Projects United Pacific 5W Deuce Build
Discussion in 'The Hokey Ass Message Board' started by Groovy, Feb 18, 2017.
  1. Groovy
    Groovy
    Fuel tank is ready to bolt down. Hood and grill are loosely fitted. Tail light sockets were checked for clearance... IMG_4150.JPG IMG_4151.JPG IMG_4152.JPG IMG_4145.JPG IMG_4148.JPG IMG_4147.JPG IMG_4160.JPG
    Stogy, Desoto291Hemi, alfin32 and 4 others like this.
  2. Groovy
    Groovy
    Fuel tank straps are bolted in.
    Had to remove the rad and drill new mounting holes to move the bottom of the rad closer to the firewall. I used the holes that were fitted and that made the bottom of the hood sides 3/4" wider than it should have been. Drilled a new hole in the rad mounting tab to move it 1/2" closer to FW. IMG_4169.JPG IMG_4161.JPG IMG_4162.JPG IMG_4163.JPG IMG_4164.JPG IMG_4167.JPG IMG_4168.JPG IMG_4166.JPG
    Stogy, wicarnut, alfin32 and 5 others like this.
  3. Groovy
    Groovy
    Fuel line is fully ****oned up along with vent tube.
    Rad hoses are trimmed and installed.
    E-brake cables are secured to handle and cable is held in place so it doesn't touch drive shaft... IMG_4187.JPG IMG_4188.JPG IMG_4189.JPG IMG_4190.JPG IMG_4180.JPG IMG_4182.JPG IMG_4181.JPG IMG_4200.JPG
    Stogy, wicarnut, alfin32 and 3 others like this.
  4. Groovy
    Groovy
    Seat belt hoop is installed.
    Fitted rear roll pan to check fit & trimmed fuel tank check valve bracket... IMG_4207.JPG IMG_4202.JPG IMG_4203.JPG IMG_4204.JPG IMG_4201.JPG IMG_4209.JPG IMG_4211.JPG IMG_4205.JPG
    Stogy, wicarnut, alfin32 and 4 others like this.
  5. pprather
    pprather
    I like the roll pan. Whose product is that?
    Thanks.
  6. Groovy
    Groovy
    "MIG" IMG_1766.JPG IMG_1767.JPG DSC01084.JPG DSC01085.JPG DSC01097.JPG ... Made in garage. I made it myself.
    Stogy, Bcap55, Just Gary and 9 others like this.
  7. The 39 guy
    The 39 guy
    Looking good! Nice work !
    Stogy and loudbang like this.
  8. Groovy
    Groovy
    Today I made a change to the roll pan. I got lazy when I first made it and thought I wouldn't angle one line and after I fitted it knew right away how odd it looked so I trimmed it and rewelded a piece in. Next sand the filler and re prime. IMG_4209.JPG IMG_4222.JPG IMG_4223.JPG IMG_4224.JPG IMG_4227.JPG
  9. Groovy
    Groovy
    Wiring has started. IMG_4233.JPG IMG_4234.JPG IMG_4241.JPG IMG_4237.JPG IMG_4235.JPG
    Floor pan is riveted together...
    Stogy, wicarnut, brEad and 3 others like this.
  10. Groovy
    Groovy
    IMG_4252.JPG IMG_4253.JPG Gauges are wired... IMG_4242.JPG IMG_4243.JPG IMG_4244.JPG
  11. loudbang
    Nice clean wiring job. :)
  12. i.rant
    i.rant
    Impressive,detailed craftsmanship is not going unnoticed. Thanks for sharing.
  13. Groovy
    Groovy
    Roll pan tail lights have been wired.
    Head lights have been straightened up. Had to notch swivel joint to turn the top outward.
    Wiring is slowly being routed to facilitate mounting trying to find best location.
    Rear window drip line installed.
    Roll pan line has be finished... IMG_4258.JPG IMG_4254.JPG IMG_4282.JPG IMG_4270.JPG IMG_4269.JPG IMG_4284.JPG IMG_4286.JPG IMG_4285.JPG IMG_4287.JPG
  14. Groovy
    Groovy
    Wiper had to have a bracket made to stop it from rotating. Regulator and resister are fitted.
    Horn bracket is built and remaining two wheels finally showed up and are installed... IMG_4330.JPG IMG_4329.JPG IMG_4318.JPG IMG_4331.JPG IMG_4332.JPG IMG_4327.JPG IMG_4324.JPG
  15. Fortunateson
    Fortunateson
    Keeps getting better (a little like the Canucks!)....
  16. Groovy
    Groovy
    Regulator & resistor bracket painted and installed.
    M IMG_4358.JPG IMG_4359.JPG IMG_4341.JPG IMG_4339.JPG IMG_4360.JPG ade an aluminum bracket to clamp e brake cables to the ch***is.
    Horns and brackets painted...
    Stogy, brEad, loudbang and 1 other person like this.
  17. 30tudor
    30tudor
    Very clean, very nice, very tidy. Love it.
    Are there silencers of some kind in those exhaust boxes?
  18. Groovy
    Groovy
    No silencers... Just some triangular wedges in the plenum to bounce the exhaust around?? I don't know if I am going with these exhaust but I need to get it running to check noise and decide if I keep them.
  19. The 39 guy
    The 39 guy
    I'm kind of late on this comment/question. Back on Feb 21 st you showed what I think it is a fuel tank vent. It looks like it is located inside the trunk. I would think it should be terminated outside. Are you concerned at all about fumes? I am not trying to be negative here. Maybe I canlearn something from you about vents. I have been enjoying your build. Your wiring is top notch btw.
    Nailhead Jason and loudbang like this.
  20. Groovy
    Groovy
    The vent as per the instructions should be mounted higher than the filler cap. Problem is on nearly all car applications where do you mount it where it is functional and out of sight. I knew there may be a problem with fumes but will see once it is on the road to see if there are any noticeable fumes. It will eventually have a paneled interior so this would be in the trunk airspace. Just another thing that I may have to rethink.
    Stogy, loudbang and The 39 guy like this.
  21. Dick Stevens
    Dick Stevens
    He said it is a check valve, which I think will allow air into the tank but won't allow fumes to come out. At least I hope that is the case as fumes are explosive and you wouldn't want fumes contained in the trunk area!
  22. pprather
    pprather
    My Deuce tank breather comes up through trunk floor near right wheel tub (behind upholstery). It goes up vertical about 8 " above floor, then I turns downward through floor.
    Yes, still fumes into garage at times.
    A charcoal filter or fume valve would help, but at least it doesn't vent inside body.
  23. You will get some smell from the check valve. Depending on how you seal the interior, it may not be a problem. I have used that on 3 different builds before. You are making nice progress. Some nice personal touches. :)
  24. Groovy
    Groovy
    Part of the wiring is finished and secured under dash. Engine side has been wired.
    Brake cable bracket is installed... IMG_4366.JPG IMG_4368.JPG IMG_4369.JPG IMG_4370.JPG IMG_4374.JPG IMG_4378.JPG IMG_4361.JPG IMG_4364.JPG IMG_4365.JPG
    Stogy, brEad, loudbang and 2 others like this.
  25. Groovy
    Groovy
    Dash wiring is mostly done. A wooded platform works great to hold the panel while working. Engine and headlights are done... IMG_4423.JPG IMG_4425.JPG IMG_4426.JPG IMG_4429.JPG IMG_4432.JPG
    Stogy, The 39 guy, brEad and 3 others like this.
  26. Groovy
    Groovy
    Rear roll pan is painted black. More wiring completed... IMG_4511.JPG IMG_4513.JPG IMG_4514.JPG IMG_4515.JPG IMG_4517.JPG IMG_4518.JPG IMG_4516.JPG
    Stogy, brEad, loudbang and 3 others like this.
  27. 30tudor
    30tudor
    Roll pan is beautiful as is all your work. Learned a lot on that f5 build I expect.
    Stogy, loudbang and Nicholas Coe like this.
  28. Groovy
    Groovy
    Roll panel has been installed to attach tail light wiring. Under dash wiring almost done and needs to be tidied up. Sand blasted some final parts and installed conventional headers to use for start up... IMG_4536.JPG IMG_4531.JPG IMG_4532.JPG IMG_4533.JPG IMG_4537.JPG IMG_4540.JPG IMG_4544.JPG IMG_4547.JPG IMG_4529.JPG IMG_4549.JPG IMG_4550.JPG IMG_4546.JPG IMG_4545.JPG
  29. Groovy
    Groovy
    Battery tray is welded up. Nylon rear frame / body mount installed. Licence plate bracket painted... IMG_4603.JPG IMG_4604.JPG IMG_4594.JPG IMG_4595.JPG IMG_4597.JPG IMG_4598.JPG IMG_4605.JPG IMG_4599.JPG IMG_4601.JPG IMG_4602.JPG
  30. Groovy
    Groovy
    Wiring is completed and dash is in place. Need to build a platform to sit my foot on to comfortably work the throttle... IMG_4660.JPG IMG_4661.JPG IMG_4665.JPG IMG_4662.JPG IMG_4669.JPG IMG_4673.JPG
