Hot Rods The all inclusive,almighty Y block thread
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 16, 2021.
  1. jimmy six
    jimmy six
    Nice. Tim I no longer need a vacuum pump on the fuel pump. Which one do you recommend since I see there was not one on the engine. Thanks...
    1stGrumpy and loudbang like this.
  2. junkyardjeff
    junkyardjeff
    I am putting another 55 272 back in my Sunliner,its getting the B intake along with 57 and up exhaust manifolds and distributor. I also have the better rocker arms and will be getting a PCV system. 100_9567.JPG
    warbird1, loudbang and williebill like this.
  3. You can buy one from rock auto just search for 1964 F-100 with a 292 parts.
  4. jimmy six
    jimmy six
    Thanks Tim. there is so much said about FE pumps I thought it might be one of those.. as a side after I removed and cleaned the oil pump/byp*** relief, installed a PVC system and appears the oil leaking from the real seal is gone or very minimal. Thanks for your help..
  5. Are they posted?
  6. Here is a little story I wrote for Y-Block magazine. It's a bit of a long read but I thought you guys might like it too. [​IMG]
    A Tale of Two Trucks
    By Tim McMaster
    “It was the best of times, it was the worst of times, it was the age of wisdom, it was the age of foolishness………” and so it goes. I have been asked many times why I am interested in Y-Blocks, after all I am so young (age 56, born the year Y-block production ceased in the US 1964). My frivolous answer is “I grew up in and around them so it seeped into my blood”. Truth is I was raised on a citrus farm in central California where we had a 1960 F-600 with a 292 and a 1964 F-100 with a 292 that was one of the first vehicles that I learned to drive in.
    “the best of times” Truck number one. I recall vividly riding between my Father and my Uncle Frank in that ’60 F-600 hauling a load of oranges to the Blue Goose packing house in Strathmore CA. It was the late 60s and you as the farmer were still responsible for getting the fruit to the plant. I would get out and as my Father and uncle would go about their business I would roam the packing house watching in awe the people sorting and packing, the boxes going down roller ramps and conveyor belts to reach their final destination, another larger truck where they were loaded and shipped all over the world. Then, before leaving, my Dad would buy me an ice cold 10 oz. bottle of Frosty root beer. I can taste it now. After 1970 though the “Citrus ***ociation” started sending large diesel trucks with 4x4 field bins to the orchards to get the fruit and do the hauling job. Gone were the days of the smaller “lugs” that we were so familiar with and the old wooden boxes became building blocks for forts for us kids. The old F-600 was then relegated to the job of pulling trailers with equipment to the various orchards in our little area of Terra Bella.
    “The worst of times” After many years of performing the thankless task of equipment hauler the F-600 was getting a little tired. It was 1991 and my Uncle Frank asked me if I could take a look at it and see if I could improve the power a bit. I had since gotten older and a little more experienced and was working in a machine shop building engines and I figured myself a pretty good mechanic by that time. I told him I would take a look and he told me how the neighbor, a line mechanic for the CHP, had rebuilt the carburetor and it was running better but not perfect. Upon opening the hood I first notice that the engine had been modified with the all popular band aid external oiler kit to the rockers. It had been a while since I had spent much time at “the ranch” so I was not familiar with the caring for and maintenance of the old truck and who had been doing it, but I did know of the “Mickey Mouse” fix and I did not approve. Upon removal of the valve covers I was greeted with a broken rocker shaft on the driver’s side. My Uncle had been driving this truck for years on six cylinders! Always short trips of only a few miles but a testament to the power of the ol’ Y that it did the job adequately. I decided we would pull the heads and go through them, as well as, rebuild the rocker ***emblies. With the heads and the valley pan removed I recalled an article in Hot Rod magazine from a few years back where they showed how to remove the cam from a Y-Block without pulling the engine by holding the lifters up with old wooden clothes pins. With this in mind I dropped the pan, removed the timing cover, and poked the lifters up one by one while my Uncle clipped each one in place. Worked like a charm! I then slipped the cam out and inspected the center cam bearing. My uncle told me that the truck received a replacement engine in the late 70s and it had those oiling tubes from the start. This led me to believe that the cam bearing was installed incorrectly during rebuild (something I would see many times in the future, a common problem with sloppy rebuilders). I didn’t want to beat on the engine to replace the bearing as I thought the lifters might fall so I just took a long 1/8” drill bit, ran it down the feed hole in the block and put a hole in the side of the bearing as it was in the block. My Uncle seemed impressed with my action and I thought of myself as quite clever, after all there was no internet at the time for me to look for this stuff.
    The heads were rebuilt at the shop I was working for, and the engine was re***embled with the old cam back in place, clothes pins pulled and the timing chain reinstalled. Twelve pins of course. When all was complete the 292 came to life and purred like it hadn’t in years. My Uncle was quite happy and decided it was time for a test drive. The next thing I knew, my 70 year old Uncle was jamming gears down Ave. 80 with my 72 year old Father on the bed holding onto the head board. It was quite a sight, two old men acting like kids again. When they returned, Uncle Frank told me they had the old Ford up to 70 mph “that truck hasn’t been that fast since it was new!”
    All was right in the world again and later that year he let me use the truck in the Visalia Christmas parade to pull the Jaycees’ Santa Claus float. Good times.
    “Better times” Truck number two. In 1985 I went to work for Hanford Auto Supply as a machinist grinding crankshafts, I had learned this skill at Automotive parts Co. in Visalia but was lured away by my old boss Leonard Tripp with the promise of double pay so I left for greener pastures. In my first year there I was asked to do a number of other things that wasn’t in my job description but when the boss says to do something you do it. One day I was told to go to the old man’s warehouse In Avenal, some 40 miles to the west of Hanford, to put some stuff in storage. I had not yet been to this treasure chest of a building. But when I arrived I found inside all manner of things related to machine work, old engines, V8-60 race engines and best of all a 1959 F-600. I thought to myself this was almost like the one my Uncle Frank has. How fun would it be to have an old two ton truck? When I returned to the shop I asked the boss about the truck and he told me how he bought it at a city auction in 1974 and how he built a 312 for it to replace the tired 292, he used it for many things like hauling equipment when he moved the shop from 116 E 6th street to the current location of 200 E. 6th street but after a few years it wasn’t needed and he just stored it away. I let him know my interest in the truck and if he ever wanted to sell it I would like to have it.
    20+ years later the boss was selling his warehouse and needed to clear it out. I asked what he was going to do with the ’59 F-600 and he told me that his son wanted it and was getting it running to move it to Coalinga. Darn! I wanted that truck still after all these years but it was not meant to be, not yet anyway. The truck was moved from a nice indoor storage to a lot out in the open where it sat for another ten years, the boss’ son did nothing with it except let it sit.
    In 2015 after working for Leonard Tripp for 30 years the old man p***ed away at age 94, after spending his last day working at the shop, not a bad run. He had considerable ***ets but the shop really wasn’t one of them and no one in the family wanted the place. I hadn’t looked for a job since I was 18, so I really didn’t want to at 51. The family made me a good deal on the property and now I own the place. Then one day the old man’s son called me and asked “do you still want that old Ford flatbed?” It wasn’t part of the deal for the shop but for a little extra cash I now had, after waiting 30 years, my F-600. I went over to Coalinga on a Saturday morning with a little gas and a new battery and with little effort the truck was up and running. Now, will it make the 40 mile trip back to Hanford? It ran very well all the way back to the shop although it did smoke a bit. No worries, I’m well known for not leaving things as is when I acquire a new vehicle. After all, I do own an engine rebuilding shop.
    I have quite a collection of Y-Block parts and cores, I build engines for others and make a good living plus pay for my racing exploits. I wanted to build an engine for the “two ton” but didn’t want to use stuff that I can sell for profit to a customer. The idea for my “junk motor” came to mind. I would use the less desirable stuff I had, saving the good stuff for customer builds. I had a 312 block that needed three sleeves and was already .060” over, not the best but I can use it. I had a 312 crank with a burnt rod and was .030”/.030” under already, not the best but I can use it. I had a set of ECG-H heads that nobody really cared for but I can use them. The block was sleeved and bored to 3.905” as I had a set of .030” over 307 scrub pistons that would work for me. I ground the mains on the 312 crank to .040” under and offset ground the rods to 2.100” and a stroke of 3.5”, with a set of 6.2” aftermarket rods the 307 pistons came just even with the deck. This combination gave me 335 cubic inches. The heads came from the factory with 1.78” intake valves but I cut them out for the larger 1.92” intakes and cleaned up the ports and bowls to take advantage of the larger valves. Everything in the heads were old, used but still serviceable. I did use new heavy valve springs and hard ex seats but that just makes sense. A special reground camshaft was used with refaced lifters. Truth be told the cam is probably not right for a big truck but it sure sounds good. Topped with 1.54:1 rockers and a “B” intake the engine was installed with a set of rams horn exhaust and a 600 cfm (reman) 4160 Holley carb. How did it run? Great! I use this truck for everything from hauling s**** to the recycle yard, bringing home new Model A projects, even trailering the Y-Block powered dragster to the races and pitching a tent on the bed for camping. I’ve had this truck to 90 mph (gps backed) with the stock gearing. It really screams, probably my best demonstrator as to the quality and power of my Y-Block builds. Better than my 192 mph roadster. And I finally got it over to “the Ranch” to have a photo op with the original F-600 that my Uncle bought brand new in 1960 and although he and my Father have long since p***ed, my Cousin still works the truck on the farm some 60 years later. My personal Y-Block powered F-600 hauler, and the truck I rode in as a kid that would infect me with the Y-Block disease.
    There is continuity in life.
    150554970_10225577011719151_87074352274603554_n.jpg 150586616_10225577012439169_8195408906184293933_n.jpg 149922164_10225577013799203_8249192267149930949_o.jpg 14364626_1112280512171397_8152177220026396526_n.jpg 155001627_3754687517930670_792802042790980610_n.jpg
  7. silent rick
    silent rick
    i mis-read the part about growing up on a citrus farm and thought i read circus farm. i thought to myself @mctim64 comes from carny folk, that's why he likes Y blocks
    Spooky, UNSHINED 2, Jrs50 and 6 others like this.
  8. guthriesmith
    guthriesmith
    loudbang, egads and silent rick like this.
  9. Spooky, loudbang, egads and 2 others like this.
  10. sidevalve8ba
    sidevalve8ba
    I don't know. How do I tell?
    46international and loudbang like this.
  11. warbird1
    warbird1
    sidevalve8ba, loudbang and egads like this.
  12. egads
    egads
    loudbang and guthriesmith like this.
  13. warhorseracing
    warhorseracing
    from cameron wv
    I think he means "ported". Maybe he will come back and clarify what "posted" means if not
  14. jimmy six
    jimmy six
    Its a factory cast “post” in the water jackets for strength. Probably not needed for your typical street engine but a must if you mill the heads for added compression. There are sites on the net showing how to do it to non posted heads.
    I have. 57 set of 312” with the large valves non posted, not milled, and a fresh valve job ready to go for my 56 292 if I ever need them. But typical a smaller valve engine is better at low rpm for torque off idle.
    egads, loudbang and warhorseracing like this.
  15. 55blacktie
    55blacktie
  16. 55blacktie
    55blacktie
    Easy enough mistake to make, but I meant posted. My non-posted heads will be posted before installation.
  17. I have heard of people installing posts in these heads but it sounds kind of "micky mouse" what is your plan.
    silent rick and egads like this.
  18. 55blacktie
    55blacktie
    I recently spoke to Ted Eaton (eatonbalancing.com) who said that he posts all non-posted heads. There's nothing "micky mouse" about Ted Eaton. He also routinely mills heads .025. M-I-C-K-E-Y-M-O-U-S-E.
  19. jimmy six
    jimmy six
    Tim McMaster and John Mummert in California and Ted Eaton in Texas are included in the best with the Y-blocks. There are many others that also know how to make them run great and most build something for the Vintage Engine Shootouts of the past. The Yblocksforever.com site is full of ways to help out the user of these great engines.
    Spooky, loudbang, warbird1 and 4 others like this.
  20. You are correct, not a Mickey Mouse deal. People have been doing it for years, even back before you could get "posted" from the factory. "Posted", by the way, was a development of truck engines but when the NASCAR boys got ahold of a set they found they could push the old Y harder. A lot of good things come from racing unfortunately it's also what doomed the design as it couldn't keep up with rising displacement.
  21. egads
    egads
    ^^^^^^^^^^^^How is this done?
  22. silent rick
    silent rick
    yes, show and tell us
  23. 55blacktie
    55blacktie
    forums.y-blocksforever.com/Topic47592.aspx
    46international, mctim64 and loudbang like this.
  24. jimmy six
    jimmy six
    Like I said everything u ever wanted know about the YBlock is on that site. There is an engine bi-monthly magazine too which Ted and others write in. Complete manifold testing, dyno runs of rebuilds, etc... I look forward to it every other month...
  25. silent rick
    silent rick
    scary stuff. how thick is the surface at the bottom of the hole? you know, where you need to dimple with the drill bit so the jb weld stuff will adhere and anchor the bottom of the new post.
    Dirty Mule likes this.
  26. silent rick
    silent rick
  27. egads
    egads
    Do you feel this is necessary for a mild street engine?
  28. No. Not really needed till you get up to and over 10:1 comp. ratios.
    loudbang, egads and sidevalve8ba like this.
  29. 55blacktie
    55blacktie
    Ford recommended a maximum of .010 when surfacing; however, you can go .025 without posts. I look at it this way: Ford must have had a good reason to post G heads made after April, 57. The 113 G-head replacement also posted. If you are looking at a complete rebuild, not to OEM specs, like I am, why cut corners? I would, however, not attempt to do it myself, but leave it to someone who has done it, like Tim or Ted.
