Projects Potvin Blower On A Studebaker V8
Discussion in 'Traditional Hot Rods' started by 60elky, Jan 15, 2020.
  1. 60elky
    60elky
    I will trim a case at some point. I emailed Dyers to see at what point in the blower conversion would be OK to trim it. Send me an email, jakammer@charter.com
    kidcampbell71 and loudbang like this.
  2. Brand Apart
    Brand Apart
    from Roswell GA
    Well good for him, not only would I rather buy American but buying local is even more important if possible. Not to mention the OP already has a relationship with the machine shop making him other items. Lastly if any adjustments or tweaks become necessary good luck going back to China.
    My 2 cents but most people don't think it's worth a penny anymore.
    Budget36 and loudbang like this.
  3. gbones32coupe
    gbones32coupe
    Wow I'm subscribed!!!! I'm building a 32 with a potvin hemi.That turned out real nice!!!!! That is going to be so cool I love anything with a front blower on it. Can't wait to follow tis build its going to be a good one. 2021-03-04-01-11-40.jpeg
    Sent from my LM-Q720 using The H.A.M.B. mobile app
    NealinCA, Tim, Fordors and 11 others like this.
  4. gbones32coupe
    gbones32coupe
    Hey are you planning on running an alternator if so how are you going to drive it? I'm struggling with this situation I may have to run a pulley off the front of the blower and a fuel pump at the same time but I'm not sure if The fuel pump shaft will be strong enough to power both. Or run fuel pump off the mag and just power alternator of front of blower. Pretty much the only two options?
  5. mohr hp
    mohr hp
    from Georgia
    This is really cool. I've contemplated building a 299 Stude V8 with a roots blower on top. Do you think I could make 550 HP with a streetable combo?
    stillrunners and loudbang like this.
  6. Why not run an alternator on the rearend like sprintcar guys do?
    loudbang, guitarguy and Deuces like this.
  7. gbones32coupe
    gbones32coupe
    I'm going to need constant power to run electric motors for cooling fans and water pumps putting radiator in the back of the car and I'm running a starter and lights. I thought about running a charging system off the rear and that could be an option but if I get stuck in traffic the battery will go dead. I just do not think I will charge enough power to support al of that. Front mounted blowers are great for drag cars but I'm trying to drive mine on the street as well.
  8. Brand Apart
    Brand Apart
    from Roswell GA
    I'm looking forward to seeing how you solve that along with other things that may arise. This is already so cool.
  9. gbones32coupe
    gbones32coupe
    Ok so what type of injector are you going to run and how are you driving the fuel pump? I love how you did the water neck that looks real nice. Everything looks nice. making that gear 3d print was a great idea so cool man.
  10. drumyn29
    drumyn29
    WOW, AMAZING WORK!
    I came across an early Hemi potvin cover and a potvin early cam and I am going to try and scramble parts together to build it. If you stumble upon any potvin parts or pieces, please let me know.
    I'm trying to figure out what Potvin did in the early days to attach the blower to the cover. There must have been a plate with counter sunk holes I'm guessing.
  11. Nailhead Jason
    Nailhead Jason
    That looks killer!!! Where did those slick exhaust manifolds come from? they would be great on the 259 Stude in my 31 Sedan.
  12. Potvinguy
    Potvinguy
    from MSP, MN
    Say, I’m running a Potvin with EFI on a street T bucket. Lemme know if I can help.
    stillrunners and Tim like this.
  13. enjenjo
    enjenjo
    from swanton oh
  14. stillrunners
    stillrunners
    from dallas
    Those are pretty dang ***y......do need to be seen.....
