Hot Rods A New England Channeled Roadster
Discussion in 'The Hokey Ass Message Board' started by 51box, Aug 28, 2020.
  1. The37Kid
    The37Kid
    Great side view, rear tire covers the wheel well just about perfectly.
    Bob
  2. 51box
    51box
    from MA
    I would love to have a chrome firewall in this! Unfortunately it is pitted from end to end and my sheetmetal work always requires a bit of polyester leveling enhancer.
    brEad, Tman, chryslerfan55 and 4 others like this.
  3. The37Kid
    The37Kid
    Buffed stainless or aluminum sheet could be bolted over it.:rolleyes:
  4. 51box
    51box
    from MA
    Made up the rear sub rails out and of some 1/16” plate bent 90 degrees and plug welded them to the inner wheel wells. Skinned the floor with 18 gauge and made a small bump over the rear end to finish out the trunk area. C14F0F0D-4180-4CC9-9B99-7794E3B0CFF6.jpeg
    Working my way forward skinned the rest of the kickup and connected the tunnel to the floor. The pinion is off center 1 1/2” and didn’t want the tunnel to look too crooked in the car so I just made it a little wider then it needed to be. Also made up those two small bumped out covers for access to the spring adjusters.
    hfh, catdad49, brEad and 10 others like this.
  5. 51box
    51box
    from MA
    Had a nice productive day, made up some more floor bracing and skinned both sides up to the toe board area. 63F408A3-31D2-4966-A319-5334E1FF1004.jpeg
  6. vtwhead
    vtwhead
    It's coming along nicely. Nice job on the pans.
    51box and loudbang like this.
  7. 51box
    51box
    from MA
    Picking away at the tunnel this week, with the transmission pretty much inside the car it was definitely a challenge to keep it fitting tight without looking like a square box. These tunnel pieces were formed by hand over a 4” piece of pipe and then welded together behind the shifter. 29C31720-69AB-4E4C-86DB-90A163078FD5.jpeg
    rod1, hfh, catdad49 and 10 others like this.
  8. Looking great. I like the section taken out of the frame rails. You rarely see that great hack!
    Stogy, loudbang and 51box like this.
  9. 51box
    51box
    from MA
    Thank you, when I first saw the sectioned rails on a channeled car I thought man this is genius. You get the look but can still sit low in it
    Tman and loudbang like this.
  10. TFoch
    TFoch
    Nice fab work! Looking great!
    chryslerfan55, 51box and loudbang like this.
  11. gonzo
    gonzo
    I completely missed that detail earlier on. Genius.
  12. 51box
    51box
    from MA
    First I needed to build a new flange along the bottom of the firewall to give myself a target for the trans tunnel to land on. This was made from 1/16” plate and shaped with a torch.
    I decided to weld the trans tunnel and toe boards together to keep it simple. The tunnel is 18 gauge and the toe boards are 1/16” plate.
    Here it is bolted in the car, it adds a tremendous amount of strength to the floor as you would imagine.
    With that project done I cut out the temporary bracing and laid some seat cushions in to make sure I fit before moving on. So far so good!
  13. The37Kid
    The37Kid
    I really like this project, hard to believe there is this much steel attached to a gl*** body. Still remember the Westcott I had, $2,200 delivered to Connecticut back in 1976.
  14. pprather
    pprather
    I believe it is a Brookville steel roadster.
    Stogy and loudbang like this.
  15. 51box
    51box
    from MA
  16. The37Kid
    The37Kid
    I stand corrected, most Brookvilles are in red primer, Wescotts are dark gray.:oops:
  17. 51box
    51box
    from MA
    Here’s what has been going since finishing the floor up.
    Due to the angle of the rails being pinched so hard the F100 steering box needed the flange cut off and a new piece made up. I used a piece of 1/2” thick plate and made a washer out of 16 gauge stainless. 1CB94D81-35E2-4331-AB12-0F5A1648A9CB.jpeg
    This works nice because you can drill your holes, bolt it to the frame and then set the position exactly where you want it before tacking. 2B5CF7F7-AB58-4408-995C-2141AA124BF8.jpeg
    I used silicon bronze filler to attach the flange to the cast steering box.
    Now that the steering column was in I made this reinforcement plate 1/4” thick and welded it in to the firewall for the swing pedal / master cyl setup.
    A shot inside the car with how it all lays out. Somehow an original 32 column drop worked out with no modifications. B70426B3-85F2-4851-A40C-C725977E9348.jpeg
    With those pieces situated I ordered up some mandrel bends and built a set of headers. They probably aren’t the best design for performance but I think they look pretty neat. E41A993E-2FC3-4F43-98AD-2F0A5DF55301.jpeg
    rod1, Tim, hfh and 19 others like this.
  18. gnichols
    gnichols
    from Tampa, FL
    What kind of pedal ***embly / master cylinder are you using? Or did I miss the info earlier? Thanx.
    loudbang and Stogy like this.
  19. The37Kid
    The37Kid
    I like the cowl bracket on the side of the rail. Little things like this are eye catchers. :)Bob
  20. TFoch
    TFoch
    Nice work! Headers look great!
    loudbang, Stogy and 51box like this.
  21. 51box
    51box
    from MA
    The pedal setup is from Rjays speed shop, very nice unit. I purchased the master cylinder and slave cylinder from Rockauto. They are early 60’s chevy truck items.
  22. 51box
    51box
    from MA
    Thank you, channeling a car definitely brings out many obstacles to overcome.
  23. 51box
    51box
    from MA
    Thank you!
    chryslerfan55, loudbang and TFoch like this.
  24. triumph 1
    triumph 1
    Very nice work! Thanks for taking the time to show the steering box flange mods.
  25. 51box
    51box
    from MA
    What a day! I cut the ch***is off the table and got the front end under it for the first time. It’s really taking shape now! FFAFFF58-1033-4080-9A2D-04C3F7180B68.jpeg
    Cut in these 40’s buick taillights and got the 32 plate mounted up.
    29EHV8, hfh, wheeldog57 and 20 others like this.
  26. AHotRod
    AHotRod
    Now that's a Hot Rod ^
  27. Austinrod
    Austinrod
    from Austin
    Great thread my old 31 survivor It had 10” channeled
    catdad49, brEad, Shadow Creek and 4 others like this.
  28. The37Kid
    The37Kid
    Like the Buick tail lights!
  29. brianf31
    brianf31
    Man that looks fine! You nailed the east coast look.
  30. loudbang
    Great "Stance" :)
    chryslerfan55 and 51box like this.
