Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
    I think this will finish the sides off well and allow the wood to move. IMG_1692.JPG
    dwollam, TFoch, brEad and 6 others like this.
  2. tb33anda3rd
    tb33anda3rd
    brought the bed over to Charlie's to test fit it and get the measurements we need for the crossmember. and mounting braces. thumbnail-5.jpeg thumbnail-6.jpeg thumbnail-7.jpeg thumbnail-11.jpeg thumbnail-10.jpeg
  3. tb33anda3rd
    tb33anda3rd
  4. tb33anda3rd
    tb33anda3rd
  5. tb33anda3rd
    tb33anda3rd
    note Charlie's "new " wheels and tires.
    battery went dead in camera so sorry for ****ty phone pics
    dwollam, TFoch, Stogy and 4 others like this.
  6. FolksWaggin
    FolksWaggin
    Just ran some oak boards through the planer so Ted can build the floor of the pickup bed.
  7. FolksWaggin
    FolksWaggin
    dwollam, loudbang, Stogy and 3 others like this.
  8. Stogy
    Stogy
    Mmmm...Bias Plys...;)
  9. Stogy
    Stogy
    Breathing Holes...them ****ers gotta duck when the blades are coming at them eh! 6 legged Drill bits​
    dwollam, brady1929, loudbang and 3 others like this.
  10. TFoch
    TFoch
    Great progress! Lookin' great!!
  11. tb33anda3rd
    tb33anda3rd
    awesome thanks!!!!!
  12. Stogy
    Stogy
    What a Handy Branch it's been did you count the rings...
  13. tb33anda3rd
    tb33anda3rd
    I never did count the rings. I only have a few small pieces left. :cool:
    loudbang, TFoch and Stogy like this.
  14. Stogy
    Stogy
    The Truck and that Tree have known each other for years and neither knew they would meet by accident...were United in Repair by a Team of Craftsmen...some with funny names like Slacker...They Cruised off into the Wild Blue Yonder...with Charlie Hummin A Tune with a Smile a Mile Wide...
  15. FolksWaggin
    FolksWaggin
    Anytime!
    tb33anda3rd, loudbang and Stogy like this.
  16. The37Kid
    The37Kid
    Never ran a plainer, how many p***es did it take to get them to finish thickness? Bob
  17. FolksWaggin
    FolksWaggin
    These boards were all pretty close in thickness to each other, and the saw marks weren’t very deep, so I think it took me about 6 p***es total—a few p***es on each side. You can take more material off on the first p*** or two, and then you have to turn the dial down to only take about 1/32 or 1/64 of an inch on the final p***es on each side to get a smoother finish.
    dwollam, Stogy, tb33anda3rd and 3 others like this.
  18. NashRodMan
    NashRodMan
    This truck has come a long way! Looking great. You saved one that many would have thrown away. :cool:
  19. tb33anda3rd
    tb33anda3rd
    I have the wood laid out, I have a couple extras in case I make a mistake. IMG_1724.JPG IMG_1725.JPG
    brEad, dwollam, TFoch and 7 others like this.
  20. tb33anda3rd
    tb33anda3rd
    this is a picture Charlie has been using as his inspiration.
    Gotgas, dwollam, TFoch and 4 others like this.
  21. The37Kid
    The37Kid
    Will the boards be free floating or will you add biscuits'? I've got a DeWalt cutter if you need one. Bob
    TFoch and loudbang like this.
  22. tb33anda3rd
    tb33anda3rd
    the boards will be clamped down with bed strips. I will cut a bevel down each side of the boards .
    ct1932ford, TFoch, nunattax and 2 others like this.
  23. tb33anda3rd
    tb33anda3rd
    went to the slacker's to fit the pieces I made. he has decided to not raise the bed an inch so I had to change my design. I will need to make the side pieces longer and run the brace behind the shocks instead of above. IMG_1726.JPG IMG_1727.JPG
    brEad, Stogy, dwollam and 3 others like this.
  24. tb33anda3rd
    tb33anda3rd
    he has been busy. he put the front fenders on and the light bar and was working on wiring the head lights. IMG_1728.JPG
    brEad, patmanta, Stogy and 8 others like this.
  25. tb33anda3rd
    tb33anda3rd
    he also found these cool running lights that will get mounted to the top of the fender. he cleaned them up, rewired them, new sockets and some paint. IMG_1731.JPG IMG_1732.JPG IMG_1733.JPG electrlite
    brEad, patmanta, Stogy and 6 others like this.
  26. tb33anda3rd
    tb33anda3rd
    I went back to my shop and bent up some longer side angle and welded the notches I put in the cross brace back in IMG_1736.JPG
  27. tb33anda3rd
    tb33anda3rd
    I took the boards and decided which side s would be the face side, then cut the best end square. IMG_1737.JPG
    Stogy, dwollam, TFoch and 3 others like this.
  28. tb33anda3rd
    tb33anda3rd
    I then marked for the rabbets that will run down each side of the boards. there will also be a 1/4" space between the boards to allow the carriage bolts to p*** between them. I then set the fence to 5/8" and lowered the blade to a 1/4" and made the face cut on the boards. IMG_1739.JPG
    brEad, Stogy, dwollam and 7 others like this.
  29. nunattax
    nunattax
    what about similar grooves on the underside to try and prevent cupping at least 3!.
    Stogy, tb33anda3rd and loudbang like this.
  30. tb33anda3rd
    tb33anda3rd
    I know they use grooves on the underside of flooring but I have never seen it on truck bed wood. maybe because the bed wood is exposed to the air on both sides and flooring gets trapped against another surface with only one side exposed? interesting thought and I could just run a few with my router and a beading bit.
    Stogy and TFoch like this.
