Technical Drivetrain Adaptation Tribal Knowledge Thread
Discussion in 'The Hokey Ass Message Board' started by treb11, Jan 15, 2020.
  1. in2cjs
    in2cjs
    It called the Hollander interchange been around since the 30’s
    alanp561, Tman, MO54Frank and 3 others like this.
  2. treb11
    treb11
  3. treb11
    treb11
  4. treb11
    treb11
  5. Would you share the ***le of that book?
    Ben
    GuyW and loudbang like this.
  6. treb11
    treb11
  7. treb11
    treb11
  8. treb11
    treb11
  9. treb11
    treb11
  10. gimpyshotrods
    gimpyshotrods
  11. treb11
    treb11
  12. treb11
    treb11
  13. Beanscoot
    Beanscoot
  14. treb11
    treb11
  15. treb11
    treb11
  16. treb11
    treb11
  17. treb11
    treb11
  18. treb11
    treb11
  19. How to adapt a Blue Flame/G.M.C. 6 to an early Ford transmission.
    [​IMG][​IMG]
    How I did it
    Cyclone transmission adapter-
    Ford pressure plate and clutch disc
    Speedway pilot bushing same as SBC to early Ford
    Flywheel redrilled/nutserts pressed in (N.O.S. SCHIEFER aluminum flywheel) redrilled and tapped for a steel flywheel
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Stovebolt and fegsta like this.
  20. treb11
    treb11
  21. treb11
    treb11
  22. treb11
    treb11
  23. treb11
    treb11
  24. TRENDZ
    TRENDZ
    The beginning of an early hemi adapter to sbm Lakewood ****tershield for mounting a clutchflite. A3ABDE7C-CA36-4DB4-93DE-98CB1AB56A9E.jpeg
    jakespeed63 and treb11 like this.
  25. treb11
    treb11
  26. treb11
    treb11
  27. treb11
    treb11
  28. D-Russ
    D-Russ
    In the race truck we have a Ford 262 inline six bolted to a home-made steel adapter plate that's bolted to a Lakewood Chevy bell housing that's bolted to a GM T5. The flywheel is a Ford Y block (bolt pattern is the same as the 262 crank) that's been machined down to accept a Chevy 153 tooth ring gear so we can run a Chevy starter and drilled and tapped to run a Chevy 10.5 inch clutch, pressure plate and throw out bearing. In the pic below, @57 HEAP is working on pinning the flywheel to the crank. You can see where the original pressure plate bolt holes are cut in half as a result of turning down the diameter of the flywheel. @john mullen is the mad scientist that figured all this out.
    Tim, fegsta, Hnstray and 1 other person like this.
  29. treb11
    treb11
  30. Koz
    Koz
    This is kind of weird but I just love the way a three speed feels in a light rod. I'm using this '66 GTO 389 in my Vicky with a Ford 303 trans. It is an incredibly easy adaption. I scored a steel blowproof 'bell on here and made a homemade blockplate just because the origional was missing. Nothing special. I them turned the Ford bearing retainer to GM specs, ($55.00 at B&Y Machine). The trans centered itself in the 'bell and I trnasfer punched and and added three new bolt holes by drilling and welding grade 8 nuts to the inside of the steel 'bell.
    I used a new Ram 1557LW flywheel, a stocker would have worked, along with the matching Ram GM pressure plate and generic Ford 11" clutch disc from Speedway. A '70 Bronco 3 speed pilot bushing works without modification. The whole ***embly dropped together, easy peezy. I haven't got it in at this point but hopefully everything will run very nice. No reason not to! The top shifter is a Jeep T 150, (junk yard issue), with a '48 pickup stick grafted on. After I get it properly shaped in the Model "A" it will get chromed.
    rod1 likes this.
