Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. bchctybob
    bchctybob
    FINALLY, we are having decent weather for Bondo and paint work so I'm attacking my roadster frame again. Hoping to at least get it primered and blocked this week and the paint ordered.
  2. WB69
    WB69
    from Kansas
    Was going to get one out of hibernation today for a little cruise after it's winter nap. Checked fluids, tires, and other little things. About to fire her up when unexpected company showed up. Welp, so much for the cruise.
    61Cruiser, bchctybob and Lil32 like this.
  3. Rocky
    Rocky
    Classified Editor
    My buddy, Dar came over today to help me watch the NASCAR race and afterward we wandered out to the garage to visit my 50 Pontiac. I told him I'd run the engine last Thursday and drowned it with Marvel Mystery oil while it was running, 'till it died and prolly wouldn't start until I cleaned the plugs. Just for the helluvit I turned on the key and hit the starter,,,,,,Vroom! It fired up after the 2nd revolution! The engine was quieter than it'd been before but still missed on one cylinder.
    mad mikey, Hamtown Al and bchctybob like this.
  4. Marty Strode
    Marty Strode
    Olds 1.jpeg Garage find ! Found this in my garage, where it has been for 25 years, going to a new owner on Tuesday. Would you believe it was painted, cut and rubbed a week later, back in '96, never been waxed !
  5. jimmy six
    jimmy six
    With the help of fellow HAMB member Mike from Washington I installed the first and maybe only custom feature on our 56 Vic. I’ve kept the exterior all stock with the exception of wheels and a slight rake, but the chance of Lee tail light lenses changed that. I’d already gone to LED bulbs mostly for safety and they work great with the Lee’s. There’s a rubber trim gasket for now but may go to the original cork style later..
    Would have liked a set of Dodge Polaras as Merc Wagons are no in the budget.
    F75FD73A-7A8A-4507-8244-567E73B87841.jpeg 710BF79A-D9D3-4C1A-A565-718F00F3677C.jpeg
  6. Chappy444
    Chappy444
    Special thanks to @Mac VP for taking the time to help this transmission noob get what I needed. Its nice when the owner of a company takes 30-40 min to help you understand what you need and get the right parts ordered.
    Chappy
  7. Moparmaniac79
    Moparmaniac79
    [​IMG][​IMG]
    I managed to strip off the front clip without breaking any bolts and only one busted knuckle. But now I see how gone my core support is and how bad the nose is gonna be to fabricate.
  8. winduptoy
    winduptoy
    Front seal time in the Roadster.
    I had to take the spring mounting bolts off... nope not enough clearance to get the pulley off. Jack up the front of the engine... nope header pipe hitting firewall. Take off header which also means take off intake... jack it up nope valve cover hits the firewall. Pull the valve cover which means pull the dizzy... success. Lost that ugly split loom plastic***** too IMG_20210303_162046427.jpeg IMG_20210304_081316974.jpeg
    Sent from my XT1585 using The H.A.M.B. mobile app
    mad mikey, 40two, LAROKE and 5 others like this.
  9. Greg Rogers
    Greg Rogers
    Finally got in shop, removed box , rear fenders, running boards, etc to take to get sand blasted. IMG_3168.JPG IMG_3167.JPG
    mad mikey, Lil32, Stock Racer and 4 others like this.
  10. Lloyd's paint & glass
    My guess would be limited clearance for the wrench.
    mad mikey and winduptoy like this.
  11. DDDenny
    That photo does not do that Olds justice Marty!
    I saw it at Martys' place just like this many years ago and it is a stunner.
  12. Black_Sheep
    Black_Sheep
    Valve cover gaskets showed up yesterday so I changed them out and fired up the ‘58 for the first time since late October. It took some cranking to fill the carb but it allowed the engine to build oil pressure before lighting. I let it run for a minute at high idle then let it idle until it reached operating temp. I still have a couple odd jobs to do but there’s plenty of time before spring rains wash the deicing chemicals off the roads...
  13. Marty Strode
    Marty Strode
    Doug, It got a good home with Harold Wallace, the premier stainless steel repairman. He straightened the trim for that car in 1986, and has restored several concourse quality cars. The best part was, at 81 he was giddy as a kid, getting his first car.
  14. LAROKE
    LAROKE
    Beautiful! FYI, I had repop lenses (Chevy truck) shatter and fall off several times before I realized the repops (from China) didn't come with the shouldered screws of the originals that would allow the expansion of the cork when it got wet. Something to check if you go with the cork.
    lothiandon1940 and winduptoy like this.
  15. LAROKE
    LAROKE
    From the BillyBob Shop log
    March 6th 2021 Scraped gasket bits off the block with a razor scrapper. Sent for a specialized tool to remove the freeze plugs but that was a waste of money. The removal tool wasn't any easier than a common chisel. Some days are like that. Removed gobs of loose rust from the water jacket with a pocket telescoping magnet. Removed the drainage petcock from the driver side bank and cleaned the rust from the hole where the passenger side petcock once was, I presume.
  16. topher5150
    topher5150
    Flipping through some junkyard pics from this past summer, and it got me thinking that I need to do some more pilfering.
    Does anyone know what the steering shaft size for an AMC Rambler American would be?
  17. jimmy six
    jimmy six
    Now that’s a ...”Y”...block
    mad mikey, lothiandon1940 and LAROKE like this.
  18. LAROKE
    LAROKE
    Yup, both Ford and Buick had deep crankcase designs.
    mad mikey and lothiandon1940 like this.
  19. saltflats
    saltflats
    from Missouri
    Got the exhaust manifolds blasted and painted for the 62. :)
  20. High test 63
    High test 63
    IMG_20210308_171537660_HDR.jpg took the AA out of hibernation.
    Went for a little blast over to my parents place.
  21. FRANK GRELLE
    FRANK GRELLE
    Got her out for some exercise and test my "New " Steering column ,gonna take little getting use to the fact there is no delay when i turn the wheel ,..lol 156431284_1334214253606619_7403536767558689106_n.jpg
  22. bchctybob
    bchctybob
    More sanding..... trying to get my roadster frame painted so I can start reassembly. It was sandblasted and epoxy primed. Sandblasting exposed a lot of little ugly that they primed over. I still have one more round of filling and sanding then it gets the poly prime, and more sanding. :eek: Lots of nooks and crannies to get into.
  23. jimmy six
    jimmy six
    And now the LS ....oh! the Horror..
    LAROKE likes this.
  24. WB69
    WB69
    from Kansas
    IMG_2825.jpg Grandson and I got one of the old girls out of winter hybernation and went for a cruise. Glad he enjoys my company as much as I enjoy his!
  25. saltflats
    saltflats
    from Missouri
    And the Mopar. ;)
    mad mikey and LAROKE like this.
  26. LAROKE
    LAROKE
    March 7th 2021 The jagged, sharp casting flash at the bottom of the lifter bores had never been smoothed on this nailhead block so, I used my newly rediscovered burrs with the electric die grinder to take the edges off. Nothing fancy, just enough to eliminate small bits from breaking off. Background music was Rolling Stones Hot Rocks Volume II.
  27. lothiandon1940
    lothiandon1940
    Rolling Stones! What's not to like .:D
    High test 63, mad mikey and LAROKE like this.
  28. LAROKE
    LAROKE
    March 11th 2021 Made the first pass at cleaning the flat machined block surfaces with scotchbrite "cookies" in the air-powered angle grinder. I know this method is controversial but I don't have the gumption to do this by hand and I'm a*****er for shiny metal.
    After watching Matt on Iron Trap Garage clean sheet metal, I decided to take a pass with the Eastwood SCT Surface Conditioning Tool with the 120 grit drum (the finest grit I currently have) instead of the Scotchbrite cookies as an experiment.
    The experiment was a success. Only took ten minutes for one bank, including a time out for a short gasket scraping. Advantages of the SCT drum is that it is five inches wide, runs at a slower speed and is electric. I also ordered a finer grit drum for future ops.
    Meanwhile, I'm still struggling with the oil galley plugs. All I've managed, so far, is to drive two of the little*******s in deeper. Beer of the day was Nebraska Brewing Company's Cardinal Pale Ale.
  29. lake_harley
    lake_harley
    With much difficulty, head scratching, two trips to the hardware store and the help of a friend here and there over the last 2 days, the running boards/splash aprons, front fenders and headlight bar are finally back on my '31 Coupe project. The 2 days doesn't include the days and days it took to get the fenders presentable. The fenders needed a lot of hammer and dolly work, patches, some filler and lots of priming and block sanding, but they turned out very nice considering how they started out. Big thank you to my long-time friend Stan! If I EVER mention anything on the HAMB about wanting to build another full fendered car, PLEASE remind me of the grief it is to get fenders on without destroying them!
    On a good note....I'm really pleased with what the stance of the car might look like. A few more things to finish up since they'll be easier to get to and do before the body goes back on, but at least this thing is starting to take shape.
    Lynn
  30. lake_harley
    lake_harley
    Another accomplishment, this time one that actually looks like progress! Put the body back on for hopefully the last time. Two front and two rear bolts have it lined up for now. The wood blocks and rubber pads are in place, and the bolts are dropped into the holes from above and into the blocks. Still might have to do a bit of lining up of holes into the frame with a tapered punch but at this point it should be about ready to bolt in place. Things could change with body alignment as bolts are tightened but at this point doors are lined up pretty nice and they open and close easily. Fingers crossed!
    I'm pretty pleased with the rake too. At this point I have between 1" and 1.5" of down-in-front rake along the length of the running board. I'm 5'9"-ish and the highest spot of the roof is about even with the top of my head. I think I'm going to like it!
    Lynn
