Technical Banjo Rear End Bolts
Discussion in 'Traditional Hot Rods' started by Littlejake, Mar 7, 2021.
  1. Littlejake
    Littlejake
    Several postings online say that you should not chase the threads on a banjo center housing because the bolts are a special thread, designed to prevent leaking. One fella even suggested that one should take care to return each bolt to the same hole it came from because each bolt is matched to the female thread in the housing. The Green Book lists a 24329-s bolt, 3/8-24X5/8 for the axle housing. No special thread. It lists a 350522-s bolt, 3/8-24X1 drilled, for the torque tube. No special thread. Is this just an urban legend? Does anybody have do***entation of special bolts for the banjo rear end?
  2. rusty valley
    rusty valley
    same bolt in the same hole!! never heard that one. I've heard the special thread story, I just clean them up on a wire wheel, and if needed a thread chaser, not a tap or die
    leadsled likes this.
  3. alchemy
    alchemy
    I think the hole has the tight tolerance threads, not the bolt. Same on the engine block deck.
    My bro and I are working on a banjo/quickchange project and I was thinking that studs might be the best answer to the leaky problem. You could glue them into the housing really nice, and then if you ever need to dis***emble, just the nuts need to come off.
    V8-m and rusty valley like this.
  4. The issue is the CL*** of thread, not the thread size and pitch. The cl*** determines the allowable thread tolerances and clearances, and the tighter the tolerances, the more strength the joint has, and the more torque that can be put into fastening the joint. I don't remember the cl*** designations, but some are so loose you can throw them in the hole from across the room, and the other end of the spectrum is interference fit. That's why you shouldn't chase threads with cutting tap unless you know it's the same cl*** as the hole. Do a quick search for 'cl*** of thread fit'
    Algoma56, warbird1 and rusty valley like this.
  5. Oldtmtech
    Oldtmtech
    You can still use modern technology and still stay traditional. This is what I have used on ot rears https://www.mcmaster.com/#93781A038
    winduptoy likes this.
  6. rusty valley
    rusty valley
    i have never really had a problem with them leaking. i do have a can of extra bolts though, so if one looks bad or wont start by hand, just grab a different one
    stillrunners likes this.
  7. tradrod1930
    tradrod1930
    So many rumors out there made to scare people! Not a good idea to chase threads in housing for no reason, but Ford wasn’t that picky about housing bolts at the factory I’m sure!!
  8. getow
    getow
    I would think that thread sealer could be used also??
  9. 19Fordy
    19Fordy
    I'm the fellow that recommended installing the bolts in the same threaded hole
    they came out of. REASON: It's easy to do and just wanted to have more insurance that there would be no leaks even with sealant. The cl*** of fit is very important also. I could not find any torque specs for those bolts. 2nd photo shows OEM safety wire configuration.
  10. trevorsworth
    trevorsworth
    From working on antique guns I am in the habit of matching screws to the holes they came out of. Screws and holes wear together. It probably doesn’t matter so much on cars but I do it anyway if I can. Can’t hurt.
