Hot Rods Octane Ratings
Discussion in 'The Hokey Ass Message Board' started by TCATTC, Mar 3, 2021.
  1. TCATTC
    TCATTC
    Does anyone remember the octane rating of "Regular" and "High Test" fuel in the early 60's ?
    Deuces likes this.
  2. RmK57
    RmK57
    Premium would be in the lower-mid 90's but used tetraethyl lead additive to reduce knock.
  3. Mr48chev
    It depended a bit on what brand you bought. When I was driving my 51 Merc with the flathead in high school as long as the pump said "gas" on it it ran just as well on the cheap stuff as it did on the spendy stuff. My 55 Buick with the Super engine in it (Special with an engine swap) was another story. It wanted premium and was a bit picky about who's premium at times. It sure didn't run worth a hoot on my grandfather's farm gas.
    Deuces and VANDENPLAS like this.
  4. squirrel
    It also depended on what rating system you use to get the numbers. they've changed over the years...used to be a Motor number, and Research number, and the modern numbers are an average of the two.
  5. roseville carl
    roseville carl
    yea and it was .25 a gallon same as a pack of cigs..........
    Deuces, Chicster, mad mikey and 3 others like this.
  6. Jalopy Joker
    Jalopy Joker
  7. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    A9805812-A8EB-4553-8488-93204DC31465.jpeg In 1968, I was a young man of 21 years of age;I bought a 68 Plymouth Road Runner from a dealer in Temple.Texas;paid $2842.80 driveout. Super Shell 104 octane was $0.25 per gallon. Nobody cared your Road Runner, 396 Chevelle,Pontiac GTO, etc got 10-12 mpg; nobody cared!!!
    Deuces, 31hotrodguy and mad mikey like this.
  8. egads
    egads
    Don't know the octane rating but how many remember the Sunoco dail-a-matic pump's? [​IMG]?
  9. Elcohaulic
    Elcohaulic
    Premium 100 to 110 octane, Regular 92-92.. However, this was due to a very dangerous lead additive.. I think todays gasoline is better so long as the engine was built around the octane to be used..
    Remember pulling plugs at least once a week to clean the lead deposits off them or they would short and screw the timing up..
    jimmy six and squirrel like this.
  10. This is very close. I worked for Standard Oil in the late '60s/early 70s and IIRC Chevron (regular) was 93, Chevron Supreme was 99, and Chevron Custom Supreme (white pump) was 105. These numbers could vary from place to place and even season as the mixes were semi-tailored to local conditions. These were all research octane numbers, not the lower motor octane.
  11. Budget36
    Budget36
    And I recall it was full service too.
  12. Chicster
    Chicster
    And if you filled up you got a gl***, get a oil change and you got the pitcher to match the gl***es.
    Deuces, loudbang, jimmy six and 3 others like this.
  13. greybeard360
    greybeard360
    If you were pulling plugs once a week to clean them it was way too rich or burning oil.
    Exactly how does a fouled plug change the ignition timing? Answer: It can't.
    warbird1, Special Ed, Deuces and 2 others like this.
  14. Jmountainjr
    Jmountainjr
    I remember pulling my '55 Chevy into the Sunoco station and filling the tank with 260. It kept the 301 running strong.
    Deuces, egads and loudbang like this.
  15. Truck64
    Truck64
    from Ioway
    Steak knives!
    egads, Deuces, loudbang and 2 others like this.
  16. Flat Six Fix
    Flat Six Fix
    Tiger Tail, ESSO put a tiger in your tank. A whole differn kinna tale....lol
  17. hotrodjack33
    hotrodjack33
    And S & H Green stamps:D
    egads, Deuces, Truck64 and 2 others like this.
  18. jetnow1
    jetnow1
    from CT
    And we checked your oil, tire pressure, cleaned windshield, rear window and lights.
  19. roseville carl
    roseville carl
    and had 8 seconds to respond to bell going off or you were fired, all for a buck an hr. and closed the station down 6 days a week at 12 pm......... but did get to use the racks after work for my own use that was worth the min wage gig............
    Special Ed, egads, Deuces and 4 others like this.
  20. warhorseracing
    warhorseracing
    from cameron wv
    I pumped alot of gallons after school from one of those at the Sunoco station. At the other end of town was the Texaco with Fire Chief regular and Sky Chief high test. In the center of town was the American station and they had the little circles that spun around when the gas was pumped. Any regular was$.26 a gallon.
    Deuces, loudbang and egads like this.
  21. TCATTC
    TCATTC
    I believe the Gulf stations called theirs Good Gulf and No Nox
    Elcohaulic, Deuces, loudbang and 2 others like this.
  22. 31hotrodguy
    31hotrodguy
    Although I have never heard of this issue i think he was referring to the deposits causing issues with the spark because of the electrical conductivity of the lead.
    Deuces likes this.
  23. Rusty O'Toole
    Rusty O'Toole
    B/A station in small town Canada mid sixties, regular was 88 hi test was Super 98. I always thought that was the octane. Blue Sunoco 103 octane. All gas was leaded back then, we also sold naptha gas for blow torches, coleman lanterns and stoves, it had no additives.
    warhorseracing likes this.
  24. hotrodjack33
    hotrodjack33
    And you could get a pair of vacuum-formed (orangish brown) horseshoes to put on your car:)
  25. Truck64
    Truck64
    from Ioway
    I thought I read Amoco sold unleaded back in the day? By that I mean long before TEL was banned for automotive use.
    I wish they still sold "White Gas" for stoves and lanterns, it's well north of $12 a gallon now. Why, I'm not sure, it's 50 octane first cut Naptha with no additives. Seems like it should cost less than auto gas, at least wholesale.
  26. mountainman2
    mountainman2
    Don't forget Gulftane! :rolleyes:
    hotrodjack33 and egads like this.
  27. Pete1
    Pete1
    from Wa.
    Ah yes, the good ol' dayz when av gas came in 4 colors and was only a nickle more than "white pump".
    warbird1 and 31hotrodguy like this.
  28. TCATTC
    TCATTC
    I have some of those somewhere
    hotrodjack33 likes this.
  29. Rusty O'Toole
    Rusty O'Toole
    I was talking about the gas stations I worked at, I don't think they sold Amoco around here. Unleaded gas was a new thing in the 70s, they had special pumps for it at first.
    Truck64 likes this.
  30. Dave G in Gansevoort
    from Upstate NY
    Amoco white gas late 60s early 70s was about 100 octaneby the method they used then (motor I believe). No lead, but there was another additive that wasn't too good for us either, however it didn't foul plugs. It was the recommended gasoline for 2 stroke engines, as it had adequate detonation/ping resistance, and as 2 strokes didn't need the TEL to protect valves and seats it was good for most purposes. Add a little Fuel Activator to boost octane for racing snowmobiles (well a lot actually, a whole bottle per 5 gallons...) and good to go.
