Hot Rods 1933 willys coupe build
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Sep 4, 2014.
  1. drumyn29
    drumyn29
    Since thee isn't a manual for these old Fairbanks transmissions, I have had to feel my way through the dark. After mount my new clutch, I realized that the only way to make it all work is to have an adapter cut. $150 on a one day turn around, not bad. Now I need to find a roll cage guy.
  2. Inland empire hot rods
    from so cal
    Hey Oswald! Mark Ducharm here! Loving all your projects!
    Sent from my SM-G973U using Tapatalk
    elgringo71, loudbang and Thor1 like this.
  3. drumyn29
    drumyn29
    HEY HEY HEY
  4. drumyn29
    drumyn29
  5. elgringo71
    elgringo71
    Looking great, nice work
    Thor1, loudbang and chryslerfan55 like this.
  6. Inland empire hot rods
    from so cal
    Thor1 and loudbang like this.
  7. flatheadgary
    flatheadgary
    from boron,ca
    i think irwindale would be closer. that is if they are still runnig.
  8. drumyn29
    drumyn29
    I can't do 1/8 mile
  9. steveo3377
    steveo3377
  10. drumyn29
    drumyn29
    Getting ready for bead blast
    TFoch, mad mikey, LAROKE and 4 others like this.
  11. drumyn29
    drumyn29
    I'll take a look but I think they are nothing fancy, I bought them for $20 just so it could roll.
    Thor1 likes this.
  12. drumyn29
    drumyn29
  13. The37Kid
    The37Kid
    Nice! Will it cost a lot to get the rest or the driveway to match now?:rolleyes:
  14. drumyn29
    drumyn29
  15. drumyn29
    drumyn29
  16. Fordgasser1
    Fordgasser1
    from Jersey
    what steering box did you use?
  17. willys36
    willys36
    osage orange and loudbang like this.
  18. drumyn29
    drumyn29
    aluminum vega box
  19. willys36
    willys36
    Didn't know Vegas came in aluminum.
  20. dirt t
    dirt t
    It did not. Corvair was aluminum and maybe a Chrysler box.
  21. willys36
    willys36
    I use the reversed 'Vair. Pretty much the standard G***er box.
    osage orange, TFoch, loudbang and 4 others like this.
  22. I'm not sure how I missed this thread...until today. Wow, just wow...pegged the coolometer!
    Am I the only one that wants a walk around tour of your cool digs and projects?
  23. Fordgasser1
    Fordgasser1
    from Jersey
    I have a reversed corvair box but it won't fit with the starter being on the DS of the 426 hemi so i'm looking for other options.
  24. willys36
    willys36
    I had the same problem with my 354 hemi. It is actually a long bell housing 331 that has been bored to 354. I solved this by welding a starter flange on the bottom bell housing pan on the p***enger side.
    Here is my gear that goes thru the factory hole in the frame rail. See the starter hole cover plate behind the gear.
    Here are two views of the new starter mount. Welded up out of 1/4" steel plate, welded to the cast iron pan then steel reinforcement plates bolted to the mount and cast piece in case the iron weld didn't hold. Been working great for 30 years.
  25. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks for the pics..Thats pretty darn cool..I was actually thinking about ways to relocate the starter! if it was on the p*** side it would solve the steering issue.
  26. drumyn29
    drumyn29
  27. drumyn29
    drumyn29
    Thor1, mad mikey, TFoch and 1 other person like this.
  28. ROADSTER1927
    ROADSTER1927
    Very COOL Thanks!:D
  29. elgringo71
    elgringo71
    Hill born two port and a chain drive. That is a wicked little beast.
    Thor1 and mad mikey like this.
  30. drumyn29
    drumyn29
    Scott 2 port with a Scott pump.
