Technical Steering box ID
Discussion in 'The Hokey Ass Message Board' started by Chappy444, Mar 6, 2021.
  1. Trying to ID this steering box... thought it was early to mid 40's but not finding to much on the ol' interpersonal.
    It's marked Saginaw Gear 263587 8
    Thanks for any info
    Chappy
    (For some reason I can only upload this one picture of the box, all others give me some strange security error warning)
  2. AHotRod
    AHotRod
    Picture no work
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Looks industrial , fork truck or similar ?
  4. squirrel
  5. squirrel
  6. Chevy or GMC side steer.
  7. Thanks all,
    Going to try and make this work on my build.
    Just need to figure out the original mounting and see if I can make it work for my application.
    Thanks again.
    Chappy
  8. squirrel
    it had a clamp, that bolted to the frame.
  9. Is that for your coupe or something else?
  10. New project. I am doing a prewar racecar kind of thing with a 23 roadster.
    Right now it is a pile of parts scattered over 5 locations in two states...lol
    I keep rotating parts through the garage to refurb them.
    I will try and do a build thread once I get closer to mock up and final assembly
    How is the 51 coming along?
    Did you get the wiring sorted?
    Chappy
    warhorseracing likes this.
  11. @squirrel thank you so much for the insight and helpful links.
    Much appreciated!
    Chappy
  12. squirrel
    I found a picture of one in use in a hot rod.... Steve's 31 Chevy roadster, in TRJ65. He used lots of 1940ish truck donor parts to build this car, front and rear axles, steering, etc.
  13. Still sorting the bodywork and almost have the roof hood trunk and drivers side done off and on then on to the passenger side. I got a Rebel Wire harness and am re wiring the entire car 6 Volt. Take care and have fun.
  14. Looks like the 30s GM pickup box I used in my old Touring. Got the idea from Clark aka Sowhat
  15. Lol... I got this box from Clark...
    Chappy
    Tman likes this.
  16. Thanks...
    That almost looks like a main bearing cap clamping the box to the top of the frame...
    Chappy
  17. cfmvw
    cfmvw
    That's a nice looking setup; be sure to show us how you installed yours!
  18. Joe H
    Joe H
    http://chevy.oldcarmanualproject.com/parts/1929_54/396.htm
    '37-'40 Chevy truck, 1/2 -1.5 ton all used the same gear box, the bigger trucks 1 - 1.5 ton had longer shafts for the steering wheel. Pitman shaft / sector gear were all the same.
    16 - 1 gear ratio. Internals are gear on gear, so check the worm gear for wear marks and the bottom bearing for water damage. The lower race is part of the worm gear, so if it's bad you are shopping for whole new shaft or gear box.
    If you rebuild it, add a second bushing where the sheet metal spacer is out towards the end of the pitman shaft. It adds way more support out on the end of the shaft. The spacer is shown as a bushing in section 6.855. Go to NAPA for a seal, NOS 11055. Bearings are barrel shaped and can be had from most of the Chevy Truck parts venders. You can make your own gaskets. John Deere Corn head grease works really good, grade 00 so if flows back in on itself, cheap to.
    Budget36 likes this.
  19. Joe H
    Joe H
    There are two machined pieces that clamp the gear box to the frame, you can see the wear marks on the housing 16150668322985545512224126773866.jpg
