Technical Rust-oleum paint
Discussion in 'The Hokey Ass Message Board' started by birdman1, Mar 4, 2021.
  1. birdman1
    birdman1
    I've used Rust-Oleum black paint on frames and ch***is and brushed it on. Very satisfied with the results. I'm building a 1937 ford coupe dirt track tribute car, don't need or want a fancy paint job. Anyone used the Rust-Oleum paint and sprayed it on? Thanks Henry IMG_20210227_135009527.jpg
  2. mitch 36
    mitch 36
    I have brushed/ rolled satin rustoleum on the body, turned out the way I wanted. Mitch
    PoTaToTrUcK likes this.
  3. Hollywood-East
    Hollywood-East
    KIMG2897.JPG I use 7777 satin black on frame's, an off-road bumper's etc, reduce with urethane reducer till your comfortable with spray out... Doesn't take a lot...
  4. I've sprayed it. Thinned it with Xylene. Also put hardener in it. Fairly durable!
    1952henry and mrharley66 like this.
  5. I’ve used it. Looks ok.
    I used an alkyd equipment enamel with a hardener, I liked it much better. Cost around $15 more a gallon to use it.
    there are more color choices available
    1952henry and chryslerfan55 like this.
  6. swade41
    swade41
    from Buffalo,NY
    The headlights are rattle can and the body and grill shell are rolled on with a foam roller
    When I first sprayed them
    The black is also rattle can
  7. tombstone
    tombstone
    from sk.canada
    Inside of frame satin black , outside of rails gloss black . Rolled on with 4 inch foam roller , spent time sanding with 400, 800, wet.... then compound and a polish . Did two rods this way with satin black both came out good , will do this one a two tone gloss . Time consuming but very pleased with outcome and durability ..... and cost cause I’m CHEAP ‼️ 90680AB9-D977-4568-98D3-0AAFEB5E386A.jpeg
  8. Flat Six Fix
    Flat Six Fix
    Here yah go 8 years ago painted my truck with a similar paint.
    This is Home Hardware Rust Coat tintable enamel.
    Mixed with generic acrylic enamel hardener, reduced with standard urethane grade reducer and shot on with a gravity flow gun at 45 psi and 1.4 tip.
    Good enuff for my needs, as good as nason or Omni acrylic solid color enamel.
  9. Did the same many times...be fore -warned...sticky shoes and nose hairs....hahaha
  10. how about trying this...Latex house paint thinned with water and sprayed on your race car. I have painted a couple cars with Velspar satin thinned with water and had great results $35.95 a gallon and water clean up, no need to mask or wear a suit...takes a while to harden up but it will last...someone crashed my truck and I had to put some fenders, running boards, new bed, tailgate, and cab rear fixing on it. 4years aged and it went on with no tell tale lines...great. I have even gloss cleared over it on the dash and firewall.
    I did use rustoleum satin black on the ch***is, daily driver choice for sure. easy to touch up ida3.jpg
  11. Blues4U
    Blues4U
    from So Cal
    Oh geeeez, I think there's a whole bunch of guys here on the HAMB that just went apoplectic after reading this! You can't do that! :D :D
    chryslerfan55 and swade41 like this.
  12. gene-koning
    gene-koning
    I put a bunch on miles on my coupe ( close to 10,000 miles a year) with the local farm store brand of oil based paint. I'm not a wax kind of guy, I'm a get in and drive it, wash it if it really looks bad kind of guy. I've done several vehicles with this paint.
    Don't over thin it, if you thin it too much, it won't hold up worth a ****.
    It takes days to completely dry, weeks if you intend to do any sanding.
    Be sure you add the hardener, bugs hitting it at highway speeds will chip it without the hardener.
    My stuff sits outside. The paint looks really good for the first 2-3 years. Then it starts to fade. It chips more easily as the paint gets older. After 4-5 years its starting to look pretty rough, just about right for an old dirt track car...
    For me, the 5 year time line is OK, I hate body work and tend to quit before its really done. When the paint starts to look bad, I just redo the body work, and paint it again.
    Over the last couple of years, all paint has changed for the worse. The cheap Rustoleum kind of paint has really been effected. It doesn't seem to hold up nearly as long as it used to. This last time I redid the body on the coupe (I had rust issues I had to fix), I broke down and did acrylic enamel paint. The car is two different colors. Two quarts (one of each) of color, the needed hardeners, thinner, and sealer at my buddy's body shop cost was $285. I don't intend to paint this car again. Gene
  13. Flat Six Fix
    Flat Six Fix
    It doesnt normally take days to dry, it takes a few weeks to cure. If you use a hardener its dried and cured much quicker.
    This type of paint has its limits, but so does cheap automotive paints too.
  14. mikec4193
    mikec4193
    I ran roundy round cars for years...nothing but yellow Rust-oleum paint and I thinned it and that was it...looked great...probably gonna do the same thing on my current hot rod (a vintage roundy round car)...
    MikeC
    chryslerfan55 and alanp561 like this.
  15. oldiron 440
    oldiron 440
    The way elkyd enamel would have been sprayed back in the 50s would have been to put the gallon of paint on a hotplate and warm it up until it got to the viscosity for spraying. No reduction no harder.
  16. Hollywood-East
    Hollywood-East
  17. TCATTC
    TCATTC
    But you can buy house brand real car paint from Summit cheap. They even have satin and flat colors.
  18. Mopar Tony
    Mopar Tony
    If you are wanting satin, John Deere Blitz Black is great, durable, and cheap.
    Not my truck but this is painted in Blitz Black
    chryslerfan55, WB69 and ramblin dan like this.
  19. OverThePond
    OverThePond
    from London, UK
  20. alanp561
    alanp561
    You know, if foam rollers had been available back in the 40's and 50's, I just bet that would have been the way a lot of paint jobs would have been applied. It looks like you built your car to drive and I can't see a thing wrong with anything you've done with the paint. If I ever get mine to where it's going to get painted, that's the way I'm going.
    chryslerfan55, swade41 and 48fordnut like this.
  21. birdman1
    birdman1
    Thankyou all for your help. This is a tribute car to my 3 brothers and I. Going to have all our names on it, 2 of them are gone now.
  22. Rusty Heaps
    Rusty Heaps
    67B19E4A-C687-4A87-90FB-903576E20215.jpeg I rattle canned this entire car with the satin and later compounded and waxed it. I have people ask if it’s the original paint and a garage find
  23. Ice man
    Ice man
    I often hear of Rust Oleum paint on this sight and often think of my story of this famous paint. This was in the late 50s and I was working on my 39 Buick coupe, newly married and living in a small 2nd floor apartment with no space to work on my car. A friend told me about a man he knew, not far from our apt that had property where I could work on the Buick. WE met the old man and he was just a prince of a man, and was happy to have me come to his FARM as he called it to fix my Buick. But it was just property. no farm, no animals, and we often talked about his life. He was a black man, at a time when few were wealthy and could afford property in a Pittsburgh suburb, and he had many acres. He told me about has work along the Ohio River and his dealing with the ever-present rust where he worked. He developed some of his ideas and came up with a Paint that used fish oil and worked well with steel and the ever present rust problems. He showed me some of his early samplings and early on realized that he did not have the money to sell his product to the world around him, so he hired an attorney who was able the find a buyer for his idea and was paid a good Dollar Figure and Bill was made a wealthy man, was able to buy his farm and live a happy life. He became a close friend, and was always happy to see me come out to repair the Buick. I lost touch with him when I moved down south in 59, driving the Buick to Georgia. But when I hear of Rust Oleum paint I think of Bill, and his idea and how much his idea is still used today long after He is long gone. I can only describe him as a very gentle man who was a friend when I really needed a friend. Iceman
  24. I painted my Merc. with Rustolean Paint & it Lasted about 8 years
    I have to do it again, & I will Shoot it again.
    Just my 3.5 cents
    Live Learn & Die a Fool
    alanp561 likes this.
  25. ramblin dan
    ramblin dan
    Sure I've used it and also Trem-Clad. Brush painted my engine bay with gloss black and just cut it with varsol to cut down on brush marks.
    Flat Six Fix likes this.
  26. theHIGHLANDER
    theHIGHLANDER
    Like old school alkyd the overspray will be wet. It will stick to everything that isn't covered, and be sticky for a day or more. If you don't want overspray on it, cover it. Gonna spray outside? Cover the ground, but if it's breezy you'll have neighbor trouble ***uming you have neighbors. That's all I got for ya.
  27. 283john
    283john
    I rollered this wagon over ten years ago with thinned Rustoleum Antique White. Six coats with a wet sand and wheel buff afterwards. Still looks good but it is garage-kept.
    swade41 likes this.
  28. bigdog
    bigdog
    Yep, what he said. The overspray is a *****, plan ahead.
  29. 1971BB427
    1971BB427
    from Oregon
    Never painted a body with Rustoleum, but I have brushed, rolled, and sprayed frames, and floors inside and out with it and it's all I use now. Holds up great, and easy to use. Plus it's cheap.
