Technical 1940 Ford Radiator hoses sbc
Discussion in 'Traditional Hot Rods' started by Al Hampton, Mar 1, 2021.
  1. Al Hampton
    Al Hampton
    from Alabama
    I recently purchased a 1940 Ford Coupe with a 350 SBC. I need to replace the radiator hoses. I have looked at other threads but would appreciate your advice. The car has a Walker radiator. As can be seen in the pictures the hoses are larger than standard and are "bunched" up at the thermostat housing, water pump and radiator inlet/outlet. Please look at how the lower hose weaves under the sway bar and then another bend before attaching to the water pump. Thanking you in advance. Al
      204.6 KB
      186.2 KB
      165 KB
      143.3 KB
  2. leadsled
    leadsled
    At closer glance I can see on the upper hose at the thermostat the hose looks hand cut. I didn't catch that yesterday.
    Tim
  3. harpo1313
    harpo1313
    from wareham,ma
    Looks like your lower rad hose is collapsing at higher rpm. Is there a spring in there?
    dana barlow likes this.
  4. harpo1313
    harpo1313
    from wareham,ma
    Make a pattern out of heater hose the way you want it and start looking at the rack at the parts store.
  5. harpo1313
    harpo1313
    from wareham,ma
    heater air duct.
  6. olscrounger
    olscrounger
    Top hose--gates 21179--comes straight out then turns -use in all 40's with small block and walker radiator-bottom hose 57 Chevy V8
  7. slowmotion
    slowmotion
    Top side of the bottom hose, I'd hack a half inch off at a time to get that bend out of it, for the time being.....
    'Hack' being the operative word...:D
    Olscrounger got the goods.;)
  8. 42merc
    42merc
  9. 40Standard
    40Standard
    from Indy
    good tech, thanks
  10. Graybeard4545
    Graybeard4545
    from Maryland
    For the bottom hose, I used a 57 chevy V8 hose. Had to cut a little but fits great. My top I used a 45deg hose with a straight thermo housing. I don't have a lot of things in the way for the top hose, it was a straight shot.
  11. leadsled
    leadsled
    Looks like a 57 Chevy hose for the bottom. I'm sure Ms Keri can get one of those. If you use the Gates hose mentioned above, it may interfere with 3rd point adjustable rods.
  12. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    top hose is wrong diameter for the fittings.
  13. PONTNAK123
    PONTNAK123
    mr 40s fat stuff have the radiator hoses for a sbc in a 39 40 ford
    golferforpar likes this.
