
    Tribalmonkey
    What is the best way to remove all of this petrified rubber?
  18. Tribalmonkey
    Tribalmonkey
    Seems like a torch might do it but I’m afraid it might crack the windshield. IMG_5492.JPG
  19. lothiandon1940
    lothiandon1940
    I would take a putty knife and gently tap it to try and remove that spent rubber. Like you mentioned, I would be reluctant to use a torch. What would soften that rubber and help it to release? That's another question.
    Tim, lothianwilly71 and Tribalmonkey like this.
  20. Tribalmonkey
    Tribalmonkey
    Thanks Don. Not sure if you can tell but I lack patience sometimes. Gently with a putty knife will take a lot of self control. I’ll try. [emoji2]
  21. lothiandon1940
    lothiandon1940
    I might try a blow drier or heat gun to try and soften the old rubber, but be careful not to get too close to that gl*** or "another rabbit hole"!:eek:
  22. Dick Stevens
    Dick Stevens
    We used to make a tire prep when we raced gokarts that was equal parts acetone, mineral spirits and ATF, it will soften up rubber then use either a razor s****er or sharpen a putty knife so that it will cut the rubber, if that doesn't get it soft enough you could try a hair dryer after the fumes from the prep have dissapated!
    drdave and Tribalmonkey like this.
  23. Tribalmonkey
    Tribalmonkey
    Thanks ****. I’m open to all suggestions on this one.
    This seems to be working. Really slow though
  24. atch
    atch
    That's too bad. I was hoping it was one of Jason Bourne's keys to a locker that had money and guns and p***ports in it.
    Brake fluid will soften rubber. It also will dissolve paint, so don't get it anywhere you don't want paint ruined.
    I've never heard of or used the concoction that Mr. Stevens mentioned. It sounds like it would be pretty effective, though.
    b-t-w; after you've got all of it off that you can by s****ing I bet a wire wheel on a 4" angle grinder will clean the metal up to bright and shiny. I'm ***uming that after s****ing you'll still have dried glue and rubber particles that haven't yet come off.
    lothiandon1940 and drdave like this.
  25. tb33anda3rd
    tb33anda3rd
  26. atch
    atch
    If the sox don't fit you must acquit...
    bchctybob and drdave like this.
  27. Tribalmonkey
    Tribalmonkey
    Haha!
  28. Tribalmonkey
    Tribalmonkey
    Now I’m wondering if I should replace with safety gl*** while I have it out
  29. drdave
    drdave
    Yes, I got the Cartouche kit. Came with everything....seat covers, padding, upholstered door panels, headliner, wind lace and all the other misc covered panels. The parts I have done have fit great. Like you, it’s easy for me to run down the rabbit hole, so there are parts of the interior I won’t be doing for a while because one part “begats” the next and then I’m into rebuilding windows and window tracks, which get to paint while it’s apart, which gets to top insert which gets into.... lol
  30. bchctybob
    bchctybob
    On the broken cowl light, I just took the cowl lights off of my Model A and I used snap-in hole plugs; aka ch***is plugs or Butch plugs available in those convenient little hardware drawers at Ace Hardware. I painted them with a Rustoleum red and popped them in, almost a perfect match with the paint and it looks so much more hot roddy.
    Tribalmonkey and lothiandon1940 like this.
